Old 04-04-2005, 06:02 PM   #31
dansedgli
dansedgli's Avatar
The wastegate venting to the atmosphere wont affect it boosting or not. I reckon its your timing being advanced so much.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2005, 06:37 PM   #32
sphell
sphell's Avatar
im pretty sure i turned the timing back to the IGN mark in the end. cause i was able to fit that water hose back on in the end so it can't be advanced too much. anyway, im goin round there in about 30mins to check it all out. hopefully we can get it running sweet tonight.
Old 04-04-2005, 06:41 PM   #33
old_mate
Smash the Boost
old_mate's Avatar
One thing I have noticed, you guys have ditched the EA/EB/ED manifold for the BBM, are you going to retain this manifold when a intercooler is installed?
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2005, 06:42 PM   #34
needfordspeed
I don't think he will, I think they just wanted to get it "boostin" by last night :P
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2005, 06:46 PM   #35
Psycho Chicken
Psycho Chicken's Avatar
Splice the TPS wires together, not sure if all the colours match but just line the pins up and join them.
Looks the goods though.
Old 04-04-2005, 06:54 PM   #36
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
Top effort for one days work......Good to see your not mucking around sunny!
Current rides - 2013 FPV GT-E MK2 & 2010 FPV F6-E
Tuned by Michael J's & Son.
EASPRINT is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2005, 07:03 PM   #37
Kenaz
Kenaz's Avatar
Are you guys coming to the meet?
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2005, 11:11 PM   #38
InitialD
Low and Loud
InitialD's Avatar
Sunny, The two sets of TPS wires can be merged together, thats what I did on my car to run the 91DA TPS.
The auto has the Blue TPS wires with colour lines...
AUTO TPS ---------------- ECU TPS
Blue with Green Orange
Blue with Orange Green
Blue with Black (i think) Black
hope this was some help
BTW did you attack it with a Timing light?
Old 04-04-2005, 11:12 PM   #39
LG
LG's Avatar
Top effort guys, hope you get it sorted!!
Old 05-04-2005, 12:19 AM   #40
Sundeep
Sundeep's Avatar
Yeah if/when a cooler is fitted it will be ED manifold stylez.
Tonight after the meet (which was crap) Doug and Dan came round and helped get it all going a bit better. Doug mainly did all the work, he chucked in the rising rate reg. and a extra injector, and wired up the hobbs switch for the extra injector. Then we took it for a spin to get more juice and along the way Doug kept fiddling with the hobbs switch until we got some decent boost happening.
Once the hoobs switch was set we got out on the highway and gave it some stick. Pulled pretty hard from about 60. You can hear the turbo it's like sick.
Anything under 60 or around 2700RPM the car runs like a bag. At full, half or low throttle it accelerates at the same rate. Our guess is that the rising rate reg. is flooding it until it hits boost. Won't even do a standy! :
Anyways, got home and found the wiring loom was melting due to a glowing dump pipe and the part of the turbo that's in front of it (n00b) so we called it a day :
Any ideas on what to do about the low RPM flooding? :
ID I kinda don't get your post about the TPS lol :togo:
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2005, 12:27 AM   #41
sphell
sphell's Avatar
ok update after tonight. Today Sunny got the exhaust mated up to the turbo dump pipe for $25...not bad eh! He also traced the 'running sh*t' problem to a pin being pulled out of the number 4 injector plug. Tonight we pushed it back in and it ran heaps better. Then we set the timing again. After that the car idled fine. We hooked up the rising rate fuel reg, boost gauge and also rigged up an extra injector into the throttle body and ran that off a Hobbs pressure switch. Then rigged up a light which we stuck to the windscreen for tuning purposes so we could adjust when the pressure switch was coming on. Tuned it so the extra injector kicks in at 3psi. The car runs 5psi although there is a 6psi spring in the wastegate. Dan said once the exhaust is freed up it will get the extra pound of boost. After a bit of driving round we were suprised to see the turbine side of the turbo was glowing a bit red! Overall it goes alright for a few hrs tuning, just runs a bit rich down low.
Old 05-04-2005, 12:28 AM   #42
John_LS1
its looking good sunny. all you need to do with the TPS is do what Rob said. put the plugs next to each other and match each wire to the same position then merge into the newer plug. i did it a couple of days ago when i converted my EA to MPFI. id get a pic but its all taped up now.
Old 05-04-2005, 12:30 AM   #43
sphell
sphell's Avatar
Sundeep
you probably would have tried harder if you weren't trying to do it in your garage with a wall 2ft infront of you!
Old 05-04-2005, 04:48 PM   #44
LUXO_8
windsor user
lmao!~!!
glad to hear its running good now
Old 05-04-2005, 10:39 PM   #45
Sundeep
Sundeep's Avatar
In other news, cops are now patrolling my area lol. I rarely see them around here...but..ahh...I think there might have been some noise and hooning complaints over the weekend and last night : e _
Sundeep
Old 05-04-2005, 10:42 PM   #46
Julza
871 Productions Filmmaker
Julza's Avatar
Sundeep
nah mate, they've just come to check out your turbo motor lol :
nice work btw sundeep, can't wait to see the finished product
Julza
Edge SY MKII Territory TS AWD
Blueprint AUIII Falcon XR8 Ute
Lightning Strike BA MKII Falcon XR6T
http://www.youtube.com/871productions
Julza is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2005, 10:46 PM   #47
needfordspeed
Sundeep
Ahhhh funny ****, i'm gonna turn my scanner on and see what's going on :P
Old 05-04-2005, 10:57 PM   #48
Psycho Chicken
Probably due to all those hoons towing boot lids around.
Old 05-04-2005, 11:25 PM   #49
Walkinshaw
Two > One
Walkinshaw's Avatar
hehehe sounds similar to the stuff we did arround work, replace boot lid with butchers trays.
Old 06-04-2005, 12:03 AM   #50
Smoked
Burnin Rubber
Smoked's Avatar
Good work Sunny, got the car up and going pretty quick. When im in the area again, hopefully this weekend if i go and see Ryan, any chance of popping in to have a look see?
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
