View Poll Results: Has your zf heat exchanger failed? POST 2012 CARS ONLY | |||
No |
85 | 92.39% |
Yes - cooling system serviced as per factory, using factory coolant |
6 | 6.52% |
Yes - cooling system serviced as per factory using different coolant |
0 | 0% |
Yes - cooling system not serviced |
1 | 1.09% |
Voters: 92. You may not vote on this poll |
#91 | ||
Have a look through JR's XR8 thread in the show n shine section. I think there were details in there.
2 users like this post: |
#92 | ||
a quick phone call to ford and yes my car is on the need to swap radiator over list
see how I go |
3 users like this post: |
#93 | ||
And if you paid for a transmission replacement send the receipts into Ford.
You should get reimbursed. At least for parts anyway, they may ask you to pay for labour if it was out of warranty.
www.bseries.com.au/mercurybullet 2016 Falcon XR8. Powered by the legend that is - David Winter. XC Cobra #181. 1985 Mack Superliner, CAT 3408, 24 speed Allison. |
#94 | ||
My F6 is 08. Runs an air cooler with a Deraile bypass thermostat which opens fully at 83c. My cooler has a fan which only turns on at 87c & has only ever done at the track mainly on return to the pits. May have turned on once or at most twice in heatwave temps during road use.
I have a light which shows when the fan turns on. Other than that I have no ZF temps monitoring but it's fair to say it could almost do without any cooling except for major crawling in very heavy traffic on a hot day & track days. Interesting that over 10% of respondents of post 12 cars have had an milkshake issue unless I read that wrong. Last edited by Blem; 31-03-2017 at 08:07 PM. |
#95 | |||
Rob
I'd say its running at closer to 0% failure for post 2012 cars. |
4 users like this post: |
#96 | |||
George
![]() Join Date: Jun 2015
![]() In answer to your interesting thought, The warm up strategy is simply using torque convertor slip to heat the trans fluid, from the monitoring I have done it takes 2-5 minutes (depending on ambient temp) of driving to get the ZF6 to 30C, torque convertor slip is also used extensively throughout the operation of the trans to smooth gear changes etc, the extra few minutes are here nor there, put your trans in perf mode and you will see it in action, it will not display perf on the dash until the trans gets to 30C. I have monitored my ZF6 in ambients of 0 - 43C for over a year now and have never seen the fluid temp drop, it always continues to climb at a steady and stable rate until reaching its max temp, on average that temp is between 45 - 65C, depending on distance travelled and ambient temp, the ZF6 self monitors its fluid temp and looks for steady temps once over 30C, it does not look for any specific operating temp above that, so it is happy operating at any temp, but the lower the better within that range, unless it reaches its max of 120C when it will go into "hot mode" to protect itself. Please read my posts in the thread link below showing extracts from my Ford Workshop Manual, Trans Section, which outlines in detail what I have been trying to explain here, I am getting pretty tired of trying to get my message across when people just need to read what I have posted previously. Thank goodness someone (SensationFG8) has finally got it ![]() I have posted my monitoring results and much more info here, includes a poll,https://fordforums.com.au/showthread.php?t=11441275 For those who are interested. ![]() Regards, George
BFWSM ![]() ZF ![]() ![]() R/Up 2019 ![]() ![]() PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI. 1997 Fairmont EL Ghia Tickford 4L Auto ![]() 1985 Falcon XF GL 4.1L Auto. 1979 Fairmont XD Ghia 4.1L Auto. 1971 Cortina GL Estate 1200cc Manual. Last edited by BFIIGhiaZF6; 31-03-2017 at 10:46 PM. |
#97 | |||
![]() ![]() Join Date: Jan 2014
And my trans temp is less than 30C, as I am able to monitor it on my XCAL4. |
#98 | |||
George
I can only go by what my 2007 BF11 ZF6 does and I have an air/oil cooler.
BFWSM ![]() ZF ![]() ![]() R/Up 2019 ![]() ![]() PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI. 1997 Fairmont EL Ghia Tickford 4L Auto ![]() 1985 Falcon XF GL 4.1L Auto. 1979 Fairmont XD Ghia 4.1L Auto. 1971 Cortina GL Estate 1200cc Manual. |
#99 | ||
BA/F6 BF/F6 SSV/R TTG
You know what they say
It's a bit like this George
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
#100 | ||
#101 | |||
Rob
you think that because your car runs a heat exchanger, that nothing has changed and your findings are still relevant? you also have a sample size of 1, as far as your monitoring goes. |
#102 | ||
George
Ok, so your trans is happy running at 10-15C.
#103 | |||
George
I don't have a heat exchanger, I removed the heat exchanger and installed an air/oil cooler, what changed was I have no risk of "Milkshake" and trans is running cooler, why would my findings not be relevant to the majority of Falcons with air/oil coolers installed? It's a sample of ZF6 monitoring with a typical air/oil cooler setup, there are many other posts of monitoring done by others with similar results in my thread, can only monitor my own car, but is typical of any car with similar setup. If you take the trouble to read my thread you will see other supporting info similar to mine. The poll in my thread is also interesting if you would like to take a look.
