#31 | |||
The only way that 1 wheel in a straight line can light up is if a) that wheel is in oil b) diff is ed. |
#32 | ||
Back on the road
Moya, you need to recheck your information.
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#33 | |||
BIG LUKE
EXAMPLE Jack up the back of a car.take 1 wheel off and put the car down on an axle stand. (1 tyre on the ground and the other in the air) Now you can start the car, put it in drive and hit the gas and the car won't move. why??? Beause 1 wheel is spinning, the diff centre pushes the power to that wheel.(Note: 1 wheel has traction, the other dosent) This is an open wheel diff. The diff will favour the wheel with less traction. Do the same to a car fitted with an LSD and your garage door will look pretty bad. The only way to make an LSD single wheel is to provide enough traction to one wheel. SO, your LSD centre is set up to 80ft/lbs. That means it requires 80ft/lbs of torque to slip the centre. So if you put a skinny 185/60/15 retread on 1 back wheel and a 15" wide slick on the other, and drop the clutch only 1 wheel will spin as you have provided enough traction on 1 wheel to exceed the slip rating of your diff centre. However, the car will still move forward as it is only limited slip, not complete slip like an open wheel. When you are turning, the only reason the centre slips is because the tyres provide enough traction to slip the centre. If you give your diff a higher load rating, it may "hop" when you turn.(I know mine does ![]() An LSD is not the same as a SOLID or LOCK diff. As the name says an LSD provides limited slip, so when you are cornering the inside wheel dosen't "hop". With a Solid Or LOCK diff the inside wheel must "HOP" as the 2 axles are locked together and both wheels have to spin the same amount. LUKE
I am like 7/11, I am not always doing business, but I am always open! XR6BBQ.......... Just when you thought I had given up!!!
#34 | ||
Falcon Owner
Hey its been ages since i replied as you can see on my previous post i wanted to know how quick my car would go down the quater ruffly. Unfortunatly i live in the ACT and we have to many greenies so we lost our drag way :( where are the closet drag strips to the ACT??
#35 | |||
TL40 Wagon?
#36 | ||
Falcon Owner
WSID?? whats that.....ps dont tease me
#37 | ||
Two > One
Western Scum(Sydney) International Dragway
#38 | ||
XB in parts...
www.wsid.com.au for more info.
#39 | |||
HSV, I just ate one
Jonbays.....
Now this is what i was talking about, add to the a manual gearbox something like a nice 5 speed, and shave upto 0.2 seconds off that 14.2 and u would be on about 14 flat lighten the car a little a should be able to pull 13.9's.... my final goal to reach 13.9 or better ![]() |
#40 | |||
thats my goal to ,but i seem to be going backwards at the moment. would be great to see an au i6 in the 13's i reckon hamo's would do it with a 2.0 60 footer. |
#41 | |||
AU FAIRLAINE GHIA TICKFORD I6, KINGS SL/KYB ALL ROUND, RED BACK EXHAUST, G220 RIMS |
#42 | ||
Smile
I dont see why 13.9's cant be the new standard ? Just need to take advantage of what youve got.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#43 | |||
Custom user title
An open center diff does not put all its power through one wheel dont know how u came up with that one pull it apart and look at the mechanicals and it should be pretty straight foward . Get a locker and snap an axel, it will fry the tire that has the good axel and u will hardly be able to take of . THat is driving one wheel an open wheel diff defently has bags more traction than that. An open wheeler diff if the suspension is set up corectly can be made to spin 2. I ran my car with an open center 2 pin dif and it hooked 2 up every time on the strip. BUT I 100 percent agrea a decent lsd is defently going to be alot beter than an open center as the 4 pin open center diffs loves one leggers |
#44 | ||
XF Ghia. All snorted out
Open wheel diffs are a mechanical torque splitter, they will work ok providing the tractive effort is equal to both wheels/axles. Drive/torque is lost to the wheel with the least traction, an lsd/locker removes this from the equation. Injected 250 i agree with you on this one.
