Closed Thread
Old 10-07-2014, 03:34 PM   #121
2242100
Default Re: FPV GT-F outpowers HSV GTS The Aussie horsepower king has been identified & we are surprised as any1
Originally Posted by jasen View Post
That's interesting and it explains why the HSV that Drive tested got to 190 kph at 400 metres compared to the 186.7 kph that Wheels got in the current issue from the Ford, and that's in spite of the HSV apparently being around 40 kg's heavier.
Looking closely at the Dyno graph, it seems that the HSV is stronger below peak revs as well as having more power at the end.
The first HSV tests made it look to me that the car was well short of it's claimed power,but this Dyno result plus the Drive 400 metre end speed have changed my mind.
2242100 is offline
Old 10-07-2014, 03:35 PM   #122
LoudPipes
The difference between a 19”and 20”rim can be negated by the wall height of the tyre you fit.
Example a 20” tyre will usually have a lower profile than a 19” tyre leaving the rolling diameters to be almost identical.
LoudPipes is offline
Old 10-07-2014, 03:46 PM   #123
ray38l
Originally Posted by teak81 View Post
Does RAY38L stand for Ray 3.8 ltr ?
that is correct. in my defense it was over 9 years ago when i joined and these days i don't care so much for brand rivalry.
I come to this forum because its the only car forum that still has decent discussions going on.
ray38l is offline
Old 10-07-2014, 04:11 PM   #124
2242100
Originally Posted by Peter B - CV8 View Post
I'm a bit confused (easily done...). Was the dyno result of 330rwkw for the Ford achieved during temporary "overboost" - or is this the normal output than can be expected at all times ??
I believe it was 330 kW for the HSV and 311 kW for the Ford.
As far as overboost is concerned, I have a standard untuned FG XR 6 Turbo that doesn't get nursed and it's overboost is normally available unless the engine and/or the transmission gets a hard time immediately before a test. If that happens then acceleration slows by at least 10%.
Not surprising as it gets up to around 18% of overboost.
2242100 is offline
Old 10-07-2014, 04:19 PM   #125
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
So if this is Fact then why the issue of rwkw?
Auto GT-F 1835 kg, 187 kph trap speed.
Auto GTS 1842 kg, 189 kph trap speed.
FPV GT-F 5.0 S/C Auto - (note run number 7)
HSV GTS 6.2 S/C Auto - (note run number 2)
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline
6 users like this post:
Old 10-07-2014, 04:46 PM   #126
Bent8
Long live the GT !
Bent8's Avatar
Originally Posted by Rodge View Post
Sorry but I can't remember. 20 inch rims and tyres will generally weigh more as you've suggested so I guess you get more losses from the centifugal forces required to spin the extra weight up. Youv'e also got far bigger rear brakes on the GTS and anything that adds to rotational mass will reduce the dyno result.
If the car being dyno'd only makes 300 odd horsepower, you will probably notice a difference in rear wheel outputs but I highly doubt a (factory claimed) 577hp blown V8 is going to be affected by larger wheels or brakes..
2018 Ford Mustang GT - Oxford White | Auto | Herrod Tune | K&N Filter | StreetFighter Oil Separators | H&R Springs | Whiteline Vertical Links | Ceramic Protection | Tint
"Whatya think of me car, XR Falcon, 351 Blown Cleveland running Motec injection and runnin' on methanol... goes pretty hard too, got heaps of torque for chucking burnouts, IT'S UNREAL !!" - Poida
Bent8 is offline
Old 10-07-2014, 05:06 PM   #127
burnz
VFII SS UTE
burnz's Avatar
the GTS is 1937 KG ballpark 2T with driver.
GO SOUTHS
burnz is offline
Old 10-07-2014, 05:08 PM   #128
Batmobile
Talking Re: FPV GT-F outpowers HSV GTS The Aussie horsepower king has been identified & we are surprised as any1
Interesting to see the flywheel torque on the GTS declining..Looks like there is a gap between it generating the power and then being able to feed it down the line to the rear wheels. This
is probably why on the engine stand they had been able to claim 430fwkw .
Forum members in the know will be able to explain this I am sure. I will sit tight.
Batmobile is offline
Old 10-07-2014, 06:17 PM   #129
Rodge
Rodge's Avatar
Gotta laugh some days.
So last week one of the Wheels guys popped his head over the partition and asked me to recommend a place where they could dyno a new HSV GTS and an FPV GT-F. After just doing a blower install story at VCM Performance, and being impressed with their facilities, I recommended them. Then I asked if they were going to film them.
"We weren't but I guess we should", was the answer.
So I decided to go along and video the whole thing with a view that Wheels would do "their" video and Street Machine do something different.
We drove both cars (both autos) to VCM last Thursday and put them on them on the dyno. The GTS went first and made 330rwkw, which gave the GT-F the best chance to cool down. Then the GT-F ran 311rwkw and we were impressed. The HSV made about what we expected and the Ford made more than we expected. It was about as honest and simple of a dyno test I've ever seen, and the idea was that we would both edit our vids and post them at the same time on Monday.
