Old 23-04-2011, 09:47 PM   #61
Joe5619
Default Re: 2012 Ford Focus Ad, something Ford Australia could use on its Falcon
Originally Posted by MexicanBatman
You ever driven a fwd car with a real LSD?
Electronic gizmos are ********, it applies the brake on the inside wheel to transfer torque... Now a simple LSD achieves basically the same thing without working against itself
But this isn't the kinda of car designed with drivers in mind, no.. It's designed for Americans, who gives a crap if you can tag a song to then later be downloaded or have it poorly park itself, things like direct injection and 6spd powershift are win though, as is a decent sound system, but by Sony, really? Sure its better than what we have locally but Sony are crap!
I dont see how it is any different to DSC or traction control on our local Falcon that applies the brakes to one wheel..
Joe5619 is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2011, 12:36 AM   #62
Buntz
Straight Eight
Buntz's Avatar
Except that it applies it through every corner to help the FWD car corner better. Completely irrelevant for Falcon. And it uses the brakes more. Which mena they wear more, which means they need replacing more often, which means it will cost more to own.
The Falcon is dead. Long live the Mighty Falcon.
Buntz is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2011, 09:40 PM   #63
Swordsman88
Getting it done.....
Swordsman88's Avatar
Cost more to own than a falcon..not likely! Sure it has higher pad wear as i alluded to in my earlier post but its not likely to be very much. The euro spec pads are the main reason a focus costs more to replace brake pads not the fact they are used more. Besides the rego and running costs fuel wise of the falcon (plus higher up front cost) mean it will always cost more to run overall than a focus even with expensive euro parts....
Dynamic White 1995 EF XR6 Auto
Now with:
Pacemaker 4499s
Lukey Catback Exhaust
Chrome BA XR-style tip
Airdam Mounted CAI with modified (bellmouth) airbox
Trip Computer install
KYB shocks
Bridgestone Adrenalin tyres
Coming Soon:
Exhaust Overhaul.....
Swordsman88 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2011, 09:53 PM   #64
DJM83
Barra Turbo > V8
DJM83's Avatar
hahaha a Focus more expensive to run then a Falcon seriously where do you get this from?
My Focus is a lot cheaper to run then my old T2 TE50, and the payments are more then the TE aswell.
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2011, 10:55 PM   #65
Joe5619
I don't understand your point. If you drive a Falcon too hard around a concer DSC will apply the breaks to one wheel.. Sounds like the same thing is happening with the focus. If it dosn't lose traction it wont apply the breaks?? Or have I missed something??
Old 29-04-2011, 12:02 AM   #66
Swordsman88
THey are related in so far as the same tech is behind it (braking system). BUT the difference here is that the Falcon will not intervene unless the car becomes substantially unstable...esp i oversteer situations. This system on teh focus is more of an active system. i.e. it uses the dsc system to apply brakes to achieve the desired line the driver requires via reading the steering lock. It would cut in much earlier than the falcon system and is really a feature to reduce FWD understeer on exit of the corner rather than a safety feature.
So while the two systems are in effect the same thing the focus has the added feature (on top of its own dsc) to assist in driving through corners even when the car is not as yet in an 'unstable' state....
Now with:
Pacemaker 4499s
KYB shocks
Coming Soon:
Old 29-04-2011, 01:55 PM   #67
Buntz
Straight Eight
Buntz's Avatar
I didn't say it would you twit. I'm saying it would cost more to own if applied to the Falcon, as it's going to cost more to own than previous model Focus'.
Old 29-04-2011, 02:00 PM   #68
DJM83
Barra Turbo > V8
DJM83's Avatar
Um no re read your post, i wasnt the only one that quoted you as it meaning that the Focus would cost more to own then a Falcon.
Personal insults will also not be tolerated against me or anyone else thanks.
