27-09-2021, 09:58 PM | #1141 | ||
you dont even let dirt settle on your tools,
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent |
5 users like this post: |
27-09-2021, 10:47 PM | #1142 | |||
Cheers BillyN |
28-09-2021, 09:47 AM | #1143 | ||
T3/Sprint8
yep its sad but mad cleaning the garden and work tools for me
The most cleaning I've done is the blower over the mower quickly, I like the used and abused look on garden and outside tools of choice More like I couldn't be bothered, barring new plugs or a filter thats all the TLC they need to keep them firing.
4 users like this post: |
28-09-2021, 10:26 AM | #1144 | |||
But it did make me chuckle a little, good stuff on a normal boring day. Cheers BillyT |
2 users like this post: |
28-09-2021, 11:28 AM | #1145 | ||
T3/Sprint8
gawd even spraying WD is excessive to me lol, the tools are all under cover in the off season, infact just brought out the Stihl whipper and Briggsy 4stroker out of hibernation on the weekend for the seasons first cut/s, both fired up with relative ease and away we go
30-09-2021, 07:42 PM | #1146 | ||
I finally got my Hoselink oscillating sprinkler and manual hose reel today. The sprinkler is gonna take some fine tuning, it may mean I have to move it at least once.
Typically mum brings around her 9 pattern one after I already ordered Maybe I can use that for the front but not sure. The hose reel not as slick as I expected but then again that is compared to the much more expensive wall mounted one I'm used to. It is certainly a lot more compact than I expected. I thought the leader hose would be on a reel but it is kind of awkward and needs to be wound by hand behind clips. You can either attached leader or reel end to the tap. Otherwise it will do the job fine, it reels in simply enough and certainly better than the crappy reel I got now. |
3 users like this post: |
01-10-2021, 06:47 PM | #1147 | ||
RS The Faster Fords
We're nearing renovation season on the golf course (I'm at a new club now) so I thought I'd share a couple of steps if anyones thinking about doing the same at home.
So firstly, get your retic or watering tested and working. Most retic shops give out catch cups for free so use these to check for uniformity wet/dry spots and work out your timing for a 10mm drink which is the usual rate for watering and washing in product. On to the products, depending on your soil start with an application of wetta soil granules, followed by 10mm of water. A week later apply a general fertilizer and another 10mm. This will put the plant in good health before the stress of renovation. I know the blokey thing to do would be to chuck out a bag of each until it looks like its just snowed But, please, work out your square meterage and stick to the recommended rates. You're just throwing money away otherwise... A couple of weeks later you'll be ready to go. Generally you'll get away with a low mow and rake to remove thatch. Vertimow if you've got heavy thatch or if the mower chokes when you mow. Core with a machine or punch holes with a fork if the soils compact or if theres a thatch problem. This will help with water penetration and get the soil bacteria working to help break down future thatch. Hope that helps get those lawns started for summer.
Escort RS2000 Restored factory a/c and alloys. TD Cortina Unrestored 35 000km 6cyl manual. Mk1 GT Cortina Project. FG XR50 Daily. |
10 users like this post: |
01-10-2021, 06:54 PM | #1148 | |||
Great tips!
PX MK II Ranger FG XR6 FG X XR8 Mustang GT T3 TS50 - gone but not forgotten |
01-10-2021, 07:20 PM | #1149 | ||
Very regular
I have to ask. Is that similar to the Illudium Q-36 Explosive Space Modulator?
G6E Turbo Ego Cashmere .....The velvet sledgehammer |
01-10-2021, 09:20 PM | #1150 | ||
Budget Racer
Where's the kaboom? There was supposed to be an earth-shattering kaboom!
12.1@112Mph 285rwkw on n2o Cleveland Power |
04-10-2021, 03:31 AM | #1151 | ||
It's pretty cool. There is a knob for water flow, adjustable sliders for range and then you can turn off up to 3 jets either side for width control just by pushing tabs in.
You can also undo the knob on the end to drain it and it also has a pin for clearing the jets if they get clogged up. Also has a mesh filter on the inlet. Last edited by MITCHAY; 04-10-2021 at 03:37 AM. |
08-10-2021, 12:42 PM | #1152 | ||
Yesterday i did the wilson and stuck my head over the fence as i could hear my mate doing a lot of axe swinging but no block splitting. So i offered a hand and my chainsaw. So the stump is hardwood and about 900mm in diameter. So my bunnings cheapo chainsaw, its fine for trimming small trees etc as i dont have any large trees, so no chance of great success with this stump. But we did make a solid dent before it turned into another job for another day. Got half the stump out. So went through a tank of fuel, used the axe and a sledgy to eventually crak it in half and because the roots had been dug up and sawed off, that half came out with a lot of prior effort.
