03-06-2005, 02:51 PM | #31 | ||
Two > One
Good work mate.
I love the hidden cooler!!!
03-06-2005, 03:05 PM | #32 | ||
Soul baby
I sounds good, but some of it sounds and looks a bit dodgy...
engine fires, TB injectors, 2inch piping?????? I hope it holds together for you Sunny...
People don't kill people, lawn mowers kill people. |
03-06-2005, 03:18 PM | #33 | ||
Last warning
2inch piping is pretty normal, the turbo outlet is only 2", so there is no need for bigger.
TB injectors, just a simple way to add fuel rather then aftermarket ECU, they're triggered at a certain point in the rev range (usually when boost hits)
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
03-06-2005, 03:18 PM | #34 | ||
Former E-Series Member
She'll be right mate.
03-06-2005, 03:22 PM | #35 | |||
TB injectors is part of/controlled by the Microfueler. Microfueler's were used by AVO when the first EA turbo kits came out, along with many other aftermarket turbo kits before the engine management fad began. You can adjust the duration of the spray and when they come on, in my case in comes on at 0PSI. 2" piping is to reduce the lag. When you have a small turbo etc. I'm told it's better to go the smaller piping to reduce the lag, and the outlet on the compressor cover is 2". I called up the guy and clarified this. Happy? Sundeep |
03-06-2005, 03:24 PM | #36 | |||
windsor user
03-06-2005, 03:55 PM | #37 | |||
03-06-2005, 04:00 PM | #38 | ||
hibernating
sounds pretty mad... i love the vl turbo style flutter! hehe. seems to be coming along well
03-06-2005, 04:30 PM | #39 | ||
Well done on getting it all up and running....
03-06-2005, 07:44 PM | #40 | ||
just on the piping thing, originally I said he should turn the compressor housing around but then after looking in the engine bay, there really isn't any room. The turbo sits fairly low in the bay and if you had the piping down there it would have to go into a sharp 90deg bend to clear the block and face the battery box. It would have looked better but probably wouldn't have flowed as well due to the bend. And I'd rather take 2" piping anyday over 2.5". I used 2.5" and it was a nightmare. You don't realise how big it is till you have to cut holes everywhere. Dan's EB had 2" on the turbo side and that was fine. For sunny's setup 2" is ample.
04-06-2005, 05:32 AM | #41 | ||
Sunny - you won't beable to just slot ef axles into your diff. ef axles will be 28 spline, your diff will have a 25 spline centre. so basically it will never work. you'd need to gram an ed diff (or eb2) as long as it has a 28 spline centre to beable to use the ef axles.
just take it to a diff shopand say ' i want a 4 pin 28 pline lsd centre with 3.9 gears please.
04-06-2005, 08:31 AM | #42 | ||
eec tweaker
OT, but i saw you cruising the city last (friday) night Sunny... Elizabeth st, nfi what time. Looking & sounding good mate! And was that Kenaz' old car following?
Jase |
04-06-2005, 08:56 AM | #43 | ||||
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
04-06-2005, 11:00 AM | #44 | ||
eec tweaker
I was wondering if had been finished! i had a few drinks by that stage though...
05-06-2005, 06:18 PM | #45 | ||
Yeah too many drinks Jase lol.
Just wondering here, the car has been inconsistent fuelling and performance wise since all the piping was installed. Sometimes going well, at other times going sluggish, lagging and flatspotting. I reckon a majority of it is caused by the un-tuned state of it all, and a dodgy TPS. Now I was also wondering if the distance between the factory fuel reg and the Malpassi could cause it, as the distance between the 2 is about 1.5 metre of fuel hose. I'm 99% sure it would, because on boost the pressure has to build to 30PSI with only a trickle of fuel probably returning from the rail. Tomorrow hopefully I will change the manifold loom and fix the TPS's, then plumb up the extra injectors and Malpassi differently. I think I have it all sussed out. The Malpassi also makes strange hissing and whining noises on startup which go away mysteriously each time the engine flatspots. So I'm thinking there's definitely a pressure problem there. Anyways, opinions appreciated! Sundeep |
05-06-2005, 06:32 PM | #46 | ||
ok here's another vid, this one has a MAD flutter in it, just excuse sunny talking about TPS's and changing gears manually:P
http://users.tpg.com.au/gillau/vide.3gp |
05-06-2005, 06:34 PM | #47 | ||
LOL! That's sick, I haven't seen that 1! Dial up friendly too!
That video is rated M (L); And is suitable for mature audiences. It contains course language. Sundeep |
05-06-2005, 06:35 PM | #48 | |||
hehe... sweet!
05-06-2005, 07:06 PM | #49 | |||
own the road
sounds sic! hehe
T3 TE50 #146 Quote:
05-06-2005, 07:08 PM | #50 | ||
eec tweaker
i still dont get how you can run two fuel pressure regs on one fuel rail and end up with a rise in pressure at the rail. wouldnt you have to remove the stock one?
what about your pump? maybe a chat to a performance shop would help? dynomotive or someone like that? and who was following you anywya?? |
05-06-2005, 07:32 PM | #51 | ||
Whe the aftermarket regulator reaches a pressure that is above the factory reg's pressure, the factory regulator will constantly stay open trying to relieve the extra pressure, get it?
The pump was changed on the Bundoora cruise, and it has had the same problem on both pumps. It has to be something in the way I have connected the regulators up. Sundeep |
05-06-2005, 07:36 PM | #52 | ||
The first reg will bleed pressure off but the second one will hold pressure.
05-06-2005, 07:40 PM | #53 | ||
fully *** turboooo
nice sunny, nice. i was jus getting some work done before heathcote
... hehehe my goal in life is to beat dan by a second or more on my way there as well
AU1 Forte 178.6rwkw @ 5 psi Highflowed T03, Intercooled Full comp insurance :nutsycuck
05-06-2005, 07:41 PM | #54 | ||
HAHA!!!
/cue laughing you made at bogan in V8 VN. Your going down steve!
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
05-06-2005, 08:32 PM | #55 | |||
V8 Turbo Hoon
05-06-2005, 08:32 PM | #56 | ||
Is your fuel pressure always at about 30psi? thats below what they should be as standard.
05-06-2005, 09:22 PM | #57 | ||
eec tweaker
ok.. so the reg thing makes sense...
maybe the stock pump isnt enough to keep up with the demand of higher flow through the stock injectors PLUS two additional ones? weird noises doesnt sound right though. oh well, good luck... |
08-06-2005, 03:44 PM | #58 | ||
that vl type noise is caused by the air going back to the turbos getting sliced by the blades i would get a bov asap.
13-06-2005, 12:04 PM | #59 | ||
_ObLiViOuS_
hey guys it seems like you know what ur talkin about and i know about jack all so i was wondering if u could help me out with a little advice. I've got my parents 04 fiesta and i know its gutless compared to all ur cars but i wanted to add a hotdog or some kind of exhaust to it so it sounds a little more like a mans car. What do you suggest?? Would it help my cause at all? thanx heaps if u can give me a hand..
13-06-2005, 05:14 PM | #60 | ||
Maybe try asking in a different thread... ;)