Then Ford got wind of the result and they weren't happy. So Wheels delayed, and we were told to hold off as well. The phone calls continued all through today as well - I can't reveal the contents of those calls, I'd probably get fired. Let's just say Ford were VERY unhappy. Ford reckons the GT-F should have made more.
Then mysteriously a rival publication went to print with very different figures today (hmm, wonder how that happened) and the decision was made to pull the trigger on our results. Then everyone lost their minds!
Personally I don't see the drama. We all know Ford has underquoted the Miami-powered GT for years. The GTS made about what you'd expect and the Ford made lots more than we expected. Ford should be happy, everyone should be happy, but nope. Apparently everyone believes that an unintercooled 5-litre should make more power than an intercooled 6.2-litre.
You can't post that on a Ford Forum, that'll have the punters in an absolute lather.
Isn't it funny that we have the dedicated press car GT-F 001 manual making close to 350 rwkw's and then a non-press car GT-F-014 auto only making 311 rwkw's,
Nearly 40 rwkw's lower for an auto non-press car !! He're we're comparing two non press car auto's GTS and Gt-F and the HSV beats the Gt-F by 19 rwkw's.
Which test do we believe ? Direct Auto to Auto transmission comparison and non press car to non press car seems to me to have more credibility.
Not only that but I can't help wondering why would Ford get their panties so twisted about this seeing as they claim all the GT-F's are sold ?
Something isn't right.
Rodge is offline
Old 10-07-2014, 06:28 PM   #130
fgpsi
Yes we all know you're a GTS fan boi Rodger
fgpsi is offline
Old 10-07-2014, 06:30 PM   #131
prydey
Rob
prydey's Avatar
there are no press cars. cars 001 and 014 will later be auctioned off along with 500 (i think).
car 001 is a manual and is blue.
car 014 is auto and is smoke.
the GTF used on the dyno's is the same car, no 014.
the GTS used by motoring.com.au is the same one that Drive used to run the 12.1 400m.
the GTS vcm used was a different one again.
credibility rodge - you don't have a lot when you post things like that.
prydey is offline
8 users like this post:
Old 10-07-2014, 06:38 PM   #132
Rodge
Rodge's Avatar
Its GT-F 001 that's been doing the rounds though, regardless of whether you want to call it an official press car or not that's what it's being used for, until its auctioned off.
Rodge is offline
Old 10-07-2014, 06:45 PM   #133
prydey
Rob
prydey's Avatar
wrong again. GT-F 001 is a blue manual.
the dyno car is the auto GT-F 014.
facts. you're missing them.
prydey is offline
Old 10-07-2014, 06:55 PM   #134
myts50
myts50's Avatar
Awesome too see the rivalry has not died down about time the red brigade were shut down imagine the power output if it had 351 cubes!!
FTe Venom T2 TS50 man Build # 23...
Sunroof , tri y's , custom twin exhaust, Hooker mufflers
FPV BF FORCE 8 Ego Build # 26
........... S/Steel xforce exhaust,Blue Power air filter, ZF trans all tuned by "Autotech", 254rwk ,brembo's,factory sunroof
myts50 is offline
Old 10-07-2014, 06:59 PM   #135
Rodge
Rodge's Avatar
GT-F 001 manual, yes I know its the blue one dynoed up at close to 350 rwkw's by one mob, (that's the one people on other forums are calling the special press tune).
GT-F 014 Auto got only 311 rwkw's by another outfit and that's the result Ford got their panties in a real twist about and tried to censor the result.
Those are the facts so far.
Rodge is offline
Old 10-07-2014, 07:02 PM   #136
Smoke Pursuit
No Rodge the blue one hasn't been dynoed, only build 14 the Auto.
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is offline
Old 10-07-2014, 07:04 PM   #137
rancidpunx
FPV GTR
rancidpunx's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For technical contribution to all things car-care related. And helping/advising forum members with the best possible information.
Rodge only the Smoke coloured one, 014, has been dynoed. It made 311 with Wheels and 348 with Motoring.
Edit: Brent beat me to it.
- FPV GT RSpec -
- Chill SZ Territory Titanium -
The Family Bus
- Veridian Green PJ Ranger XLT -
The Work Truck
rancidpunx is offline
Old 10-07-2014, 07:04 PM   #138
futura
futura's Avatar
What about the motoring dyno run of 348.6 rwkw?
GTF Smoke with Black stripes.
futura is offline
Old 10-07-2014, 07:09 PM   #139
Rodge
Rodge's Avatar
I need another beer
Rodge is offline
Old 10-07-2014, 07:10 PM   #140
Smoke Pursuit
300 c forum not keeping you busy?
