Old 18-02-2013, 12:41 PM   #1651
poppa smurf
poppa smurf's Avatar
Default Re: who amongst us have gone solar
not sure about "shouldn't matter how it looks" mate.......solar is up there for the long haul...15 to 25 years are some of the figures bandied around even a slight amount of movement X friction X time = trouble
I tidied up a few areas on my install but I really think it should be done properly in the first place.....sloppy install = sloppy????
the junction box should have been at least screwed to the beam.....cable ties are prone to breakage, cables left dangling are a fire risk
G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II...
may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon!
poppa smurf is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2013, 12:43 PM   #1652
Stagg
Stagg's Avatar
Definitely it should be a lot cleaner, however the sloppy cabling wouldn't be causing any performance issues if it is properly wired
DAS IT MANE
Stagg is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2013, 12:46 PM   #1653
poppa smurf
no not now, but as I say in the future there may be a problem.......best to have it tidy right from the get go.....I wont comment on performance as i will leave that to the experts, I have seen a few "issues" that may contribute to under power though
Old 18-02-2013, 03:35 PM   #1654
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
WELL WELL WELL ....LOVE THIS FORUM
well i jumped back up on the roof toady after sparky dave brought something up
and it looks like my last panel in the top string isn't even connected WTF
i pulled the wires out and yep its just attached to itself
after telling me its making its average, there is nothing wrong blah blah (and the installer wouldn't even come out to look at it) ....makes me mad that does
the bloke who sold it to me was more of a help than the installer (the bloke who sold it said that was the last straw for the installer, hes done a few stuff ups)
so if its hooked up in in 3x lots of 5 and because 1 lot has only 4 would that drag the everything down???
oh and the installer is sending someone out today ..like he bloody well should
and here are the pics of the other stuff
and the panels
FG XR8 Ute 2010 Nitro,
Mods so far: Herrod CAI, headers, Ballistic cats, Cat back Manta dual 2.5" with X pipe and hotdog mid section, Mellings oil pump, Summit racing 60mm twin throttle body, and Yella Terra plenum
Powerbond 25% under drives, Sports bar,
now fitted with Koya Inox R1's, the rears are 20x10 with a 40mm offset and the fronts are 20x8.5 with a 35mm offset
total of 285.5 rwkw and 642nm
when Herrod cams in 290rwkw
GSXR 750K7 with goodies, dyno'd 136rwhp,
10.567sec for the strip
comagutsa is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2013, 04:07 PM   #1655
Stagg
Stagg's Avatar
At least you'll see a positive difference when someone has come out to fix the problem to not making what you have currently been making.
As someone who really works and believes in the industry it is annoying and disheartening that folks who work in the industry pull **** like this, which snowballs into people hearing about shock jobs and then being turned off by the industry. The whole industry really does need a tighten up and people have to have a standard level of workmanship.
Especially as you would have paid top dollar for Suntech & SMA for that system, I would assume it's only fair you get a top quality install!
It is good that you had a few guys here helping you out and it's good that you had the guts to get up on the roof to check it out good work!!
DAS IT MANE
Old 18-02-2013, 04:08 PM   #1656
SPArKy_Dave
Too many Fords........ :)
SPArKy_Dave's Avatar
That's great news.
You just need to find which of the 3 strings, is missing a panel.
You don't want to end up with a string of 4, 5, and 6 panels.
The unconnected panel, and un-equal strings, will be the primary issue here.
But there are the other installation issues.
The biggest two, are -
1. The el-cheapo DC circuit breaker they've used, is under-rated for the number of panels connected in series.
There are effectively two strings going through that 800V DC breaker, and each pole is rated at 200V.
When the calculations are done, you need a breaker rated at approx 1200v, or 300V per pole.
The minimum per pole rating you can have, is 273V. (or a 1092v rated isolator)
Since the next size up from 1000v, is 1200v, that's the one you want.
And ask for a decent DC isolator - Telergon, IMO, or Kraus Naimler. (About $100.00)
Don't accept that $20.00 chinese rubbish.
Makes me sad to see a premium panel/inverter system spoiled by cheapo switchgear.
They're a real fire hazard.
2. cables lying on the tiles under the panels, is a definite no.
Be hard to fix that one up without removing the solar panels.
Current Projects
97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY
93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal.
95 XG ute - awaiting a head gasket...... grrrrr.
74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto.
XB Coupe and Van TV Ad
you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it
SPArKy_Dave is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2013, 04:14 PM   #1657
Stagg
Stagg's Avatar
Story of my life, customer asks why we're more expensive than the other people selling the same gear...
DAS IT MANE
Old 18-02-2013, 04:16 PM   #1658
poppa smurf
terrific outcome.......really pleased for you.......well done to sparky for picking the problem, I had my suspicions but didn't like to say anything that I'm not qualified in
great outcome!
sparky said........"2. cables lying on the tiles under the panels, is a definite no.
Be hard to fix that one up without removing the solar panels"
couldn't agree more!
Old 18-02-2013, 04:25 PM   #1659
SPArKy_Dave
Clearly great minds think alike.........
I reckon we should team up, tell those dodgey sales mobs to F-off, and install premium systems, for customers direct.
The likes of Modern, TVS, Origin, etc........ cause more problems then they're worth.
