Old 15-12-2005, 07:33 PM   #61
ned
Once shy... twice bitten
ned's Avatar
Sorry for picking up an old thread, just wanted to know if you've still got air-con? Or do you have to get rid of it?
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11.
ned is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2005, 10:56 PM   #62
OED666
OED666's Avatar
i dont have the old ac compressor connected... i am not sure what model compressor i have now... either ef, el or au...
i still have the ed compressor though...
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2006, 05:59 PM   #63
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
what needs to be done to get the original ea accessories working with the au motor?
cheers,
santo
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2006, 06:51 PM   #64
OED666
OED666's Avatar
i wouldnt even bother... you have to grind heaps at the timing cover and swap the harmonic balancer...
your better off keeping the serpentine setup... much easier, plus you will have a 110amp alternator...
so i went with the serpentine setup...
Turbo Barra ED 4L
Old 13-05-2006, 07:13 PM   #65
santoitaliano
BF F6, APV SR3900
can existing accessories be converted or do serpentine type accessories also need to be purchased, particularly ps pump and the like...
Santo
Daily:
Bluepower enhanced.
Old 13-05-2006, 07:15 PM   #66
Walkinshaw
Two > One
Walkinshaw's Avatar
purchase all EF/L/AU parts
Compressor, P/S, Alt etc
Old 14-05-2006, 09:01 AM   #67
Kenaz
Kenaz's Avatar
Santo, sphell put a AU motor in his EA keeping the EA belt setup. If you send him a PM I'm sure he'd be able to tell you more about it.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2006, 05:32 PM   #68
OED666
OED666's Avatar
if you get the pulley from an ef-au then you can keep your power steering pump. i swapped mine over.
you will however need to get a new alternator and ac compressor
Turbo Barra ED 4L
Old 14-05-2006, 10:21 PM   #69
santoitaliano
BF F6, APV SR3900
aww the a/c just been re-gassed... where would be a good place to source a good au xr6 engine?
Santo
Daily:
Bluepower enhanced.
Old 15-05-2006, 08:30 PM   #70
santoitaliano
BF F6, APV SR3900
ok found a motor today... 70k on it...
it is complete with accessories... they only had vct xr6 engines but i would like to cam it up, so am not going to go this avenue... there isnt much diff between std. and au engines anyway?
so all i need is:
1 x au motor
1 x set of thermos
1 x accessories to run single belt setup
1 x EA engine mounts
and need to be aware of:
1. need to use my manifold
2. two holes dont line up on bellhousing
3. sump / k-frame need to be ground a bit
4. radiator pipe slightly different, but problem can be solved..
i'm looking at doing it all on saturday...
is there anything else i should know, or is there any big benefit of trying to find an xr6 engine..
i can't not run VCT and run a normal cam can i?
on a standard AU motor i can run the cam i currently run in my car (977b) and valve springs?
any help appreciated..
Santo
Daily:
Bluepower enhanced.
Old 15-05-2006, 09:58 PM   #71
Rollin
Rollin's Avatar
Earlier cams are not compatible with earlier engines, unless you have a late EL cam.
im not sure about the VCT setup, its run off engine oil pressure, but I dont know if its a pulse-width-modulated signal or just a pure 5v or 12v signal...if it was a straight signal you could set up some kind of shiftlight arrangement but using it to change over the cam timing instead of illuminating a bulb, but you would have to do some research on that one....
VCT and AU non-VCT cams should be interchangable, which one is 'better' I don't know.
dont use the thin metal 'sandwich' plate thingo that comes on your standard engine (between the engine and gearbox) when you swap them over, if you toss it the sump on the AU motor will sit flush against the bellhousing, making it a bit stronger or less resistant to flex IMHO.
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2006, 10:00 PM   #72
santoitaliano
BF F6, APV SR3900
in all honesty.. would it be better bolting up an AU motor or is it better to run a late model motor or just rebuild the 3.9?
Santo
Daily:
Bluepower enhanced.