Sitting around after with a few earned beers, my other mate comes around to my mates place. He tried to big man himself after hearing the axe hardly makes a dent. So first swing and the thing bounced back and almost took his block off. Theres only 1 root left keeping the rest of that stump in the ground as it moves alot when bashed with a sledgy. So once its cut after more digging it should come out without too much effort. So its my mates mums house next door. Like most she's not made of money, shes doing alright for herself, but if its something her son can attack, or i can give a hand, we give it a crack. She's a really good neighbour so i dont mind helping out as it never goes unappreciated. Also i have a lot of tools that you wouldnt justify buying for a 1 off job. That being said, my chainsaw was not the correct tool for the job. Underpowered for that application, but thats not what it was purchased for and its filled its original purpose, but for 1 stump, paying a stump grinder would probably be cheaper then buying a hectic stihl chainsaw. But a bit of elbow grease, yeah takes a lot longer then a proffesional, is a lot cheaper still. |
08-10-2021, 01:15 PM | #1153 | ||
Stump grinder is dearer than a Bunnings chainsaw. You’d be looking at $220 for a solid crack at one stump. Consider a sacrificial bar and chain, yes $40-$60 but you’ll come out ahead.
My lawn is due for its |
08-10-2021, 01:42 PM | #1154 | |||
But considering it hasnt been used in months, after a fresh tank of fuel, a top up of bar lube and a prime. It started 2nd pull. 1st pull being full choke, 2nd half choke and it was good to go. So being a 37cc, 16' bar, there was no chance it would simply eat that stump. But it did make progress. So once the last root is dug down to, theres enough life left in the chain to chop that then the sledgy should be able to knock the rest of the stump free from the ground. |
08-10-2021, 01:52 PM | #1156 | ||
My $220 remark referenced the cost of having someone come out, unload their gear, grind one stump properly (to the point where the root burl was gone and main roots well ground back) and then pack up. Plenty of posers who go barely 100mm down but charge full freight.
08-10-2021, 02:16 PM | #1157 | |||
That tree was originally a big unit that died years before getting cut down to a stump. It got felled years ago. So far the 5 larger roots cut have been 6 to 8 inches in diameter so hopefully the last one i partially dug to is the final one keeping the remainder of the stump in the ground. The main 2 reasons why the seemingly simple task of the last root was postponed was my chainsaw after the best part of an hour running flat stick decided it was sweating balls so didnt want to start again, and my mate and myself were also sweating balls so beers were a better option. I did start the saw today to see if its dead, shes apples, started 1st go. |
09-10-2021, 03:39 PM | #1158 | ||
So after yesterday with doing stuff, me left arm us up to its old tricks. Anyhow enough about that.
So my mate who rents my granny flat, we go beer for beer mowing my lawn. If he wasnt a good mate he wouldnt be paying sweet f a for rent. So, he borrows my free to me whipper snipper, thats fine. The chain of ownership was my brothers neighbour bought the cheapest bunnings had, said it was a piece of crap as it never started, gave it to my brother who stashed it in his car hold for 5 or so years and then gave it to me. So a freebie, the fuel lines were shot, but $19 for a kit with fuel lines, fuel filter and a primer bulb. Add another $9 for a new spark plug. Small price to pay for something thats been deadly reliable for years now. So starting it. After a prime you go rip rip rip on full choke. It attempts to fire. Half choke, rip and thats all she wrote. Choke off and yeah. So fueled and lined up i lent my mate the snipper and sat back for entertainment. He primed it the one slow rip full choke, a time period, another slow rip full choke, well this happened a number of times and it never kicked. Then he went optimus overprime, so floods magee. I had a really hard time trying not to laugh or butt in and say give it a proper rip. He did get it going eventually it ran flawlessly. Nothing mechanical as towards not starting, purely user error. |
10-10-2021, 09:21 AM | #1160 | ||
I have a Stihl HS45 hedge trimmer that I bought in 2010.
