Old 28-09-2005, 04:14 PM   #61
EA2BA
PM me if you want
EA2BA's Avatar
no i pulled the dizzy out after several attempts to start it again, and it has been confirmed as in the correct position and timing by another member (spope) so this is really, really begining to pi$$ me off, and the wife is putting pressure on to wreck the car, catch public transport.
Old 28-09-2005, 04:48 PM   #62
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Before doing that, just wait on the other ECU's you're gonna test on it and see what happens...
Carless
Old 28-09-2005, 04:52 PM   #63
John_LS1
sounds like its flooded, start the car with your foot on WOT and keep it there, just keep cranking, it should eventually start and no doubt alot of black smoke will pour out. seems like everything is working so its all i can suggest.
Old 28-09-2005, 05:00 PM   #64
EA2BA
PM me if you want
EA2BA's Avatar
I have had the plugs put for over an hour then new plugs went in, didnt start then either, but with the new ecu will try it.
Old 28-09-2005, 05:18 PM   #65
megsy
Undergraduate EB Operator
megsy's Avatar
try what john_xr6 said it is probably flooded, other than that youve got be stumped, if the car has been sitting for ages and you start it with throttle at 100% it may go into limp mode so you may have to restart it,
good luck
Simon
04 BA Xr6 ... now with carpark dints
megsy is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2005, 05:30 PM   #66
EA2BA
PM me if you want
EA2BA's Avatar
It went in the garage sunday morning, it was finished late sunday arvo, it started for 30 seconds, since then no good.
Old 28-09-2005, 05:41 PM   #67
EFFalcon
Last warning
EFFalcon's Avatar
coooooooooompression!
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 28-09-2005, 05:46 PM   #68
Walkinshaw
Two > One
Walkinshaw's Avatar
Seing the car ran for 30sec then died, it sounds like an electrical fault. How are you testing for spark??
Old 28-09-2005, 05:46 PM   #69
EA2BA
PM me if you want
EA2BA's Avatar
it's on the list need 2 poeple as i dont have screw in type compression tester, so that wil be done, not that compression was an issue before.
Old 28-09-2005, 05:49 PM   #70
Walkinshaw
Two > One
Walkinshaw's Avatar
There is no way that you would blow all 6 rings in 30sec
Old 28-09-2005, 05:49 PM   #71
EA2BA
PM me if you want
EA2BA's Avatar
spark plug in lead, then jumper cable to the engine, crank it and watch the sparks fly, did it for eash lead, all sparked.
Old 28-09-2005, 05:51 PM   #72
EA2BA
PM me if you want
EA2BA's Avatar
It is an EA we are talking about, but yes agree, however after testing it, i can stick on the done list.
Old 28-09-2005, 06:10 PM   #73
megsy
megsy's Avatar
dellboy try this,
take out the plug on cyl 1 and manually find TDC and see if it lines up with your harmonic ballancer because you are using a different ballancer and your old timing case they may be different,
the only thing i can think of atm because you have good spark good fuel, and good air if starting at WOT therefore there is only oher thing to check it timing
Simon
Old 28-09-2005, 06:13 PM   #74
EA2BA
PM me if you want
EA2BA's Avatar
I lined the balancers up to start with using the key way, both of them facing the same direction then added a mark to the new one in the correct spot as I knew they are different.
Old 28-09-2005, 06:26 PM   #75
BIGDOG
BIGDOG's Avatar
BBBIIIGGG Vacuum Leak
Is your ICS refitted correctly after R&R for dissy
Brake booster hose
MAP senser hose
Broken vac tree at rear of intake plenem
Batt Earth lead at eng Block loose
Try loosening dissy and rotate it back & forth while cranking
One man out--Try removing start relay and jump the two large terminals in the plug it will crank(ign on)
Good luck
BIGDOG
BIGDOG is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2005, 06:34 PM   #76
efgiar
rofl copter
efgiar's Avatar
it cant be the start relay because it TURNS OVER thats wat that relay does. id say its totally out of timing, or the balancer has shifted somhow. it could be compression but highy doubt it. id try pi$$in round with the balancer and see how u go.
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2005, 07:16 PM   #77
BIGDOG
BIGDOG's Avatar
You said you were on your own.
This proceedure will allow you to crank when your noggin is under the bonnet.
BIGDOG
Old 28-09-2005, 07:59 PM   #78
Psycho Chicken
Psycho Chicken's Avatar
$500 it's got nothing to do with the ignition timing. He's checked it a million times, checking again won't change anything.
Old 28-09-2005, 08:15 PM   #79
MAD
Petro-sexual
MAD's Avatar
Did you put any shims or do something different with the valve gear? I'm thinking maybe it took 30sec to pump up the lifters, and now they are holding the valves open.
- The Story
Old 28-09-2005, 08:23 PM   #80
smoke
the only way is sideways
smoke's Avatar
Check for vacuum leaks!
And if you're plugs are really wet, could it possibly be too rich and flooding the crap outta them?
Change back to the old fuel pressure reg, you never know...
smoke is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2005, 08:51 PM   #81
EA2BA
PM me if you want
EA2BA's Avatar
Ok well after further checking, double checking,changing parts, trying weird ideas like plugging everythingn 180 out, and all no good, with the timing and plugs set correctly and foot flat to the floor it shot flames out the throttle body, nice blue flame very impressive you would say.
So all in all, I have decided to pronounce it dead due to mechanical failure, exactley where or why, I wont know till I strip it apart, so glad it happend at home and down the freeway.
Thanks again to all those who offered help, the EA will live on, just be getting a new heart very soon I hope.
Old 28-09-2005, 08:53 PM   #82
EFFalcon
Last warning
EFFalcon's Avatar
flames out the t/b?
sounds like it ignited with the intake valve open?
Old 28-09-2005, 09:03 PM   #83
smoke
smoke's Avatar
that sounds weird, did you try using aero-start to see if it'd fire?
that stuff makes anything start (well almost).
Old 28-09-2005, 09:04 PM   #84
Psycho Chicken
Uhhh, flames out the TB means one of two things, timing is out or the inlet valves aren't closing.
Old 28-09-2005, 09:08 PM   #85
Damo
how could it just be dead all of a sudden, this doesn't make any sence, it was running fine before you did serpentine conversion right ? :( I was hoping to see a positive end to this thread.
Old 28-09-2005, 09:09 PM   #86
EA2BA
PM me if you want
EA2BA's Avatar
I have decided timing is just moving about and not staying as expected, i cant think of any other reason for it not starting, so time for a new engine, after 270,000k i think maybe more (possible cluster change) it has done pretty good.
Old 28-09-2005, 09:18 PM   #87
MAD
Petro-sexual
MAD's Avatar
Does the rotor button spin when the engine is turned over? Maybe the aux shaft has had its gear sheared off.
- The Story
Old 28-09-2005, 09:18 PM   #88
EFFalcon
Last warning
EFFalcon's Avatar
compression ;)
i wanna know the answer to this dammit :P
Old 28-09-2005, 09:21 PM   #89
smoke
smoke's Avatar
so do I !!!
Old 28-09-2005, 09:21 PM   #90
EA2BA
PM me if you want
EA2BA's Avatar
compression ;)
Ok then compression, 2 turns of the motor produced these results:
1 - 90psi
2 - 90psi
3 - 30psi (checked 3 times)
4 - 90psi
5 - 90psi
6 - 90psi