Old 15-05-2006, 10:22 PM   #73
DOMN8N
AKA ___DOMMUZ
DOMN8N's Avatar
or a eb 4.0
for sale ======0430436963 -------9.000 ono
DOMN8N is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2006, 10:45 PM   #74
OED666
OED666's Avatar
yea, use your existing manifold..
dont worry about the bellhousing... it will be fine...
you need to grind a little off the sump, not the k-frame
i had a reducer made from stainless steel for the difference in radiator hoses... cost m $20
no, you will not be able to use your current cam. not sure about valve springs.
Turbo Barra ED 4L
Old 15-05-2006, 10:46 PM   #75
OED666
OED666's Avatar
AU 4.0L!!!
They are heaps smoother!!! They will go forever!!!
Turbo Barra ED 4L
Old 16-05-2006, 11:54 PM   #76
Rollin
Rollin's Avatar
valvesprings are different.
All the differences between the motors are actually IMPROVEMENTS - smaller valve stems, springs, collets, cam lobes etc all contribute to lower valvetrain mass, meaning an engine that revs quicker and 'freer'
Au engines have a better rod to stroke ratio, meaning the rods don't have to work on as bigger angles, less side loading on bores means less wear, less power loss through friction, more revs, more hp.
Each main bearing cap is held in place by 6 bolts, instead of the two on our engines...again, stronger, stiffer, more reliable.
The head responds better to porting than any previous head, again, more possible hp.
AU engines poo all over earlier engines from a great height, no contest.*
Q: How fun is it to rev an engine to the end of the factory tacho, and have the car hammer all the way to 6000rpm?
A: Very fun...OED666 was kind enough to let me drive his car after we finished it, you couldn't wipe the smile off my dial with a sledgehammer.
*thats not to say earlier engines are poo, they are very very good, it's just AU engines are very very very good...
Old 17-05-2006, 05:46 PM   #77
hobo
Monster Burreuto
hobo's Avatar
i read in other threads that you need the XH tensioner to have the serpentine with the old manifold, did you need it?
I PITY THE FOOL :ticking:
hobo is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2006, 07:41 PM   #78
BI6TIM
SnortPerformance.com
No they didn't use the XH tensioner, they used all AU gear (well pretty sure anyway).
It does all fit but only just!
BI6TIM is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2006, 07:46 PM   #79
DOMN8N
AKA ___DOMMUZ
DOMN8N's Avatar
is it a vct ?
Old 17-05-2006, 07:48 PM   #80
BI6TIM
No, it's XR but not VCT.
Old 17-05-2006, 07:49 PM   #81
BI6TIM
Sorry to steal your spot light Paul.
Old 17-05-2006, 07:51 PM   #82
OED666
OED666's Avatar
well said skro!!! i love having a tacho which allows full use...
I have a HP XR6 motor... i bought an xh tensioner and it seemed very similar (so i didnt put it on)... but the guy i bought the motor off said that i should get an xh tensioner... so i am assuming its an au tensioner...
Turbo Barra ED 4L
Old 22-05-2006, 09:32 AM   #83
!Gn|T|0n
!Gn|T|0n's Avatar
Sorry to not contribute anything useful to this thread, but I just felt the urge to thank you skro for a very entertaining post. I rolled off my heavily TSB infected region and face planted the floor I was laughing so much.
I do believe that one of the times that you wound the tacho out as described was whilst royally serving me in my "Captain Pugwash" machine.
Still saluting the Ford flag.
!Gn|T|0n is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2006, 04:34 PM   #84
OED666
OED666's Avatar
here are some pics, and many months too late
Turbo Barra ED 4L
Old 23-05-2006, 06:19 PM   #85
DOMN8N
AKA ___DOMMUZ
DOMN8N's Avatar
were did u get dat intake from
Old 23-05-2006, 06:36 PM   #86
LUXO_8
windsor user
" that " intake looks cool as....
looks to be a custom job
Old 23-05-2006, 06:38 PM   #87
RavenLS1
nice! luff the intake too!!!
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG.
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2006, 08:39 PM   #88
shoey50
got any pics of the k frame mods mate?
shoey50 is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2006, 11:21 PM   #89
DOMN8N
AKA ___DOMMUZ
DOMN8N's Avatar
would suk sum gud air in ay
Old 24-05-2006, 08:17 AM   #90
BI6TIM
dommuz, please speak english mate.
