Old 29-09-2015, 10:05 AM   #31
Ozigoo
Default Re: Cost of Fluids - alternatives?
Anyone have a spec on the best coolant?
Just ran my Mondy into a kangaroo and had to change the radiator etc...=/
Want to put the best coolant / Ford spec in... cheers
2008 Mondeo MA TDCi 6 speed Aisin Auto
Ozigoo is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2015, 03:05 PM   #32
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
Ford Spec WSS-M97B44–D, 50% concentrate, 8.14L including heater (so totally dry system).
Ford Part number R152C5L which is a 5 litre container..
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2015, 02:19 PM   #33
rondeo
Penrite LDAS synthetic about $30 litre at Repco for steering.
Brake fluid is Dot 4. Should be the same if it is Dot 4?
Personally I don't change the brake fluid, just check with a moisture meter
every year. My Falcon went ten years without a change, no problems.
rondeo is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2015, 01:56 PM   #34
ope126
ope126's Avatar
Originally Posted by ope126 View Post
Vacuum out the old (flush) and fill with new. Start car, cycle wheels left an right a few times to pump through the system; then repeat...about 5 or 6 times!
Sure that is not the most efficient way, but I did not want to unbolt fluid reservoirs and hose's and have fluid go every where.
I did a search on YouTube and found the above, worked fine!
Here is a link to a Volvo - same parts and same procedure; https://www.youtube.com/watch?v=Op6vqOlutTE
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please!
ope126 is offline   Reply With Quote Multi-Quote with this Post
