Old 23-08-2012, 02:53 PM   #31
EASYBOSS
Matakana NZ
EASYBOSS's Avatar
Default Re: since when is 13 years old "too old"
Mate well done, and thats very poor work from the origional person that looked at it.
And for some advise, from a qualifyed electrician, and as you have it working, and know what the problem was, spend a bit more time and redo your repair, loose the tape and redo your connections with some solder and heat shrink, or completly replace the wires. Do it once and do it correctly.
Also some mickey and mini pest control could be a good future invertment.
Again well done
SOLD : BA XR8 4 Speed Auto in Mercury Silver, Bluepower CIA, Full Diffilipo Big Boy Quad System, Tune, 4.11 Diff Gears, FPV Starter Button, FPV GT Rear Spoiler, Tripod Gauges, PWR Trans Cooler. 230 RWKW's. Many thanks to Chris at Bluepower Racing Developments
Hers : F6X build #150 in Ego, Stock as a Rock, untill the warranty runs out, including the extended one.
My Work Wagon AU Futura Wagon in Gold.
On the Farm : Ford 6600 Tractor
EASYBOSS is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2012, 02:55 PM   #32
EASYBOSS
Matakana NZ
EASYBOSS's Avatar
Originally Posted by davenl5l
but not the sharpest tool in the shed?........LOL
How wrong are you, turns out he is the sharpest tool in the shed.
Old 23-08-2012, 03:09 PM   #33
poppa smurf
poppa smurf's Avatar
Again well done
thanks mate, chuffed as all get out.......I will take your advice and do a bit of soldering
in the techies defence it wasn't easy to find.....I had the headlight on and the wire was tucked behind a heap of other gear.....I probably dug a bit more deeper than he did with the knowledge of nothing to lose
I intend to remove a couple of sheets of iron from the roof and see where the little buggers go to it
G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II...
may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon!
poppa smurf is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2012, 03:13 PM   #34
Mechan1k
Mechan1k's Avatar
Awesome to see that you go it all sorted on your own.
And saved a hell of a lot of $$$$ in the process as well.
Old 23-08-2012, 03:17 PM   #35
poppa smurf
please explain what I did or possibly said to you to deserve that criticism?????
I repair, build and maintain a lot of my machinery and equipment here and am well known in the district for my ability to repair and maintain other peoples machinery as well
I'm not flash on electronics.....thats a field left to the experts.....but if it's mechanical then I don't have a problem
I dont understand the willingness of some people to derive some form of pleasure from degrading another person on forums with absolutely no reason
it is not done out in the real world so why bring it in here?
please refrain from doing this in the future or if you cant then please simply bypass my threads.......totally unnecessary
Old 23-08-2012, 03:18 PM   #36
poppa smurf
thanks mate.....very pleased that I found the problem......the thing has actually had very little use
always a good feeling when a problem is solved "in house"
Old 23-08-2012, 04:36 PM   #37
blueoval
Critical Thinker
blueoval's Avatar
great work PS. Good on ya for having a go and saving yourself thousands in the mean time.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2012, 05:41 PM   #38
ea90gl
ea90gl's Avatar
Tech may have thought old machine + failed + some excuse + I bet this guy won't have a crack = remove/replace job which will earn him a lot more than trying to repair it. Wrong in many aspects but many tradies try to pull this trick. As for the mice issue, you may want to check the indoor unit by removing the front facia (should just be clips and screws) since mice can set up shop around the evaporator coil inside the actual head unit (they search for warmth). Seen it many times, also discovered a fried one across the internal printed circuit board which obviously killed the unit. They get in either via the roof or up the pipework/wires which are connected to the outdoor unit. Expanda foam works wonders or even some sort of sillicone to block up any openings. Amazing how mice can get in the tiniest of gaps so if you do plan to seal them up do it very well
ea90gl is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2012, 06:05 PM   #39
poppa smurf
thanks fellas.......I had the entire front of the unit in pieces, probably wouldn't have gone as far as i did if it wasn't for encouragement from here and the thought of nothing ventured nothing gained
I couldn't see where the little bugger got in but I will take a sheet of iron off the roof and have a good look around on the weekend
once again thanks for the encouragement and the words of support
Old 23-08-2012, 06:25 PM   #40
FGII-XR6
FGII-XR6's Avatar
hyere is a generic ac controll module to overcome these types of dramas
http://www.ebay.com.au/itm/Air-Condi...item416913cada
[SIGPIC][/SIGPIC]
Rides:
Old 23-08-2012, 06:44 PM   #41
NeillNZ
NeillNZ's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has contributed a number of great technical articles for people with X Series cars.
