#121 | ||
Diesel Sniffer
Also just to make 100% clear DO NOT open those injector fuel lines if the engine has been cranking or running, allow minimum 45mins for fuel pressure to go.....
#122 | |||
![]() Join Date: Oct 2006
https://www.youtube.com/watch?v=jBc7zRKHZrw https://www.youtube.com/watch?v=I75NYPgy328 https://www.youtube.com/watch?v=JsYI8Zp99hA https://www.youtube.com/watch?v=ahqBYGmTLrA
regards Blue Last edited by aussiblue; Today at 06:38 PM. |
#123 | |||
Diesel Sniffer
#124 | |||
And yes it's the same guy that serviced my previous injectors. But when getting those old injectors back and changing the intake manifold gaskets, the car never started again, thinking putting the injectors straight in without bleeding is maybe the reason now it didn't start. Oh and only then did i start getting code 'Low pressure on fuel rail" as mentioned in one of my earlier posts. Last edited by JustBill; Today at 07:47 PM. |
#125 | ||
Diesel Sniffer
The main pointing i see is remove the plug on the H.P pump so it can create more pressure than the combustion pressure to keep the nozzles in the injectors closed ,so that when the electrics operate the valve they are in the closed position with a head of fuel behind them.
