View Poll Results: CAI does it work
Doesn't work all expensive plastic rip off 15 13.27%
maybe worth a couple of kw and looks good 45 39.82%
will produce some good gains on a modded car 36 31.86%
cheapest and best power mod you can buy 17 15.04%
Voters: 113. You may not vote on this poll
Old 19-05-2006, 08:18 PM   #61
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
Originally Posted by Aaron_EF8
Why didn't you cut a hole in the inner guard and run a pipe from the bumper? Seems like a neater option.
I personally don't see how that will produce a noticeable amount of power, but in saying that, it won't lose power either.
where abouts do mean? underneath the head light? i got ABS to. how won't it produce power? standard intake is tiny and no air is guided up there, with mine the air that comes through the holes in the front of the bonnet gets throwin' straight up into the intake.
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2006, 10:38 PM   #62
bodes-sh
ss inductions has the same setup for their xr intakes, a ram to push air up into the intake. not saying it makes much difference tho as i havent got one....
when i first saw the picture i thought u meant u gained power by taking the engine out lol
Old 18-06-2006, 07:31 PM   #63
ziggee
what would happen if you could cool the air inside the airbox? like a refigerator, would this do anything, real good read for those that know nothing about it (like myself).
So I guess I am asking, if all that dense air is good, and you can take out of the equation the restriction bit?, would colder air be better than ambient air? or would this have a negative effect... also I know I am going get told off, but what about forced air via a fan for bigger CFM. or could your draw the exhaust gases out quicker
I like the example of how it works, air pushed in, air mixed and igntited, air exits..
just asking ;)
note : I have no idea if it works or not, not kknowledgable enough to tell
Old 18-06-2006, 07:41 PM   #64
pks54
Ford Power To The People
pks54's Avatar
[/SIZE]
a.k.a turbo or supercharger
pks54 is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2006, 07:47 PM   #65
troppo
Mr old phart
troppo's Avatar
And cold air will improve performance. Some people have spent big dollars making custom intercoolers with icebox setups to cool the air in the intake.
An object at rest cannot be stopped!!
BA GT-P Blueprint
troppo is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2006, 07:58 PM   #66
chief
FTF Club Moderator
chief's Avatar
For drag strip runs, some people put dry ice in their airbox to try and cool the air.
Albert Einstein:
Fords in the Park 2010
Old 18-06-2006, 08:04 PM   #67
ziggee
yeah without the $$$ to do it, was thinking more along the lines of jesus can't belive I am going to post this, me gets ready to be beaten to within an inch of my life, PC fans, with 120+CFM..
obviously just as a mockup...
ok, hit me, but just leave the face alone!!
Old 18-06-2006, 08:06 PM   #68
Sourbastard
Contributing Member
Sourbastard's Avatar
Dry Ice is solid carbon dioxide. Its cooling the air, and adding a crap load of C02 into the intake as it melts. You would be better off using something like frozen gel packs. Or, just install an intercooler, what it does for a turbo, it can do for a NA engine.
1965 XP Falcon Deluxe Sedan
2003 BA Fairlane G220
Old 18-06-2006, 08:09 PM   #69
Sourbastard
Contributing Member
electric fans dont work. they are a proven obstruction. prepare for beating.
Old 18-06-2006, 08:13 PM   #70
pks54
pks54's Avatar
what are you on tonight... pass some over here.
think about how quickly a piston is moving up and down per sec. times this by how many cylinders you have got. get the picture of how much air is drawn into engine.
these would do nothin but be a restriction.
anyways, give it a go and let us know. I dont know everythin
Old 18-06-2006, 08:16 PM   #71
ziggee
hehhe sorry it was the only thing that came to mind as an example...
How much CFM would be need so 6cylx7000revs (MAX)=42000CFM jesus better get a BIGGER pc fan!!! ;)
Old 19-06-2006, 11:58 AM   #72
Des
V8 Rock'n'Roll....
Des's Avatar
Location: You got me Rootin' like a Hog, Barkin' like a Dog, Climbing trees and Jumping logs....
Mount an Air Conditioning Unit in the back of the ute. One of those units that hang out your window.... :
1 owner 03 BA XR8 Manual Sedan
208.8 rwkw stock, update soon
20x8.5 fr 20x10 rr
Rumble thanks to:
Sureflo Exhaust - Stainless Cat's & 3.5in single catback system
"Tell 'em the guy with the Blue Mohawk sent Ya"
Des is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2006, 07:17 PM   #73
macca_779
Turbine Power
macca_779's Avatar
You want cold air and power. How about plumbing liquid oxygen into your airbox. That will give the desired effect. O but consider it is 100% o2 unlike NOS which is nowhere near that. You'll wanna be carefull with it. I think B O O M big B O O M might be in order. I've thought about trying it as i have access to unlimited LOX. But im a bit scared to be honest.
macca_779 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2006, 07:32 PM   #74
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
I'm not sure how many people used to read Zoom magazine when Julian Edgar wrote it, it was a really good magazine focusing on budget performance back then.
Anyway, they looked into using liquid oxygen and compressed oxygen instead of nitrous oxide. The problem they had was finding someone who would clean the parts properly while still keeping the cost down to make it reasonable. With compressed oxygen, if you get even the smallest amount of dirt in the lines or jet, like you said, there will be one hell of a bang. They didn't really follow it through, due to this 'small' factor....
A few people mentioned using the AC cooling the intake air, doesn't the new SVT F-150 Lightning have a similar setup??
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2006, 07:35 PM   #75
1TUFFUTE
1TUFFUTE's Avatar
what about a pipe from the air con turned around into the intake. Too bad the power to run the aircon is probly nagated the cooler air... :
Old 19-04-2008, 08:01 AM   #76
Wally
XP Coupe
What a classic thread. We've managed to throw in just about every cliche e.g. air pump, ram air, torque in lieu of power, denser air, oracle name dropping and even the bumometer. :voldar02:
There are the usual tribes; the cynics, the true believers, the ambivalents, google mechanics and the profiteers.
I'm with the guys who spend pennies and smirk at the idiots who buy bling & placebo noise for the same blip in the power curve.
Wally is offline   Reply With Quote Multi-Quote with this Post
