14-02-2006, 06:09 PM | #91 | ||
OK, i think its time to clear a lot up. Saying that it was all standard was definatly a mistake. But the components that i listed that ARE standard, ARE all std. Other upgrades everywhere else are most definatly in place and that is why im arguing that this engine will last.
Mods it HAS: High flow walbro fuel pump, RIsing rate Reg, Retracted spark plugs with a 8 heat range, Head ported and polished, Decomped via chambers being ground out, AU head gasket (decomps a small amount also) I cant think of anything else at the moment, My point was with this whole thread, that you can infact cheaply turbo your EA-ED and get good results without spending thousands on aftermarket ECU and tuning. This setup is yet to be run on a dyno, But i can assure you i drive it every day to its limit and theres been no hint of any failures anywhere in the car... They CAN take it, im not saying that yours will.. im not saying to do what i've done, mine worked, yours might go bang. But for all you who were wondering, i've roughly 4.5k on the turbo setup, installation, headwork, and getting into calder and laughing at a lot of vl turbo's. There's two things i can see going bang if something possibly breaks, one is the trans, and two is the bottom end. I've had so much fun with it so far, and i would not be disappointed if the bottom end failed at this stage. Its cheap to replace and if i get another 6 months out of one, i would do it every 6 months. |
14-02-2006, 06:16 PM | #92 | ||
they call me Tibbo
atleast you have come clean ELf.... I wasn't overtly bothered by your initial claim as exhuberation on the time you nailed was clearly foremost on your mind.. Well done on the time mate and for clearing up the 'std' claims for the sake of all the other boosted e'series cars in the works
14-02-2006, 06:19 PM | #93 | ||||
14-02-2006, 06:24 PM | #94 | ||
I was told they were thicker, therefore lowering the compression a small amount
14-02-2006, 06:37 PM | #95 | |||
Quoting JMM:
"The (Ford AU MLS gasket) gasket thickness is .025" compared to most which are .060" this raises the compression about .3 in most cases...ie 9.35 to 9.65."
14-02-2006, 06:42 PM | #96 | ||
well there you go, You tell me why its not detonating, fkucked if i know
14-02-2006, 06:45 PM | #97 | ||
Last warning
how much has been taken out of the chambers?
also, did you ever advance the dizzy? a few degrees can make a hell of a difference
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
14-02-2006, 06:47 PM | #98 | ||||
Cant be too bad though if people have been doing it for as long as they say they have. BTW: Tuning doesnt have to cost 1000's. I talked to chiptorque and they said they had a program ready to go for 7lb boost. For $600 its not a bad option. I payed $500 for my ecu and tuned it myself. Definately not for everyone (you have to build the thing yourself), but it is a hell of a cheap stand alone ecu.
14-02-2006, 06:55 PM | #99 | |||
Negative on the dizzy, it hasnt been touched thus far. no idea on the chambers, i would have not a clue as to the compression right now. Everything's been a trial and error situation. So far trial continues, with no error in sight |
14-02-2006, 06:58 PM | #100 | |||
14-02-2006, 07:06 PM | #101 | |||
Maybe it setup to run extreemly rich to stop detonation
Dyno with AFR would be interesting Do you know what base pressure and ratio the reg is?
18-02-2006, 07:50 PM | #102 | ||
XF Ghia. All snorted out
12:1 rising rate reg by vortec. This setup is perfect for his engine, with the 12:1 on there it's going to be running pretty rich for all situations on that boost level. I think that EF's are not as good for turbocharging due to the lesser flowing injectors and their higher compression ratio as compared to the previous e series.
Map sensor itself will notice another atmosphere (14.7 odd psi) in boost before it drops back in frequency, as for the computer though it's still a mystery to me how far into boost reference tables it travels. Seriously, a rising rate reg and a walbro pump isn't much of a modification, engine mods and fuel system mods would usually run into the thousands for most vehicles if turbocharged. My mate's gsr lancer has had plenty spent on aftermarket everything for almost every part of the car. It's still yet to actually drive for more than 170km before dropping its guts. I think 50K is close to the mark for which he has spent thus far, including 3 engines and two rebuilds on the latest fitment. |
19-02-2006, 08:28 AM | #103 | |||
FPV GT Owner!!!
Anyhow, I would have to agree that the EFs dont take boost as well as the earlier models, well with stock everything anyway. I have to run a 60psi idle fuel pressure to get it to run safely up high, but you know what thats gonna do when off boost.... On 6psi with the 2800 stall and 3 inch exhaust i would say i have a high 13 sec car(based on what ive beaten here and there).. But you can just feel that the tune is all out of whack, and it definately needs recalibrating of the whole rev range. So ems is more important than simply gaining a few kw
Cars: - Ford Ranger Wildtrak - XY GT Replica - XB Coupe Project |
19-02-2006, 09:37 AM | #104 | ||
Not a bad car at all, the CC was hardly a chicks car, many successful rally wins - the toughest test on any car. 4G93T, was a factory turbo car.
I'd be changing workshops if 170km distance is the limit, there's your problem. |
12-03-2006, 02:59 AM | #105 | ||
Wouldn't an adjustable fuel pressure regulator and air fuel ratio meter be the go? How are some people running a 2:1 regulator and some running a 12:1? there is a huge difference. How can both of these provide usable air fuel ratios? An Autometer air fuel ratio meter fits nice where the clock used to be. Has anyone else checked air fuel ratios on the dyno with stock ecu and a turbo?
Good times, good mph, good enough for mid 12's. Must have a few Kw@wheels. Inspirational for the back yard Turbo Fellas. I Have GT42 (1.44 ex)to go on EF that has Bosch 044, and air fuel ratio meter, 3", chip (to be swapped for turbo program). Were the times intercooled? Go the Turbo E-Series Skyline Eaters |
12-03-2006, 02:00 PM | #106 | ||
snortingboost - i pulled a "map sensor out of range" DTC out of my car the other day - what conditions are required to set that code? im tending to think it was set because 9psi gets thrown at it occasionally, which is more than the MAP sensor can handle...
13-03-2006, 12:31 AM | #107 | ||
:lookedat: I have just checked out some air fuel ratios for a stock ecu turbo ford and they were sweet at low boost with the 2:1 regulator + pump.
