Old 18-10-2011, 02:28 PM   #91
SteveJH
No longer a Uni student..
Default Re: Ford gear box's in all V8 race cars ?????
Originally Posted by Rapid_Axe
Just wait til COF starts, the only difference will be the badge on the grill.
How successful is NASCAR again?
Not exactly. They already use control floor pan, front suspension and rear suspension now, with the outer panels just bolted onto the rollcage etc.
Fairly sure the main change with COTF is that they are getting a control roll cage, rear mounted tansaxle and they might be going to composite panels?
Basically the cars will still look like a Commodore or Falcon from the outside....but from the inside....well they arent exactly a standard car as it is.
SteveJH is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2011, 03:04 PM   #92
Charliewool
Bolt Nerd
Charliewool's Avatar
Does this mean there'll be a drive-shaft/jack-shaft straight off the crank to the rear transaxle? (doing 7,500 RPM )
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is online now   Reply With Quote Multi-Quote with this Post
Old 18-10-2011, 03:06 PM   #93
SteveJH
Yes.
Personally I think they should have taken the opportunity to switch to using the GM LS3 and Ford BOSS302 or Cammer engines as the base engines for the Holdens and Fords in the category.
Old 18-10-2011, 05:42 PM   #94
AMGC63
AMGC63's Avatar
The most watched motorsport category in the world....
AMGC63 is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2011, 05:44 PM   #95
PHANTMXR6
It's not an FG MKI.......
PHANTMXR6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willing to help out with useful advice in the technical areas of the forum.
Smile Re: Ford gear box's in all V8 race cars ?????
SteveJH, what's to say they won't use those engines?
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG...
Want to know how to do an A Service for an FG XR6T?
Look in this http://fordforums.com.au/showthread.php?t=11339404
Thinking of oil sampling your engine?
Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample
PHANTMXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2011, 05:49 PM   #96
AMGC63
AMGC63's Avatar
Yes.
Well according to the regulations a team can elect to run any N/A V8 engine they like, it will then be restricted to match the other engine outputs which effectively makes it a complete waste of time and money because all the development has been done on the current engines and introducing new engines would cost a small fortune to develop and make durable.
So there is no advantage to be gained and a heap of cost to bring one upto speed and a clean page on handling and weight distribution too.
Old 18-10-2011, 06:16 PM   #97
SteveJH
Development is a sunk cost, the cost of building a competitive engine is a repeat cost.
For some reason I have a feeling it would be cheaper to get a modern V8 up to 650-700HP then it is to get the current old technology engines up there.
For starters they have a higher level of development as a starting point.
I think one of the V8xtra shows was saying the components to build a V8SC engine from scratch were over $100,000, with a rebuild costing over $20,000? And with a rebuild required once every couple of race weekends.....
Old 18-10-2011, 06:21 PM   #98
AMGC63
AMGC63's Avatar
As it currently stands with the current 5.0l HMS/Ford engines the development money has already been spent, these engines are bullet proof @ 650hp.
For the new tech LS3/Coyote engines it would be ground up development costs... You'd have to start again and for zero competitive gain.
The build/rebuild costs for a new engine would be no less than the current motorsport engine, in fact probably more, particularly for a DOHC engine, and that's without and development cost.
The engines currently used are 100% dedicated motorsport engines, the engines you propose are passengercar engines... Big difference.
Personally it would be a massive risk to swap and a huge imposition on development costs for no gain.
Old 18-10-2011, 06:33 PM   #99
SteveJH
The Cammer is a road car engine?
Old 19-10-2011, 09:42 AM   #100
johnno3
Can anyone shed any light as to why V8SC are going away from the bulletproof Aussie Hollinger box to a transaxle box?
Current Rides
02 AUIII XR8
97 Kawasaki ZZR1100
2001 Honda VTR1000 SP-1
97 Honda XR400
Stored Projects
64 MK1 GT Cortina
66 Fairlane GT
johnno3 is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2011, 09:43 AM   #101
AMGC63
AMGC63's Avatar
Probably something to do with IRS and weight balance.
It will probably also end up cheaper using a combined Diff/trans/IRS pack than 3 separate working components.
Old 19-10-2011, 05:31 PM   #102
SteveJH
Just for the record, as far as I am aware the Albins transmission is also an Australian designed and built gearbox.
They are an Australian based and owned company I believe?
Old 19-10-2011, 08:30 PM   #103
PHANTMXR6
PHANTMXR6's Avatar
Cost, pure and simple.
