Old 10-04-2013, 11:41 AM   #61
Vesper Martini
Vesper Martini's Avatar
Default Re: Ford & Holden Police cars put on dyno
Correct me if Im wrong, traditionally dynos are done in 4th gear because of the 1:1 ratio
what gear are they cop cars tested in and is the final drive the same?
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2013, 12:10 PM   #62
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
Not every car has 1:1 as 4th. ZF's dont even have a 1:1 gear. 4th in them is 1.14:1 and 5th is 0.87:1 IIRC, so with a low 2.73:1 final it works out the same as a 1:1 gear with a 3.11 final.
Not sure how the Commodore gearing is, but you'd trust an experienced dyno operator to know. Most 5 speeds only have 1 overdrive, most 6 speeds have 2.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2013, 12:50 PM   #63
superfly
Go the Hogster!
superfly's Avatar
Great to see the cops get behind an event like this and put their cars on the dyno. Big thumbs up!
Originally Posted by Motorbreath310
Most WRX owners would destroy their clutches quicker than they can say "I'll text my cousins after I finish this kebab" if they tried getting off the line as quick as a ZF-equipped XR6t.
I doubt this very much. It's not that hard to launch a WRX quickly even without destroying a clutch. Obviously if you can't drive, then sure you can fry you clutch. I launched my old WRX millions of times and the clutch always lasted fine.
Originally Posted by Adrenaline
My point is you can't base a car's fuel economy on the 10 seconds of wide open throttle it takes to smoke an SS. Because I do regularly give it hits, but it doesn't affect the average economy.
Is yours XR6T tuned? I agree with what you've said. Even when making lots of power, you can still get good fuel economy. Around a racetrack however, it's a different story
Nitro XR50 - the last brand new one in OZ
first registered Oct 2011.
superfly is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2013, 12:59 PM   #64
RAPID_BA
Originally Posted by 302 XC View Post
Makes the 5.7 seem dismal in the big picture ,when something with flashing lights makes more power,untouched
Tune and different diff gears on the turbo six,would be good to see
Pritty sad when the hottest of factory hotties is a 6 pot ford ........
My 5.7 LS1 has run more than 220rwkw on two dynos with a peak at 230rwkw. That is unopened.
What would diff gears do for the turbo on a dyno? make it go backwards more likely.
The SS cop car has obviously come in hot off the street (I didnt see it parked like the XR6T cop car) and torque management has pulled timing. Simple as that. That car should make 200+rwkw if it was parked like the XR6T half a day.
RAPID_BA is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2013, 01:06 PM   #65
RAPID_BA
Dyno operators are funny people..
On one dyno my LS1 years back made 226rwkw in Workshop A. I went to another workshop (Workshop B) for a OTR filter. Base run for 202rwkw in workshop B so it was reading 24rwkw less with base car same??
Then with OTR power went to 224rwkw in workshop B. Then I went to original garage workshop A for a powerrun with OTR and it made 232rwkw gained 8rwkw with OTR in workshop A over base run but gained 22rwkw in Workshop B that fitted it??? Workshop B appeared to be the more conservative dyno with base car but showed more gains with the OTR? Odd..
Old 10-04-2013, 01:26 PM   #66
FPV GTHO
The SS isn't going to do 200rwkw when the turbo does though. It's down 10kw at the engine and the Fords are well known to be underrated.
Old 10-04-2013, 01:43 PM   #67
superfly
Go the Hogster!
superfly's Avatar
Sorry but are you saying a "cold" car makes more power than a "hot" car? Or was the dyno day held on a particularly hot day?
Weird though that driving it on the street (under normal conditions) pulls out timing. When does the timing get reset? On a restart of the car or a relearn of the conditions?
Old 10-04-2013, 01:51 PM   #68
Professor Farnsworth
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Many years of valuable contributions to the forum, including some superb build threads.
after all these years and bans you still come in with the LSx troll stick..
torque management pulling timing? unless the cops had been doing flat-out runs chasing people down the highway 10 seconds before doing the dyno run then i highly doubt it.
did he miss a gear too? hit some oil? get blinded by the sun?
Professor Farnsworth is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2013, 03:20 PM   #69
Jip
I wonder what the torque figures were?
Jip is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2013, 06:13 PM   #70
DJM83
Barra Turbo > V8
DJM83's Avatar
Do you honestly believe anything that you type?
The XR6T would probably still make more power if it was full of heat soak.
I reckon you should sell your Fords...
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2013, 10:45 PM   #71
FGII-XR6
FGII-XR6's Avatar
[SIGPIC][/SIGPIC]
Rides:
Old 11-04-2013, 04:33 PM   #72
302 XC
End of the day,we can make all the excuses in the world, or throw in all the tall stories we want
The ford turbo 6 pot on the day,put down more power than the commie V8 ...
End of story,void of any or all reasons
302 XC is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2013, 08:17 PM   #73
brett7777
brett7777's Avatar
Just happy to see that the turbo'd I6 Ford was faster than the Holden V8. That's all.
Current:
Toyota JZX90 Mark II Tourer V 1JZ-GTE
Nissan Fairlady 350Z
Nissan Skyline 370GT Coupe
Previous:
FPV BF F6 Typhoon #202
BF XR6 Rebel
Founder of BA & BF FORD FALCON FACEBOOK GROUP
brett7777 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2013, 08:30 PM   #74
bungers
bungers's Avatar
Faster our more powerful? I saw more power, didn't think it was a 1/4 mile race?
In saying that the turbo 6 motors are an fantastic motor. Would rather a supercharged 8 though.
Sent from a bar somewhere
bungers is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2013, 05:16 AM   #75
brett7777
brett7777's Avatar
So which would win the 1/4 mile then?
Current:
Previous:
BF XR6 Rebel
Old 12-04-2013, 09:40 AM   #76
stock for stock, auto for auto, the turbo just.
Old 12-04-2013, 10:02 AM   #77
vevapower
vevapower's Avatar
The turbo is over half second quicker than the SS.
Possibly even more!
I've seen bog stock XR6 T's dip into the 12's and I've never seen an SS better than a 13.6 at the track.
" you've seen it, you've heard it, and you've still asking questions"
vevapower is offline   Reply With Quote Multi-Quote with this Post
