Old 30-11-2005, 07:54 AM   #31
Stav
Smile
Stav's Avatar
Originally Posted by galapogos01
ok, sounds like im going to ring TCI then.
im guessing $200-$300 is about normal for a fitting price? given its normally $100ish for a service, and that doesnt involve dropping the trans!
TCE ones go for ~$400 iirc.
Dont confuse TCI with TCE they are a different company.Also 220 was very lucky for me...Also be prepared to lose some responsiveness down low.
5000 stall speed would be drags only application.Otherwise it will never lockup in daily driving
Old 30-11-2005, 09:44 AM   #32
Casper
Contributing Member
Casper's Avatar
Originally Posted by slamd ef wagon
i spoke to 2 of adelaides best trans places mv automatics and alltorque converters and they both said the same u cant gor past 2300 2400rpm other wise the limp home mode becomes a problem
Then all the cars with the JMM3000 stall... and useless's TCI.. are freaks?
Seriously, I've had a number of people from the forums in my car and they can say that, in normal driving, limp home is not an issue. The only time it happens is due to massive heat buildup (such as stalling it to 3000+rpm and holding it there). As soon as the heat is cleared (airflow through the radiator) it goes back to normal operations.
Older, wiser, poorer.
Old 30-11-2005, 01:24 PM   #33
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Mine flash stalls to 2800 and has only gone into LHM once.
i'm running a 5000 TCI converter and i had a custom ground cam made by crow cams. though my cam is for a turbo appliction.
Why such a big stall on a turbo car? Turbo's don't need to rev to get power, a 2500stall would suit the car a lot better, and you can still drive it on the street.
It will still lockup fine, as long as you bring the RPM down enough for the TCC to engage, and the convertor is fitted with the TCC. The convertor in my EF now will still lock up at 75kmh in 4th if it desires....
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2005, 10:23 PM   #34
24CIT
back to the shop........
24CIT's Avatar
Post
Originally Posted by dansedgli
5000?? Thats a bit high isnt it?
I had a 2500 TCE one in my Turbo AU. It worked fairly well.
the size stal that i will be running was recomened by the company that built my gearbox. it is a bit high but the car isn't being built to be a daily driver.
Bow to the turbo
24CIT is offline   Reply With Quote Multi-Quote with this Post