Old 10-07-2014, 07:22 PM   #141
BHDOGS
A resounding win for the ford the gts truly is old news
BHDOGS is offline
Old 10-07-2014, 07:31 PM   #142
prydey
Rob
prydey's Avatar
oh dear.
i won't say anymore as you've already been corrected enough.
i will add that your timeline is also a bit out.
wheels dyno'd the GT-F first. Ford got wind of the results and weren't happy as they knew the car had more in it. they requested the results not be published until further testing, hence the delay on the wheels site. motoring.com.au then stepped up and ran their own tests (with the same GT-F, but different GTS) which returned a much more favourable figure. wheels then decided to go to press with their figures to beat them to the punch, despite their discussion with the manufacturer. in their haste to get the 'scoop' they have ended up with egg on their face.
now they are trying to play the victim and throw doubt on the higher reading.
the thing they don't realise is that many ford fans aren't annoyed that it didn't win the first test. they were annoyed at the apparent lack of awareness about the ford product, and the trend that has been set to date with the miami engine. a standard GT will dyno north of 300 on nearly every dyno in the country. this was the issue.
prydey is offline
Old 10-07-2014, 07:50 PM   #143
Windsor220
Now Fordless
Windsor220's Avatar
Surely Ford engineers would have a fairly good idea what sort of power to expect at the rear wheels. If it was a fair way off I dont blame them for saying something.
Windsor220 is offline
Old 10-07-2014, 08:05 PM   #144
mcnews
Trev
mcnews's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Trev has owned several boosted fords and has really contributed a lot of info on them. His posts in the bike section are also very helpful. I think he should be recognised as a technical contributor.
Just admit it Rodge, you are spewing you bought your yank tank and wish you had a GT-F and like normal when you don't have something you are justifying it being worse. Like you did with F6 being better than supercharged GT for ages, then you bought a GT and the F6 is terrible... Now you have a 300C everything else is crap and you feel the need to come in here and fight the good fight for HSV..... Seriously.....Why.......... You may be able to fool yourself, it is easy to fool a fool, but you can't fool us.... And you know I am certainly no one-eyed fanboy, but really just coming in here to poor hate on the GT-F is getting very tiresome. It is like me wasting my time going on to a Holden forum to talk crap about the GTS, thankfully I have better things to do in life.
Trev
(FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension)
mcnews is offline
Old 10-07-2014, 08:15 PM   #145
mik
mik's Avatar
i would guess that a 20 inch rim would be heavier than a 19 inch inch rim regardless of the outside diameter of the tyre, probably not a huge amount in it, but all these things add up..
mik is offline
Old 10-07-2014, 08:25 PM   #146
1TUFFUTE
1TUFFUTE's Avatar
Common we all know rodge is a good bloke....just gets on a train of thought sometimes......same as me, I get way to passionate and end up arguing for pages defending ford about something. it's all good.
And thanks prydey for clearing that timeline up.....I was seriously getting lost
I'm loving that ford is defending its pride with the power readings
1TUFFUTE is offline
Old 10-07-2014, 08:42 PM   #147
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
Yep, loving that Ford are standing up for the product. Should've done that far more often.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline
Old 10-07-2014, 08:55 PM   #148
furiousgibbon
these dyno graphs are pretty clear. GT-F may have pipped the GTS in peak power, but the torque delivery of the GTS is much stronger. It would feel significantly more powerful across the rev range, but the GT-F would feel as though it's getting stronger as the revs climb. I prefer the latter as it has a more urgent feel and revving it out would be more rewarding, but for day to day use, the GTS would feel better.
The lack of an intercooler on the GT/GT-F really kills it for me, I wouldn't want to see dyno runs done in the middle of summer... on the flip side, the GTS looks kinda nasty, and I'd expect more from its additional displacement/fuel consumption. I wouldn't own either of them, I'd pick up a GT, water/air intercooler, exhaust, remap, coilovers and have enough money spare to fuel it for the next 5 years. Anyone buying a car to store it and sell it at a profit later should have that car taken off them.
furiousgibbon is offline
Old 10-07-2014, 09:02 PM   #149
ford man xf
If the GT-F is making around 340rwkw, what would that equate to flywheel kw wise?
It's pretty amusing though, considering the XR8 next year will be reborn with the same spec engine as the FG GT, could you imagine being a HSV owner forking out all that money on a brand new GTS, then pulling up to the lights next to a FH XR8 and then sitting side by side all the way to 100 and beyond
Even more embarrasing would be the lower spec variants of the VF in HSV's stable getting whopped by a factory XR8.
ford man xf is offline
Old 10-07-2014, 09:08 PM   #150
tranquilized
The bias from so many fan boys on this forum is absolutely hilarious, but embarrassing at the same time. As soon as Rodge comes out with some perfectly reasonable points he's savaged by the blind faithful.
The heavier duty the driveline, the more power it'll suck. I clearly remember mates cars back in the day that ended up considerably slower after they'd installed a 9" diff. The GTS figures are right on the money for what you'd expect from 430kw at the flywheel.
As for Wheels magazine, is it their fault the GT-F they had on the day was putting out less power? Did it have a technical issue? The same car produced near 350rwkw's later on so obviously something was done to the car by Ford to improve it's numbers.
It's all such a non-issue anyway. Who really gives a ***k? They are both great cars and we should be proud of the quality of the last of the line Aussie muscle.
tranquilized is offline
Closed Thread
