#31 | ||
With all the time and money you are going to have to spend you would be better off going out and buying a new trailer and selling the old one to somebody with a truck!
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
#32 | ||
FG XR6T trayback
You could replace the drawbar and make a goose-neck one, with 150mm drop.
Haven't got a photo, but that's what mine has. |
#33 | ||
3..2..1..
Trailer mob near work quoted me $600 to build me a ute tub trailer, if I supplied the tub. Il price up what this one will cost to get it to what I want and work out which way to go I think.
#34 | ||
FG XR6 Tray back
#35 | ||
3..2..1..
Lol, what does a canopy weigh?
#36 | ||
BF XR8 Ute
![]() Join Date: Jun 2013
Could also fit a different tow ball tong, something that brings the ball up higher, with out compromising its loud capacity.Cheers Geoff.
Cheers Geoff _____________ HIS 2006 BF MKII XR8 Ute,Shockwave Blue. HERS Kia Picanto Signal Red Past Rides:- XD Panel Van,XE Panel van,XF Wagon,ED Wagon,BA Fairmont,LX Focus Greetings Earthlings. |
#37 | |||
FG XR6 Tray back
#38 | |||
I was borderline with towball download anyway so it was more peace of mind for me. Someone mentioned reversing the hitch to the underside of the drawbar, a big no to that one legally I think you will find |
#39 | ||
When I had a ute tub trailer I had a tow ball with a tall base. It was probably about 50mm taller than a standard ball. If you were nearby you could have it.
So if you got one of them and changed the hitch to the bottom of the draw bar you would gain around 125mm with very little cost. No buying a new drop axle or springs. Just be careful if you lower the tub itself too much as you can take the front corner out when you go through a gutter into a driveway or something. |
#40 | ||
3..2..1..
Yeah I think I'm gonna grab one of the adjustable tow hitches, for a little over $100 it at least gets it usable until I decide if I modify this one, or just get a new frame built to my specs.
#41 | ||
#42 | ||
3..2..1..
Next time one comes through work il try and remember to chuck it on the scales
#43 | ||
#44 | ||
Missing a sock...
![]() ![]() Join Date: Mar 2012
As suggested lowering blocks and longer "u" bolts might be the easiest and most convenient option - dunno if it's legal though. Definitely not legal on a car/ute.
Seems your trailer is rather heavy duty with having air shocks on it, like you said - way over engineered. Can you do away with the air shocks at all or fit just standard shocks? or better still do away with shocks at all? Does it have it's own braking system? As said before, non braking system reduces your tow capacity to around 750kg - do you need it? Cheers! Edit: I've got a 1 tonne ute and I've had the front tyres swimming at times, we all fracture the rules every now and then!
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
#45 | ||
How about trying something like this?
#46 | ||
Taller towballs tend to snap off.
Forget about fiddling with the trailer as there isn't much clearance underneath and just change your towbar tongue to a stepped up one. |
#47 | |||
Banana
You'll need a whole new towbar with a 50mm box opening to fit that hitch into.
2024 Ford Ranger Wildtrak V6 w/PP 2012 WK2 Jeep Grand Cherokee Overland CRD |
#48 | ||
#49 | |||
3..2..1..
But your right, the adjustable height one I bought didn't fit. But I did find a 40mm one on eBay that gave a 100mm drop or 70mm lift, depending which way you use it,, so I bought that. Made enough of a difference that it stopped it looking like the drawbar was dragging on the ground but still needs to be better. But my fairlane copped it in the hail last week so I'm looking at my options now. May just replace it. |
#50 | |||
3..2..1..
#51 | |||
#52 | ||
3..2..1..
Yeah you would hope that trailer has very good brakes.
#53 | ||
The cheapest, best option IMO is to lower the coupling on ya draw bar on the trailer. Either weld the plate underneath or fit a RHS spacer and lower it a bit more if needed. A bit of plate and an hr with a grinder and welder tops and she will be at the right height. You could even buy a smaller basic coupling as it looks like there is no brakes fitted anyway.
#54 | ||
Unintended Perfectionist
The one I built was higher than yours, but I used the ute chassis and springs, just made a drawbar for it.
The guy that bought it wanted it for an off road trailer behind a 4WD, so it was perfect for him.
BA-FG parts for sale. http://fordforums.com.au/showthread.php?t=11411117 http://s1092.photobucket.com/user/my...?sort=3&page=1 The XR re-erection in the works http://www.fordforums.com.au/showthread.php?t=11386452 |
#55 | ||
Pull a leaf or 3 out of each pack
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
