#1621 | |||
![]() Join Date: May 2008
The Fleet - 2016 PX MK II Ranger Cool White 2008 FG XR6 Sensation Blue 2014 FG X XR8 Emperor Red 2024 Mustang GT Race Red The Departed - 2002 T3 TS50 Blueprint 2017 Mustang GT Race Red |
2 users like this post: |
#1622 | ||
you two do realise there is an strong supporter of this page quietly sitting at home having a heart attack and perspiring around the collar at the care, love and attention you give your mowers. Shame on you.
![]() Should we start a sub series the worst cared for mowers out there ![]()
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent |
3 users like this post: |
#1623 | ||
An oil change, blades or a spark plug wont fix rust. They wont fix a lot of things.
#1624 | ||
Yep but it only cuts a small green lawn,so nothing to really wear them out.they are getting past needing replacing,but I don’t know whether the body condition warrants spending the money,but I might get the welder and some steel plate going and give it a big birthday (aircleaner,plug new oil and blades,even wheel bearings if needed)
#1625 | ||
Sorry DFB FGXR6 Wife just informed me I put new blades on about 10 years ago,but I can assure you blades and carb are the only parts replaced
4 users like this post: |
#1626 | ||
Did she remind you of exactly how much you spent on them, too?
![]() I can believe the blades lasting, your area is quite lush mostly. |
#1627 | ||
Even her memory isn’t that good lol
#1628 | ||
Before I get stuck into a full teardown of the new-to-me Mac chainsaw, can anyone advise if the clutch side is keyed to the crank or just a friction fit?
#1629 | ||
So its been a couple months since i got the edger attachment for my whippersnipper/multi doodle. Maybe used it 2 or 3 times. So very much a 1 off use kind of purchase. But its made making the place look good so much easier having clean cut edges. Quick run down the sides with the whippersnipper, do the guts with the mower.
Yeah, its low grade domestic equipment, but the $86 edger attachment works good enough and im not upset about buying it. |
#1630 | ||
Mud grooming here today, it’s the new lawn mowing for Sydney.
#1631 | ||||
Regular...with metamusal
![]() Join Date: Oct 2009
i had something similar ...... stopped using it due to me cracking the shiiits with the fuel/line side of things - so went electric & only have to worry about the line 'disappearing' ![]() bought an edger from Aldi a few years ago now [4 stroke] ...... only hiccup was the fuel line 'perishing' otherwise all good. it uses a flat steel blade of which i can make up as bunnings no longer sell blades for it!. ![]() Quote:
currently parking on the front part of the driveway/road due to front lawn being a bit wet . . . ... plus someone errr whinged ![]() |
#1632 | ||
Have had the Mustang 750iS for nearly 5 weeks now, it's been getting plenty of use at home and on jobs.
The starter battery was fully charged after assembly and was sitting on half charge before popping it on the charger this afternoon. Pretty happy with that, I could have stretched it further but that's not how I roll. ![]() ![]()
#1633 | |||
So the edger attachment isnt the complete tool, just the 'power head' you put on the end of the shaft of the whippersnipper. So saves needless extra equipment/space. Considering realistically you dont need to edge very often at all for personal domestic use it kinda makes sense. Also, from personal experience, the longer you leave small capacity garden equipment sit, the more maintenance is required. My 51.7cc ozito, heavy as it is has been really good. For a cheapy it starts 1st time every time. It has a hedge trimmer attachment that i never use, a 10" pole saw attachment that the 1 time i did use it was handy, the whippersnipper attachment which is straight shaft that i like and the edger. Only thing i have really changed on it was the plastic line spool. That thing just didnt bump too well and the bump knob was plastic. Also it was 2.4mm line. So i ebayed a replacement line spool that has a metal bump knob and takes 3mm line. Plus its a quick respool one which is really easy. |
#1634 | ||
Mower design; HELP
I would appreciate feedback re. typical blade height above lower edge of skirt. What ever type of rotary mower but in particular a side delivery slasher type machine. |
#1635 | |||
A little Victa Utility 460 would be good for smaller spaces, very light too - https://www.victa.com/au/en_au/produ...60-725exi.html I had a Masport 530 Utility with the big 850 engine, it was a beast - https://masport.com.au/outdoor-garde...utility-530-ic Also look into Bushranger Utilities - Kohler - https://bushrangerpe.com.au/browse-p...-utility-mower Honda engine - https://bushrangerpe.com.au/browse-p...-utility-mower
#1636 | |||
The reason is if this dimension is significant the mower is hard to push when on the lowest height (cutting a lawn for example) and if it were too small it would not offer much protection to the operator when slashing a jungle at the maximum height setting. |
#1637 | ||
Just spent 2 full days on a mates bush block in halls gap, clearing fallen trees and branches. I took my petrol huski chainsaw and my 530iPT5 huski battery pole saw. I used the petrol one for a total of 1 hr across the 2 days, if that doesn’t show you how good the battery one is I don’t know what will.
Some takeaways are: -cutting logs at ground level with a polesaw is so much easier, you are 2 meters away from all the wood chip spray. -battery power doesn’t scare away the wildlife like petrol (it was a land for wildlife property). -I ran it in eco mode most of the time, the slower speed keeps the chain cooler. -it’s only a 250mm blade, but I was cutting gum logs 40cm across, from both sides. What an absolute beast the husqvarna is, I’m in love.
