Old 07-12-2006, 05:41 PM   #31
poolkeeper
Its Resonating!
poolkeeper's Avatar
Ive got little bits of pvc pipe in my intake (to connect things etc...)
I found they warp, get smaller and sometimes falls apart
Metal intake coming
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2006, 05:55 PM   #32
JoesAu
JoesAu's Avatar
yeah?? mine hasnt melted.
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2006, 06:18 PM   #33
StealthAu
I think most people saying it will melt or catch fire, are not talking from experience
Old 07-12-2006, 06:25 PM   #34
GTWHOA
Just cruisin
GTWHOA's Avatar
Good idea with the plumbing pipes I thought of doing it myself. I ended up just cutting most of the first section of intake pipe off, then removing the adapter thing that sits on the air box and put the bolts back in the holes. And then connected two short lengths or this tubing stuff (found it at work) with some silocone hose. All up $10
___________________
BA LTD 5.4
GTWHOA is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2006, 06:25 PM   #35
I6corp
Was V6corp
I6corp's Avatar
Just common sense?
Car: 99 AU I Forte Sedan
Colour: Blue
Engine Mods: K&N Pod in a XR8 Pod Box; Performace fuel pump; 2 1/2" Exhaust
Planned Engine Mods: ; Extractors; Tickford CAI; Twin Mufflers; Shift Kit; Hi-Stall; Cam; ECU Flash
Bling Mods: Tinted Windows; JVC CD/DVD HU
Planned Bling Mods: TS50 Front; High Series bonnet; Rebel Skirts and Rear Bar; SL Springs; Clear Side Indicators; Rear Spolier; Mags
I6corp is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2006, 06:36 PM   #36
HLC
Audi S3
what about ABS plastic tubing?
Old 07-12-2006, 07:15 PM   #37
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
we use a heat gun at work to bend the PVC we use, and it doesn't take much time or contact before it starts to get soft
'13 Territory TX Diesel RWD. The Family Bus
'08 Mitsubishi Pajero. The Off-road Machine
StAndArdAU is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2006, 07:21 PM   #38
EFFalcon
Last warning
EFFalcon's Avatar
i think you'll find you're wrong.
i had some PVC piping in my engine bay, it warped.
seems i'm not the only person whos had this happen either.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 07-12-2006, 07:22 PM   #39
StealthAu
If its fouling against something you'll have issues, but with enough clearance, it will be fine. So far I've heard people doing it with no issues, and only people who havn't saying there will be issues
Old 08-12-2006, 03:17 AM   #40
blackers10
blackers10's Avatar
there has to be A plastic pipe that is made of the same material as the stock item!
as the stock one is plastic.. what kind of plastic is it made of?
i like what DVL40L has done with his.. a bit more blue in the engine bay and a nice big pipe! and looks like it will probably stand up to a bit of heat/abuse..
Old 09-12-2006, 03:01 AM   #41
Sleeperau
Highway Taxi
Originally Posted by The Monty
But that costs money Kenny. This cost $24 so far, lol. If it melts, Ill just try a metal one then. I actualy get another exhaust on this arvo, so I might ask them how much. And the heat? Nah, shell be right mate. Now I just have to work out how to fit my Hi-clone.
Josh you are getting bored! go for the BA pipe intake set up in the Au workshop section. I do believe albeit with everything said metal throttle body pipes like my own get too hot.
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2006, 01:15 PM   #42
XR6Stu
ok, so on AUfalcon.com, it says to get the 90mm pipe for between the airbox and intake at the motor, what is the recommended piping to use... I want to have a go at this myself, but after this thread am VERY confused as to what I should use...
XR6Stu is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2006, 05:29 PM   #43
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Supercheap are now selling bent metal intake piping for like 20-30 bucks per peice. They have 180, 90, and 45 degree bends, and then just plain straight peices...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2006, 08:36 PM   #44
black ute
SII XR8
So has anybody burnt their hand in the clear air space around their existing intake? Or the throttlebody for that matter?
I know I haven't.
The hot air gun at the same temperature would burn holes through your hand.
90mm stormwater pipe and fittings on the other hand are the lowest quality plumbing products available...
80mm sewer class pipe and fittings are of much higher quality and should be much more durable, will cost a bit more however.
black ute is offline   Reply With Quote Multi-Quote with this Post
