Old 16-09-2011, 08:58 PM   #61
2 Sips
Default Re: Hidden functions of AU dash cluster...
when in diagnostic mode and the speedo 0.0 is on bottom line in section 4: HOW DO YOU ADJUST THE SPEEDO % DOWN.
2 Sips is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2011, 09:09 PM   #62
2 Sips
Thumbs up Re: Hidden functions of AU dash cluster...
when in D-Mode, and in section 4 - speedo on bottom line is 0.0 , HOW DO I ADJUST THE % DOWN.
Old 22-10-2011, 07:30 PM   #63
trobbins
I just tried this on AU2 auto wagon. I noticed a few discrepancies in the outputs from what is indicated by others as standard:
In 9, the bottom line is 0001, then 0011 with auto engaged.
In 11, the bottom line is 0000 (not 1111).
In 12, the top line has no '0'.
In 14, the bottom line is 0 (not 118).
In 15, the bottom line is 0 (not 255).
In 16, the bottom line is 2010 (not 112), and the top line is 99 (not 98).
In 18, the bottom line is --0-
trobbins is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2011, 08:25 PM   #64
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Can you make litres per hundred klm appear in the LCD display on the povvo
cluster?
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2015, 02:40 PM   #65
Rfordsfun
cant do it, to much beer is the key on just accessories ?
Rfordsfun is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2015, 06:25 PM   #66
Dauphin
Irregular member
Dauphin's Avatar
I'm pretty sure it's accessories on. I've had mine on for over a year now.
Old 02-03-2015, 11:16 AM   #67
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Yeah key on accessories or on.
It usually takes me 3 or 4 goes to get, and I have to use my watch to get the timing right.
Old 10-03-2015, 10:43 PM   #68
Nedd
g'day all
first post
just been reading the post on AU series instrument codes and noticed something that I am sure must have been picked up by now
step one mentions depressing then releasing the odo button 5 times in 10 seconds, ie: press/release 5 times
but the following step says to release button for 5 seconds after the previous instruction was ALSO to release this button
wondering if this might ne clarified?
cheers
Stevo
Nedd is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2015, 02:08 PM   #69
Mr Hardware
Yes, you're right Nedd. I've just always moved onto the 5 second step without hesitation and it's worked. I haven't waited 1+5 seconds for the 'two' releases.
Old 22-07-2017, 06:11 PM   #70
FRDKNG
Also I know this is old but for those still using this feature if you press the button for around 2-3 seconds you can go back a step rather than cycling through forwards only.
FRDKNG is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2018, 02:28 PM   #71
raysute
My AU ser.111 speedo is 12 k fast, its an ex police ute, I tried the inst. calibration mode, but cannot get it to work. I have repeatedly tried the instructions mentions above, any ideas?
Ray
raysute is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2018, 10:37 PM   #72
NCII40
XR6T BA 2002
NCII40's Avatar
Ray
Hey Ray
Whats your diff ratio ?
What is the size of your tires and wheels ?
What colour Speedo Cog do you have ?
Auto or Manual ?
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2018, 10:49 PM   #73
raysute
G'day NC1140
I worked it out! if I disconnected the dash completely, and then reconnected it the program button works. I now have a speedo that tells the truth. What I would like to know is what other changes where made to the falcon, when the vehicle was produced for the police dept. I know about the speedo and like it, what else on the Ute?
Ray
Old 08-02-2019, 03:29 PM   #74
Climaxxx
Stupid question, but does this work for the AU3 xr8?
Climaxxx is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2019, 10:27 PM   #75
CFOUR
The Destroyer
CFOUR's Avatar
yes, it does
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2019, 04:43 AM   #76
KRL-94
Can anyone confirm that diagnostic mode works on an option20 xr cluster?? Havent tried it myself yet. I should.
'99 AU Falcon S1 GLI factory manual in sparkling burgandy, 333xxx, NA + T BF barra conversion, FG TR6060 6spd manual, 3.9 lsd. Currently at 10psi. Power figure unkown at this time.
Project "White Knight"
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
http://www.fordforums.com.au/showthread.php?t=11447916
KRL-94 is offline   Reply With Quote Multi-Quote with this Post