____________________ 2024 TOYOTA HIACE 2019 LDV G10-GONE THANKFULLY 2009 Mitsubishi Express-GONE 2011 Honda Jazz ____________________ |
5 users like this post: |
#1638 | ||
Mate, if you aren't filling your socks with wood-chip, you ain't in the game ;-)
Steve Current rides 2012 Mondeo Titanium wagon (TDCI) Moondust silver 2016 Focus Trend, 1.5ecoboost, 6sp manual. Frozen white Previous 2004 Berlina Wagon (LS1) Vespers Blue 1995 Camry 2.2, white 1971 Ford Fairmont wagon 302w, C4 Polar white 1971 TC Cortina, 2L 4sp, Ermine white |
#1639 | |||
RS The Faster Fords
![]() Join Date: Feb 2014
Its that time of year again...
![]() Cleanup usually takes a team of 4 about an hour a green to rake, shovel and sweep the spoils. Times this by 22 greens over 2 days it makes for some longs days of work. There is a solution though, drumroll.... Introducing the core harvester. ![]() This particular machine had been abandoned after the previous users claimed it didn't work. We've had a couple of shed days due to thunder storms of late so it was dug out and commissioned for service. After a check over it was attached to a tow rig. So far so good, the electrics and hydraulics all worked so it was taken for a test run. At this point it was confirmed, the machine wouldn't pick up a thing. We set about playing with the roller height and brush angle but still it wouldn't pick anything up. The brush is heavily shrouded so we decided to remove these to have a closer look at what the brush was doing. On start up we were greeted by a shower of cores being fired from the front of the machine. This wasn't right they're meant to go backwards into the hopper. Its at that moment we had a sinking feeling, could we have hooked the hydraulic couplings up back to front? With them swapped over the brush was now working the right way but the other hydraulic functions lift, dump and tow bar swivel were now back to front. After putting them back the way they were the hoses at the brush drive were swapped over and bingo everythings working like it should. It took a couple of hours work on a stormy day but this machine will be worth its weight in gold come renovation time.
Escort RS2000 Restored factory a/c and alloys. TD Cortina Unrestored 35 000km 6cyl manual. Mk1 GT Cortina Project. FG XR50 Daily. |
#1640 | ||
B1 - J & D Services
![]() Join Date: Aug 2005
Not the first time a machine has been assembled incorrectly from the begining. Well done on sorting it!
Mr. Brett Johnstone. ![]() 2005 Mitsubishi Magna Wagon 2000 Ford Falcon Wagon Egas 1999 Subaru Imprezza Sportwagon 1998 Holden Suburban 2500 1995 Land Rover Discovery TDI 1994 XG XR6 Longreach 1983 Holden Rodeo 1975 Datsun 120Y wagon 1970 MG Midget 1967 Rover 2000TC Soon: Model T. |
#1641 | ||
It’s good to have a day where you can stop chopping the wood, and sharpen the axe!
We don’t get enough thinking time these days, and thinking is often NOT rewarded by management.
#1642 | ||
I scumbagged my mate yesterday. His mum lives next door to me, was helping her re pot plants. Anyhow, she pays for her lawns to be done, however, that mob never does the strip between the boundary fence. So her house to the fence is only 4 to 5 foot wide. Its just the bit no one goes, it has the meter box and hot water unit. Cant run a mower through there due to obstacles.
If i made the offer to my mate and if his mum wasnt there, it would be a flat out no. But, thats why i scumbagged him. Offered to lend my whipper snipper, his mum was appreciative, so my mate gave me the look of dissaproval. Realistically it took my mate 4 minutes to do a pretty good job knocking out 2 foot tall grass and weeds. What really impressed me is i always say it'll start. My whipper snipper always does when no one is watching me. When i handed it to my mate and said it'll start he called bs. 2nd pull it was running. Not bad for a 2 stroke that has not been started for 5 weeks. |
#1643 | |||
T3/Sprint8
![]() Join Date: Jan 2005
Interesting re the Toro, seems like the previous guys couldn't work out the instructions or visa versa.... Yer I see this process at the course's I frequent, sure leaves alot of cleaning up, I see piles of it put aside out of the way. Hows your greens couring going what stage you ate ?
#1644 | ||
For tall, wet and sticky clover, there is only one choice...........
![]() ![]() Lots of smoke, lots of noise........ lots of smiling from me.
#1645 | |||
RS The Faster Fords
![]() The course was on the verge of bankruptcy with only 3 staff left so a 'whats the point' culture crept in and alot of machines were just parked up as they failed or in this case needed some gremlins sorted out. We're back up to 7 motivated staff now. Green coring starts next week, over the past month we've had a soil and leaf tissue analysis done and have been applying foliar fertilizers based on the results and deficiencies aswell as making some pH amendments. We'll start with a light vertimow, followed by coring, sweeping, adding compost to known dry areas, topdressing, brushing and lastly a granular fertilizer. Its amazing how quick they come back from a major renovation like this, we expect them to be ready for tournament play a month later. I get some pics as we go next week.
#1646 | ||
T3/Sprint8
Love your course storey bringing it bank to good playing condition……..
Great to hear of the growing staff and enthusiasm that’s the key. Sydney courses have began green coring and top dressing but obviously climate here is already turning and temps starting to warm lightly. As a player you dislike it haha but got to be done for the better. Yes please keep the updates and pics coming ! I admire the work done at courses. Sent from my iPhone using Tapatalk
#1647 | ||
where can I buy the dark green wash plug connector for a john deere rideon mower. its the part that connects the hose onto the deck.
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent Last edited by Tonz; 23-03-2023 at 09:58 PM. |
#1648 | ||
#1649 | ||
no sorry same as.
! mower at home has this, the other at work is missing this bit and I am not shifting it from one to the other. Bunnings has the other connector piece, that screws inside the black end and has a hose clip on connection the other.
#1650 | ||
Found. when you know what the part is called the fleabay is your answer