I used it regularly when I lived in Cairns as everything grows overnight up there. I moved to my rural property in SE Qld in 2013 and put it in the shed with some other tools that I really had no need of anymore. Fast forward to yesterday... My wife planted some of that purple fountain grass a couple of years ago and it was looking a bit straggly and windblown. I go to the shed and grab the Stihl, chuck in a bit of 2 stroke that I've has for years, prime it, choke it and pull the cord. It coughed but didn't fire up. Pulled the cord again and she fired up and ran beautifully. Old fuel, old plug no matter! Is Stihl, is good! |
10-10-2021, 01:02 PM | #1161 | |||
With my little 2 stroke, worst case if i need to fill my fuel tin its a run down the servo. 10 minutes tops. A dead 18v battery on the rapid charger i have, about 45 minutes. But again, corded isnt an option for me. And the longest extension lead you can get is 25m from memory, and again if my memory serves me correctly (going back to tafe days doing my apprenticeship) its not legal to plug 2 extension cords together. My tafe teacher gave a logical reason as to why, but i wont get into that legnthy explanation. |
10-10-2021, 01:32 PM | #1162 | |||
10-10-2021, 03:50 PM | #1163 | |||
Anyhow, so my chainsaw chain i sacrificed the chain when helping a mate and getting 50% of the tree stump he wanted out. So i always keep the last chain i took off, theory being if you munt a chain and jobs pertty well done, if the old one is in better shape use that to get over the line. So its a couple days later and in the interim i did clean the bar and put on the last but in better shape chain as ive ordered 2 new ones but being a weekend theyre not here yet. Firstly, my crappy chainsaw, cold start? What cold start? And the old chain was not 100% but still good. So it went you can get chopped, you can get chopped etc. So the last bit of amateur stump removal went well. Yes effort was involved. I use powerfit chains, theyre not the most expensive, there is probably better brands out there, but for a 56 tooth 0.050 guage 16 inch chain i know they fit. |
10-10-2021, 08:25 PM | #1164 | |||
I topped her right up and did all the jobs round the yard and even did the back nature strip that was seriously overgrown ..Never missed a beat .. The engine is a 33cc Mitsubishi and was the commercial model I bought in 1995 for my business. Even then (1995) it wasn't cheap (from memory about $700) but she's been a good one.. Incidentally I believe Husqvarna bought out Jonsered in Sweden so there is a tie in with them both... I also have a cheap and cheerful Rockwell (via Mitre10) battery line trimmer that cost me about $100 with a spare battery ..I'm surprised how much I use it actually .. Out of curiosity how much would a commercial grade petrol brush cutter cost these days . Do you guys in the biz use petrol or is battery the weapon of choice these days ?... Love to know.. |
10-10-2021, 09:56 PM | #1165 | ||
B1 - J & D Services
I am semi pro on and off over the years. I am still 2 stroke for everything. Only now am I thinking of getting a 4 stroke Honda mower.
Mr. Brett Johnstone. 2007 Honda Odyssey 2002 Ford Laser 2000 Ford Falcon Wagon Egas 1999 Subaru Imprezza Sportwagon 1998 Holden Suburban 2500 1995 Land Rover Discovery TDI 1994 XG XR6 Longreach 1983 Holden Rodeo 1982 ZK Fairlane 302 six seater 1975 Datsun 120Y wagon 1970 MG Midget 1967 Rover 2000TC Soon: Model T. |
10-10-2021, 11:26 PM | #1166 | ||
Friday’s home mow was a nigglefest. The back of the mower has a folded steel tie/brace which the catcher bottom lip lands on. The left side lost one bolt, caught on a raised root and twisted - I then couldn’t pull the mower back without lifting the rear or it dug in heavily.
And the trimmer’s air filter housing vibrated loose, ejecting its filter element. Could I find it for love or money? Not until I ran over it with the mower. Normally I seek thrift and longevity in my gardening kit - but was definitely dreaming about a newer lawnmower that afternoon. |
11-10-2021, 06:26 PM | #1167 | ||
Hello all
Great thread. I'm looking for a new mower, what does everyone recommend ? Will only be used for home use and lawn area is relatively small. Approx 150 m Thanks |
11-10-2021, 06:32 PM | #1168 | ||
If you’ve already got decent cordless tools, this might be an ideal application for a battery powered mower skin.
11-10-2021, 06:37 PM | #1169 | ||
Petrol or electric?
11-10-2021, 06:49 PM | #1170 | ||
T3/Sprint8
Nope nope and nope re cord tools and I’m struggling to be convinced re battery even though I got a small blower one that gave up the ghost recently for small light work.
I’m just on 1300sp/m home with heaps of bush surround/gums etc you can’t beat good petrol product period. Suppose if you have a small yard the other options work. Sent from my iPhone using Tapatalk
