06-01-2005, 06:40 PM | #31 | ||
Viper FG XR6 Turbo
Athlon XPs downt shut down till something like 85deg, so it shouldnt be a prob
06-01-2005, 06:46 PM | #32 | ||
OK ..coolies .......
Daughter has about a million msn pm's going atm & Im downloading a file & have this opened & winamp is playing ...... Temp reads 37oC & 50oC ......... |
06-01-2005, 06:51 PM | #33 | ||
Viper FG XR6 Turbo
to test the stability of your pc download prime95, it gives ur pc a hard time
http://www.mersenne.org/prime.htm |
06-01-2005, 07:03 PM | #34 | ||||
No longer driving a Ford.
Yeah, I don't think it's a heat problem...
(BTW, my AMD XP1800 @ 1815MHz is currently sitting on 36c/96f, and under load it doesn't rise above 55c, bloody cool for an Athlon system, go AMD lol :1syellow1) Quote:
When you say you "put my hand over the power source last night(well this morning) on Martins suggestions it cut out again", where exactly did you put your hand? Over the fan at the back near where the power cord plugs in, or somewhere else?
06-01-2005, 07:33 PM | #35 | ||
SiX_iN_a_RoW
My guess is its a cheap case with generic PSU ( Omni, X-sonic, vtech etc )
You will most likely find the PSU is a little dodgey, we get this alot at work. Usually it gets to the point where the caps swell and it will just not turn on any longer. it MAY be heat related but I doubt that very much. If you ar eonly getting LED's and no fans, its the PSU
Oh yeah, my G6ET eats diff bushes for breakfast! |
06-01-2005, 07:48 PM | #36 | ||||
Once you've installed it, it will automatically run, go to its window, click "Options", then click "Torture test...". Finally click ok, and leave it to do it's thing, personally I'd let it run for a couple of hours. If it runs for a couple of hours without showing an error, click test, then stop, then click test, followed by exit. If it reports errors, let us know. Even if it doesn't report errors, please let us know. Good luck.
06-01-2005, 07:53 PM | #37 | ||||
06-01-2005, 08:09 PM | #38 | ||
Beware of mood swings!
Location: Western 'burbs, put your bullet proof vests on!
After reading everything I think it's a PSU problem. I change mine every six months or so (or at least give it a good clean out).
I'm running an AMD 2800+ with one extraction fan, PSU fan and CPU fan and my CPU is sitting on 36 degrees. Not too bad for a basic AMD set up. If MN can have multiple MSN windows open, be using Winamp and whatever else was running, she was getting a decent temperature. I went through a couple of PSU's before I got my PC stable, just had to spend a few more dollars. It happens to the best of us. ;)
1993 EBII GLi Auto, 4.0L MPI rebuilt by JMM, JMM Dev1 kit, JMM Hi Flow Cat, still to hit the quarter mile. :Up_to_som
Dyno Sheet-14/07/05 |
06-01-2005, 08:43 PM | #39 | |||
So far its been going for over 2hrs now & not crashed ........ The weather is a lot cooler up here tonight as well & I have turned off the pedestal fan ....... The case its in is an Age of Digital Case .......... well thats what is on it .... When I had this thing done they used my DVD rom,CD burner & HDD from my old computer but everything else is about 6 months old ...... I really appreciate all this help guys |
06-01-2005, 08:56 PM | #40 | ||||
If it's run for that long without reporting a single error, that is a good sign, you could run it overnight to be sure, but most likely that rules out any problems with your CPU, RAM or some parts of your motherboard. I think the most suspect part is definately the PSU.
06-01-2005, 09:05 PM | #41 | ||
OK its downloading now ...... can I stay online when I run it .... or is it a thing to do when I go to bed ;)
06-01-2005, 09:10 PM | #42 | ||||
I think the best option would be to run it before you go to bed, if when you get up in the morning it's still running, and it isn't showing any errors, then we can rule out a few things. If however, you leave it running prime95s torture test when you go to bed and prime95 isn't on the screen when you get up, that's not exactly a great sign. Either way, try it, and see what happens, you're not going to do any damage with it.
06-01-2005, 09:59 PM | #43 | ||
Gotta hate links that dont work ... I have tried to get this thing 4 times ...... still no joy :(
Is it possible for someone to email this program to me ?>?????? |
06-01-2005, 10:03 PM | #44 | ||||
07-01-2005, 12:12 AM | #45 | ||
Looking for clues...
Mother Nature,
The motherboard of these PC's are very intricate. sometimes, when installing RAM chips, or Video cards, or whatever, whoever is pushing these card/chips can push hard enough to rupture the solder connections to the copper tracks on the boards. I've done this myself on my own PC, and it wouldn't start up, or would freeze when the temperature got right. Before going and buying a new board, I tried flexing the board the opposite direction, by gently wedging a non-conductive object between the bottom of the board and the case frame i.e. plastic or wooden such as half a peg!. It's been 18 months now, and I haven't had to buy a new motherboard! |
07-01-2005, 08:15 AM | #46 | ||
X-Series Club Moderator
It sounds like a dud power supply to me as well. The CPU fan always spins for a couple of seconds after it looses power so thats not the cause.
Shutting down for no reason is likely either a dud PSU, damaged RAM (fixed a PC once that was randomly re-booting and it turned out to be a damaged RAM chip), a faulty motherboard and less likely is bad thermal shutdown settings (don't laugh i've seen it before). Your PC may have adjustable thermal cutout points in the BIOS. To check hit 'Del' as your PC goes through the RAM check, or if that is all hidden from you just have a look at the screen that pops up and it should have a 'press F11 for setup' or something similar. Check what temp the cutout's are set to and enable warning tones as well. It might have the 'shutdown' temp set to 55 degrees and no warning tone! Unfortunatly if its not the temp cutout, only the PSU is cheap to fix... so I hope thats the problem. |
07-01-2005, 04:02 PM | #47 | ||
OK I have the stress test happening now ..... will let you all know how it goes ........
BTW ...... I was able to manually shut down the computer last night & have rebooted again without a hitch so far ...... No pedestal fans or anything & it is a warmish day here ........ Im wondering if it was the power settings in windows or if it just likes its new home now :P ..... It is still sitting on the new bench on its side & without covers ...... |
07-01-2005, 07:09 PM | #48 | ||
OK .... stress test has been going for 3hrs & 6 mins ....... there are no errors reported ..... :
The temp is running at Case 43oC CPU 52oC ... no external fans & at a reasonable heat today ........ Im hoping it was the power stuff that I changed last night to all of you who have tried to help me out Last edited by MotherNatureVer2; 07-01-2005 at 07:12 PM. |
07-01-2005, 07:15 PM | #49 | ||||
