12-09-2011, 05:22 PM | #121 | ||
And this guy (focus36) used a pacemaker cheater harness to acheive the same effect: http://www.fordforums.com.au/showthr...1250385&page=2 - see post 36
12-09-2011, 05:58 PM | #122 | |||
Torquer
Also is there much of a difference between the stock and hi flow cat in terms of performance? I'd also be looking to change my turbo pipe in the long run.
2007 LT Focus TDCi S Bluefin Remap - K&N Apollo CAI - 2.5" Turbo-back Straight Pipe - 24mm Rear Sway bar - LT Zetec Bodykit - Black Projector Head Lights - LED Tail lights - DMB Overlays - Alloy Pedals - Scuff Plates - Sports Gear Knob - LV XR5 Springs - LV XR5 Wheels - Pirelli P-Zero Nero |
12-09-2011, 06:08 PM | #123 | ||
My method wasn't a pain at all. You just need a good drill!
The stock cat in a Focus will be restrictive compared to a high-flow cat. |
12-09-2011, 09:38 PM | #124 | |||
http://www.ebay.com.au/itm/300597669...#ht_500wt_1156
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
12-09-2011, 09:45 PM | #125 | ||
Yeah that will do, mine was prob a bit bigger and i had to cut several cm off each end of it.
Oh and don't forget you need hose clamps for each end as well there is some on the stock one you can steal if needed, but you'll need smaller ones for the 12mm hose too.
2010 LV Focus LX Titanium Grey - K&N Apollo CAI - 2" Cat-back Exhaust -18" Black with machined front RS rims - DRL/Halo Headlights - Eibach prokit springs - Front Strut Brace - Black XR5 Spoiler Plans: Whiteline Rear Sway bar |
12-09-2011, 10:01 PM | #126 | ||
Yep, no worries. I picked up some nice looking (Chinese made) hose clamps at Bunnings.
13-09-2011, 10:52 AM | #127 | ||
Rims done, now to wait for the springs I noticed the rear left ford logo is loose, is there a way i can make it so it doesn't spin around..?
13-09-2011, 10:55 AM | #128 | ||
Nice wheels mate, they look great. Will look even better when the springs are in. What rubber did you go with?
13-09-2011, 10:57 AM | #129 | ||
I got falken tyres, 250 a peice, was tempted to get some yokos but that's an extra 55 each for the cheap ones..
13-09-2011, 01:14 PM | #130 | ||
Looks good, Conrad.
Btw, is there any provision in the Apollo for water drainage? The standard airbox has a few holes in the bottom, and the Apollo tube will be set lower down, so the risk must be a bit higher. I'm thinking I'll put mesh over it (maybe a flour sifter or sink strainer, or some such), but I'm concerned about water ingestion.
13-09-2011, 07:28 PM | #131 | |||
As far as i can see there's nothing besides the filter itself :P but I'm not running the hose off it anyway, gotta shorten my pipe a bit more.
13-09-2011, 09:28 PM | #132 | |||
13-09-2011, 10:17 PM | #133 | ||
Has anyone found a different engine cover I could use? Just something nice looking rather than the big black standard one the lx comes with.
14-09-2011, 12:43 AM | #134 | ||
Hi flow cat will make quite a difference (in my mechanics opinion you would be silly to do the exhaust and leave a standard flow cat in there) . And that pacemaker cheater harness was about $85 from my local exhaust place. (must get around to putting up pics of the whole job!).
Also totally changed the intake on mine since. Got rid of that stupid lower airbox and have cold air coming from a pod sitting where the passenger side fog light cover (used to be).... Left the stock airbox in the engine bay, but....... there is no longer anything in it so it looks totally stock if anyone ever wonders. Freeing up the air intake was a big must since having the whole exhaust opened up (4-1 header, hi-flow cat and 2.5" all the way through, same as DZ) and could tell a definite difference once intake was completed I think it could still do with a tune at some stage though... ? |
14-09-2011, 12:48 AM | #135 | |||
Still need pay to get the springs in and i'll get them to put my front strut in when i get it all as well, I don't want to mess with any of the suspension stuff myself just incase something goes wrong.
14-09-2011, 09:48 AM | #136 | ||
Woke up early and decided I was going to finally fit the hose onto my intake!