Awesome result. I love these stories. It's like cheating the "throw away" system.
Thoroughly recommend the heat-shrink idea. You can use a heat gun to shrink it, or if you are careful a small gas torch. Electrical wholesalers and even Jaycar have it.
My dream car/build: http://www.fordforums.com.au/showthread.php?t=11282132
NeillNZ is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2012, 06:44 PM   #42
poppa smurf
is that what that board is.......a pcb module......tricky little bugger!
Old 23-08-2012, 07:01 PM   #43
ea90gl
ea90gl's Avatar
So your issue was in the indoor unit, I assumed it was in the outdoor unit. I would also check the outdoor unit (pretty easy to remove covers) seeing as you might be in the fix it mood - hopefully there are no nasty surprises. I'm sure you know to isolate any power to unit while you get in there and have a look
Old 23-08-2012, 07:23 PM   #44
poppa smurf
yes mate, inside head unit....the outdoor unit was "mouse proofed" about 4 years ago by a refrigeration mechanic who used to service the whole unit once a year
he and his wife split up and he no longer runs the business, worse luck
the isolation switch is right beside the outdoor unit, I also shut the fuse off....our whole house has just been upgraded to the latest earth leakage protection circuits as well
had it done when I put the solar on ......but I might just have a squizz "in case"
not hard to do, it's only four screws
wife reports the unit is working as good as new.......she's happy....so the world is at ease.....no nagging .....yet!!!!
I've still got a heap of work to do before I call it a night.....thats the joy of running your own business I guess.....cant complain to the boss
Old 23-08-2012, 07:54 PM   #45
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
The little copper coil thingy looks like an inductor in the photo
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 23-08-2012, 08:52 PM   #46
GREGL
Win,win,win. nothing like a bit of nouse and good old logic to solve what some say is buggered. Nice one Poppa smurf!
GREGL is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2012, 09:08 PM   #47
Ford17
Ford17's Avatar
Glad it worked out in well for you in the end.
I was facing a similar problem with a similar vintage unit last summer.
It was the exact same story as Jastel's:
Originally Posted by Jastel
Had 3yo a/c unit ruined because a gecko walked across it and fried himself. Circuit board cost more than new unit. Lucky a mate found one out of a similar unit that was good.
He said the manufacturers are not interested in "critter proofing" the systems, just replace if under warranty.
Luckily one of those 1 or 3 or 5 amp fuses (tubular shape, like the old car ones) got it back up and running. Otherwise it would have meant a whole new unit.
Interestingly/strangely, the advice given to me by the electrician was to put moth balls into the head unit to deter the geckos/critters.
Ford17 is online now   Reply With Quote Multi-Quote with this Post
Old 24-08-2012, 12:58 AM   #48
SPArKy_Dave
Too many Fords........ :)
SPArKy_Dave's Avatar
I think he was referring to the 30yr old Evap cooler you have in the shed?
ie, it's the Falcon 500 of A/C units - it ain't real pretty or refined, but yet it's proved more reliable than the newer house A/C.
edit - read it again, and I dunno now....... guess it could have been a personal dig?
In any case, I'm jealous of the A/C in the shed........ I can only dream of such luxuries.
and +1 for the 5 minute fix... they're the best sort.
Reminds me of the time I increased the power of my EL wags, by 25% in 10 mins... (silicone on the MAF hotwire. )
Current Projects
97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY
93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal.
95 XG ute - awaiting a head gasket...... grrrrr.
74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto.