BFWSM ![]() ZF ![]() ![]() R/Up 2019 ![]() ![]() PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI. 1997 Fairmont EL Ghia Tickford 4L Auto ![]() 1985 Falcon XF GL 4.1L Auto. 1979 Fairmont XD Ghia 4.1L Auto. 1971 Cortina GL Estate 1200cc Manual. Last edited by BFIIGhiaZF6; 31-03-2017 at 11:56 PM. |
#104 | ||
George
Thanks arronm, is getting that way, pretty tired of wasting my time on some of the closed minds here anyway, have said all I have to say here, cheerio all
#105 | |||
#106 | ||
ok this will throw a spanner in the works and get a few dislikes im sure.....
i ve done a test with my post 2012 territory (for when i get around to fitting a bypass cooler and it will get one before I tow with it..) and have bypassed the coolant lines to the heat exchanger... just running the trans fluid though it.. still gets air flow,and has been that way for 5 months now... there is absolutely no difference in performance/temps with the engine or trans...and now I can sleep well at night... if the heat exchanger does fail ill see an oil leak on the floor and that is all.. Previously on my other zf6 cars I have ran a bypass trans coolers... to get the same outcome..again makes no difference to performance/temps... dont over think the process..
T2 TE50 no:154 Narooma blue AU2 XR8 ute XR4 fiesta |
#107 | |||
#108 | |||
Rob
Due to personal circumstances, this car now needs to last me many more years so for my own peace of mind I fitted a new one. My car is also one of the first fg's, and the heat exchanger has had a couple of changes over the years so putting the latest one on was another reason. That was the reason for starting this thread and poll, to determine if later ones were better in the failure rate. I've never said there is no risk, but I believe the risk is extremely small. Lots of things we do in life have risk attached. The chance of you having a crash every time you drive are probably higher than the chance of heat exchanger failure. |
#109 | |||
George
![]() I too plan to keep my car long term, sorry for being a pain in the ****, I am an Engineer after all ![]() Regards, George
#110 | |||
Funny how your poll to determine the amounts of failures of latter heat exchangers turn into a ****fight! I assume now that everyone who was hammering gmoughton about his info about operating temps will now be hammering you about your "source at Ford" about sand in the engine blocks and your statement that the "heat exchanger has had a couple of changes over the years". ? Does anyone actually have any info about the heat exchanger design changing throughout the years? Has anyone apart gmoughton got info about the best operating temps for the ZF gearbox? Seems that some people are trying to shoot him down without have any facts to back up what the best temps are. |
#111 | ||
Ford knew about sand in the blocks, thats why they used turbo oil filters.
#112 | ||
George, what is your temperature at 240km/h on a -2°c morning?
#113 | ||
I have my old 2012 factory exchanger available to anyone that wants to dissect it for research purposes..
#114 | |||
Rob
while there may be no apparent negative impact for some cars/owners, all manufacturers choose to run oil/water coolers as they have to pass much more stringent testing, which would include a much broader range of conditions. |
#115 | ||
I suspect that for most car manufacturers it is cheaper to adopt the standard in-radiator, or engine mounted cooler (as per FG) systems than to mount a separate air cooler in front of the radiator and air conditioner unit as some of us do to eliminate the dreaded milkshake.
#116 | |||
George
![]() Some cool weather monitoring from my thread here, temps are lower, stable and within optimum operating temps ![]() https://fordforums.com.au/showpost.p...&postcount=555 https://fordforums.com.au/showpost.p...&postcount=400 and here, from old_mate https://fordforums.com.au/showpost.p...&postcount=413 Much more from mexicov and AGH also in Canberra, if you take the time to read it. Have also monitored oil temp, engine temp and all other temps and functions of the car, posted in my thread. Regards, George
BFWSM ![]() ZF ![]() ![]() R/Up 2019 ![]() ![]() PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI. 1997 Fairmont EL Ghia Tickford 4L Auto ![]() 1985 Falcon XF GL 4.1L Auto. 1979 Fairmont XD Ghia 4.1L Auto. 1971 Cortina GL Estate 1200cc Manual. Last edited by BFIIGhiaZF6; 01-04-2017 at 03:27 PM. |
#117 | |||
George
![]() 2005 ![]() Blocked one ![]() 2013 ![]() made in China, merely more layers in attempt to improve cooling capacity? Sorry about the scary pics, any more? Regards, George
BFWSM ![]() ZF ![]() ![]() R/Up 2019 ![]() ![]() PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI. 1997 Fairmont EL Ghia Tickford 4L Auto ![]() 1985 Falcon XF GL 4.1L Auto. 1979 Fairmont XD Ghia 4.1L Auto. 1971 Cortina GL Estate 1200cc Manual. Last edited by BFIIGhiaZF6; 01-04-2017 at 03:49 PM. |
#118 | ||
#119 | |||
Sure have. Some of us live in the bush.
You do realise there are still open speed limits in parts of this country. How about 160km/h? Any high speed testing at all? Quote:
#120 | ||
![]() Join Date: Jun 2007
So over these heat exchanger threads, just buy a manual, much more fun.
