20-03-2015, 06:52 PM | #61 | |||
Thailand Specials
I don't think the current Triton will as its pretty damn old. Also easy to get big power and torque increases on the Triton through tune and exhaust as they're conservatively tuned so if you have that in mind might be alright to get one since they're real cheap at the moment. |
20-03-2015, 07:00 PM | #62 | ||
Thanks for that.
20-03-2015, 08:44 PM | #63 | |||
Dunno about the Focus diesel, but some diesels can have a manual burn off process initiated at the dealers, might be worth looking into? |
20-03-2015, 09:03 PM | #64 | ||
Current one doesnt, but the new one will. (Triton)
21-03-2015, 12:52 AM | #65 | ||
dpf in trucks are heaps of s---t (cummins engines) ad blue is better in our experience . but dpf can be bypassed just don't get caught
21-03-2015, 08:52 AM | #67 | ||
all modern diesels have 1issue or another to comply with emissions.
dpf as per this thread or egr, blocked intake requiring removal and clean every `80-100K or adblue, another thing to fill up change filter, run it dry and thing will go into limp home mode of some sort but they still pull like a train, oh the mountain of effortless torque |
21-03-2015, 12:04 PM | #68 | |||
Thailand Specials
Better off cutting it out, and having it turned off in ECU, its not worth replacing it for $6K when the car is worth $8K unfortunately. |
26-03-2015, 05:02 PM | #69 | ||
Yesterday I picked up the wifes 2009 diesel focus from the 3rd service centre that couldnt fix the engine malfunction issue caused by the DPF. I took it home and put it up on my hoist. There are 2 muffler shaped boxes in the exhaust, one connected directly to the turbo. The other directly aft of the first connected by a short lentgh of flex. Both have some type of sensor at the engine end. The second has what looks like 2 vacuum lines one front one rear.
I removed the later chamber and cleaned it. Firstly I stood it on its end and filled it with water and caustic drain cleaner. I let it soak for 15 minutes then flushed it out with a hose, in the reverse direction of the exhaust flow. I repeated the process and again flushed with the hose. I then used my high pressure cleaner from both directions and stood the chamber on its end to dry. I refitted the chamber and drove for 8 kms at 3000rpm to dry it out. The engine management warning has gone, the engine light is out and it runs better than it ever has. My options where $6500 to replace the DPF, or 2 hours labour and $15 for some caustic. All 4 bolts holding the chamber to the exhaust broke! No big deal I drove them out and replaced them with some 7/16 316 I had laying around. I have also found a company that will re tune the ECU to remove the DPF and improve performance etc. Regards Stephen |
7 users like this post: |
26-03-2015, 07:38 PM | #70 | |||
trying to get a leg over
I hate driving them, heaps of turbo lag, soft rear springs if you want to tow anything, they are cheap for a reason.
Cameron ------------------------------------------------------ |
26-03-2015, 08:01 PM | #71 | |||
Presumably though, there's going to be a nice cottage industry for someone to cut DPF's open, clean out and zip them back up. |
26-03-2015, 08:12 PM | #72 | |||
Thailand Specials
While you're there run her up on the dyno and make some touch ups |
26-03-2015, 08:33 PM | #73 | ||
Bloody hell what a nightmare!
No wonder France is starting to ban diesel cars in Paris and even give tax incentives to non diesel car buyers. Give it a few more years and diesels will be obsolete. Make way for more advanced LPG and Electric vehicles I say!!! |
26-03-2015, 09:00 PM | #74 | ||
Thailand Specials
Things like Ford's Ecoboost engines are making me question my allegience to diesels but for now diesel is still winning the torque output when it comes to higher torque figures.
26-03-2015, 09:09 PM | #75 | ||
Now Fordless
A lot of people dont know how to fix DPF faults so they just quote a new system. As mentioned earlier they can be reverse flushed with water. Also sometimes you can trick the system into thinking its been replaced then just carry out a burn or take it for a hard drive and that usually clears them up.
Diesels are turning into a pig of a thing these days. They weren't built to be constricted by emissions |
26-03-2015, 09:28 PM | #76 | ||
Thailand Specials
I feel with diesel engines at the moment we're in the equivilent to the 1970s/1980s for the petrol V8 how they got strangled badly by emissions regulations, look at the Chev 305/350 from the 1980s, 170HP lol.
They're just quickly coming up with bandaid solutions for emissions regulations. We've had a big jump with common rail/direct injection engines, then we've stalled again with DPF, it seems the latest diesels with SCR system on top of the DPF are having no way near as many problems with them then just DPF cars. |
26-03-2015, 09:42 PM | #77 | ||
Now Fordless
Electric cars will take over in the next 10 years. There is only so much they can do to a petrol motor emission wise and diesels are still clogging up the air even with the stuff they have hanging off them.
26-03-2015, 10:19 PM | #78 | ||
Thailand Specials
Who cares if it sounds like a tram, as long as they have a manual option and it goes fast its all good.
26-03-2015, 10:33 PM | #79 | ||
I`m not so sure, the people selling the electric models put the good points forward, and you would expect nothing less, but look closely with a magnifying glass at how the batteries are made , one has to wonder if it really is better regarding pollution and use of resources to make the batteries.
4 users like this post: |
26-03-2015, 10:55 PM | #80 | ||
Basically there isnt a diesel in existance at the moment that can meet Euro 7 standards.
Euro 7 permissable NOx levels is half that of Euro 6 which is impossible to meet with current technology apparently. Enjoy your diesels while you can.
26-03-2015, 11:31 PM | #81 | ||
That applies only to new cars :-)
26-03-2015, 11:42 PM | #82 | ||
Punch the catalyst out of the dpf and refit, the pre and aft sensors will always read 100% flow so won't ever need to do a burn lol, never tried it but heard off a few people it works...
27-03-2015, 02:00 AM | #83 | |||
Now Fordless
27-03-2015, 02:33 PM | #84 | |||
not to many rare earth elements used in basic petrol cars, and a basic car imo opinion would run rings around any electric car when all things are considered cost/pollution/cost of manufacture/infrastructure cost . but well agree to disagree |
27-03-2015, 05:12 PM | #85 | |||
VFII SS UTE
and most new diesel meet euro6 while petrol doesn't.
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
28-03-2015, 02:03 AM | #86 | ||
I remember reading some time ago an article talking about the emissions of a new car just released released..... I think it was a Honda? They went on to say the emissions coming out of the exhaust where cleaner than China's air, and they where not joking, they had ppm comparison, just a bit of trivia .
2 users like this post: |
28-03-2015, 02:05 AM | #87 | ||
Thailand Specials
You could probably put your mouth over a smelly dirty old Land Cruiser exhaust pipe with a 2H diesel in it, and it would be better health wise for you than China's air
02-09-2015, 04:56 PM | #88 | |||
I am most interested in this solution. Can you give the mix of water and caustic drain cleaner? Also what brand drain cleaner - just out of interest? I have a few other questions but they're probably better for a pm. Can't do that yet!
Cheers, Mark Quote:
02-09-2015, 10:35 PM | #89 | ||
02-09-2015, 10:41 PM | #90 | ||
Brad
Yeap and allot of people dont notice and will not put in the correct oil.
Silhouette BF MKII F6 Plazmaman Intercooler Kit, ID1000, 34mm Internal Wastegate and Turbosmart Actuator, Tein Coilovers, Focal Audio, XXR 521 18x8.5 18x10 |