XB Coupe and Van TV Ad
you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it
SPArKy_Dave is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2012, 10:47 AM   #49
poppa smurf
ah! the big old swampy in the shed, mate it's a horse........came off a bread factories roof
she stands about 8 feet high and probably 4 feet wide......no ducts (Occ health and safety had kittens when they seen it
but because I work alone with no-one allowed in the shed, because of insurance involving large machines, they passed it
the old girl just pokes her big nose through an inlet cut into the wall of the shed.....I can put my hand in and touch the drum fan
the big bugger turns so slow that it just flicks the hand out of the way....but she nearly blows you down if you stand in front of her at half throttle
brings the shed temp down by around 10 - 20 degrees on a 35+ day
I have nothing in the shed to warm the place up yet, may have to look into a wood burner......gets a bit chilly out there at times
as for the dig well I'm over it......busy time of year, I don't finish sometimes until around 2 in the mornings and start my deliveries at about 7am so it's a long day, I had a particularly bad day so I may have been a bit short
normally wouldn't bother me
ah! so mr inductor is his name.....I just figured that he didn't look to be harmed....just lost his soft cover.....I put a bit of electrical tape over him just to preserve his modesty
I have yet to pull it to pieces again to solder and heat shrink the joints but I will on the weekend...as long as the outlaws leave me alone
I'm more used to working on 2 ton 100 year old equipment than this new fangled computer controlled stuff
Old 24-08-2012, 11:36 AM   #50
TUF_302
The Vengeful One
TUF_302's Avatar
My parents daikin system died after 15 years, to much to fix or replace, they have gone back to a wood heater
TUF_302 is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2012, 06:34 PM   #51
bingoTE50
Steve
bingoTE50's Avatar
It is the thermostat PCB by the looks .. Printed Circuit Board.
Probably made by Leasam controls .
what does you wall thermostat look like ? Photo if possible. I owned a wholesale outlet in Sydney and sold all air conditioning equipment. I might be able to help if you cannot repair it.
Have a look at this site : they will have a retrofit replacement that will require a re-wire of a new wall thermostat , indoor PCB , and inter connecting ( possibly ) to the outdoor unit. Give Air Diffusion Agencies a ring if need a new controller , Bill Threadgold is the owner . They have @ four branches and are a distributor of air con units .They should be able to recommend a good contractor if your repair does not work.
http://actroncontrols.com/au/technicalData.htm ( controllers)
www.airdiffusion.com.au
Steve
Currently no Fords . 2005 Statesman International 5.7, Mazda 2 and a Hilux.
Former Fords: 2010 Ford Escape 2007 BF11 GT, TE50 Series 1 ,AU V8 One Tonner ,EL Falcon Wagon, ED Fairmont , EB Falcon Series 1. Mk 2 Cortina
Company Fords : 3 BA Falcons , EB 11 Falcon Wagon , Ford F350 351 V8.
bingoTE50 is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2012, 06:37 PM   #52
bingoTE50
Steve
bingoTE50's Avatar
http://www.airdiffusion.com.au/units/actron_access.htm
Yep they distribute the controllers.
Old 25-08-2012, 02:57 AM   #53
nuthin' fancy
Lyminge, Shepway, Kent
nuthin' fancy's Avatar
Originally Posted by |||
oh man i really thought this thread was about something else
Will I get in trouble if I say I thought it was going to be a thread about Michael Jackson?
nuthin' fancy is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2012, 09:52 AM   #54
poppa smurf
Steve
thanks mate but i don't have a wall thermostat it seems to be all "internally" controlled
I have the remote which is used to set the temp but nothing else
I soldered the joints, had to put a piece in as the mice didn't leave enough length, I also heat shrunk the joints so in theory all should be fine
my wife has been using it every night since with no dramas so i can only assume all is fixed
after mentioning my system to others and saying how mice killed it I am
surprised at how many others have had the same thing happen
all systems chucked out.......makes me wonder just how many were actually repairable
but I guess the techies have "X" amount of time for each callout and could not stay too long
never mind my outcome appears to be fine.........I will chuck a heap of mothballs around the ceiling near the head unit.....that should deter Mickey and Minnie for a while