Sooo here's what i have come up with, it just hangs straight down, had to bend it straight down there is bugger all room to play with, gonna go see if anything goes wrong later on before work. I was originally wanted to have it coming to the front grille, but it simply wont bend that way so this will do for now until i work out another solution.
14-09-2011, 10:30 AM | #137 | ||
A few questions for you...
1. Is this noticeably better than stock, even without the hose attached? 2. Is it possible to turn it so the top of the cone faces more towards the front of the car? That might help with your aim of heading for the grille. 3. What does your partner think about you getting up early on a weekday to do this?
14-09-2011, 10:54 AM | #138 | |||
The main reason I ran it without the hose was the sound is more noticeable with it off, with the hose it comes out of the end of the hose more, but now with my exhaust I don't really hear it too much anyway :P 2. In the pic you can see to the left that's the front of the car, just behind the headlight so it can't go anywhere unless i can a pipe that goes back then faces forward, could be possible but would need to get it made up properly so would be a big S shaped pipe. 3. I'm only 22 and living at home so no partner to worry about, dads over seas with work, step mum had left earlier and i just took my sister up the road to get her bus so the only people that would be worried are the neighbors when i started it up to make sure it still ran
14-09-2011, 11:42 AM | #139 | |||
14-09-2011, 12:02 PM | #140 | ||
That's OK, buddy. His car won't have lost $30k in depreciation in a few years' time.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. Last edited by MR_LON; 14-09-2011 at 03:36 PM. Reason: removing quoted post |
14-09-2011, 12:07 PM | #141 | ||
not here much anymore
Out of coffee this morning obviously.
RAM 1500
14-09-2011, 01:17 PM | #142 | ||
Torquer
I ran my intake hose to the passenger side wheel arch, it sucked in a bit of water once when it was sticking out too far so I recessed it a bit.
Works well for the most part, and being outside the engine is nice and loud
14-09-2011, 01:20 PM | #143 | ||
You have such a bad strike rate on these forums. All your threads end up getting locked by the moderators. Can't you take a message?
http://www.fordforums.com.au/showthread.php?p=3729665 http://www.fordforums.com.au/showthread.php?t=11332785 Last edited by MR_LON; 14-09-2011 at 03:38 PM. Reason: remove quoted post |
14-09-2011, 03:45 PM | #144 | ||
Lol what happened? I'm assuming somone said i'm silly for modding my focus, honestly to each his own, i've had it for a year now since new and i've always wanted to make it "mine" so that's just what I'm doing.
Now back on topic i've got something unknown waiting at the post office for me when i head home tonight
14-09-2011, 04:08 PM | #145 | ||
ConradP - My exhaust fitter ordered the pacemaker cheater harness from pacemaker. I'm not sure what type of cat you are trying to get fitted. About all i can certainly say is that it works with the x-force hi flow cat (which your dealer should be able to order from them).
14-09-2011, 04:10 PM | #146 | ||
and the cat itself was around $280
14-09-2011, 05:16 PM | #147 | |||
14-09-2011, 07:09 PM | #148 | |||
Barra Turbo > V8
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
14-09-2011, 07:09 PM | #149 | |||
I'll check it all out in a few weeks, when i get my springs and whatnot. I saw you put the rear strut in, I was thinking of doing that but then saw on the LV that it is lower and being that it makes the boot size halved, I've ordered a front strut from euro parts so that should arrive with the springs, and I was going to look into a rear swaybar to stiffen up the *** end. Oh and today I don't know what's happened but it's as if the car has only just accepted that I've got a new exhaust and wanted to just spin the wheels, got sideways going around a roundabout a bit to quickly, and I go around it every day on the way to work and that never happened before. Oh and before I forget here's what was waiting at the post office for me, just something small. Adds a little bit more class to the LX name :P Can't wait for the new headlights though, they have a glossy black backing rather than the chrome on the stock ones, will go nice with the colour scheme of the wheels and if I ever end up getting a Xr5 spoiler(I'll be painting it black)
2010 LV Focus LX Titanium Grey - K&N Apollo CAI - 2" Cat-back Exhaust -18" Black with machined front RS rims - DRL/Halo Headlights - Eibach prokit springs - Front Strut Brace - Black XR5 Spoiler Plans: Whiteline Rear Sway bar Last edited by ConradP; 14-09-2011 at 07:17 PM. |
14-09-2011, 07:39 PM | #150 | ||
May I ask if you know the cost of the headers as well focus36?