Making stupid unrealistic promises to customers....... yes sir, our standard grid connect solar will continue to power ur house, when the Grid goes down.
FFS.
Current Projects
Old 18-02-2013, 04:29 PM   #1660
SPArKy_Dave
Like I said - A real fire Hazard -
http://s931.beta.photobucket.com/use...romLegacy=true
edit - that rotary switch in the background, being used to save the day, is a Telergon ZFV32.
Current Projects
Old 18-02-2013, 04:51 PM   #1661
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
yeah just spoke with the bloke who sold it to me and told him what sparky Dave said and i sent him an email with all the pics and hes is a bit upset about the whole thing as the installer was meant to use quality bits
i think he will be getting onto the installer to fix all the stuff ups
will now have to wait and see what happens now
thanks again to everyone
Old 18-02-2013, 05:58 PM   #1662
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
well after i posted the above bit there was a knock at the door
went up and connected panel and tested before 1990w after 2250w (never been that high on a normal sunny day with no clouds)
when back up and 45mins later after fixing all the cables he could without removing panels its reading 2050w at 2.45pm , usually around 1800w this time of day....
bring on a sunny day tomorrow and see what happens
Old 18-02-2013, 06:04 PM   #1663
poppa smurf
ah! so you've picked up an extra 260 watt.......great news this should give you an extra 1.5 kilowatts per day
should boost your output quite significant......no damage to the panel by reverse power I hope
Old 18-02-2013, 06:21 PM   #1664
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
yeah will wait and see i guess
over the last week best i have got is in the 15units range 3 days out of 7 as its been a bit cloudy
hope tomorrow is a nice sunny day and i will let you know how it goes
Old 18-02-2013, 06:46 PM   #1665
Dragoneletra
Dragoneletra's Avatar
Meant to use stainless cable ties as per regs ? and the junction box was floating in the breeze ? That's not sloppy thats cr4p. no good. you shouldn't have to neaten a thing, clean up after a tradesman, you shouldn't have to do anything.
visit us @ http://dunwrights.com.au
http://Darwindoorsandgates.com.au
And http://Darwinairconditioningdirect.com.au
BFIII wagon, hoovered, scooped and dropped. Water/meth injected..
Getting the shopping done.....FAST
Build thread:
http://fordforums.com.au/showthread.php?t=11307332
'69 XW Fairmont
bombed 351 cleveland
http://fordforums.com.au/showthread.php?t=11244411
The reason I'll end up divorced
XE FALCON HEARSE build.
http://fordforums.com.au/showthread.php?t=11452342
Dragoneletra is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2013, 06:49 PM   #1666
Dragoneletra
FFS.
A lot of down south outfits are moving into darwin now. i know of one company from south who has had to replace 103 installs due to not being to NT code.
Pretty bad. we are looking at getting into solar. Accredited and everything, just haven't started anything yet.
Build thread:
'69 XW Fairmont
Old 18-02-2013, 06:56 PM   #1667
poppa smurf
my install was pretty good, I just got a few cables off the roof.......my comment on the junction box was a referral to comagutsa's instal (see pics)
a possible scenario could be the ties give way over time and the junction box is left unattended in the roof space doing god knows what
Old 18-02-2013, 07:00 PM   #1668
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
the metal cable ties as per regs came into affect around October i think and my system was done in June 2012 before the regs changed to everything in conduit and metal ties
Old 18-02-2013, 07:23 PM   #1669
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
also 1 thing i have also noticed is the Volts on the PV side has gone from 138v in the pic above to over 160v on the inverter now
Old 18-02-2013, 07:29 PM   #1670
Dragoneletra
Ahh apologies. I misread.
Though stainless cable ties are the minimum they shouldn't ever come loose.
Build thread:
'69 XW Fairmont
Old 18-02-2013, 07:31 PM   #1671
poppa smurf
so less power drawn from the grid as well with the increase in volts......win win!
I always screw the junction box to the rafter before I install any wiring......I would never use cable ties to secure the box....
that is er um assuming I was to do any electrical work, which of course I wouldn't under any circumstances cos that'd be illegal!
Old 18-02-2013, 07:32 PM   #1672
Dragoneletra
No worries.
There are a lot of dodgy operators getting around in solar circles.....I had a quote done on our place out of curiousity.
17K
didn't do shade analysis
didn't even get up on the roof and look
had to ask where north was (compass app ? Smart phone ? wtf?)
told me I would get 4.5kw from a 4.5kw system no worries
out of curiousity again, i'm getting another tomorrow from a different company. I quoted it all up and know what i'm going to charge, but thought I would see just how professional the competition really are.
Build thread:
'69 XW Fairmont
Old 19-02-2013, 07:05 AM   #1673
prydey
Rob
prydey's Avatar
my TVS system is fine. no dodgy wiring, no hanging cables, no dodgy circuit breakers etc etc.
its a bit of a 'general' statement you make, but bear in mind, there are the exceptions to the rule, and some companies do change. often the sales and the installations are totally separate companies and all it takes is a bad installer to ruin the solar company reputation.
TVS sacked most of their installers in adelaide in late 2011/early 2012, and most of the negative feedback is from before that time.
prydey is online now   Reply With Quote Multi-Quote with this Post
Old 19-02-2013, 09:07 AM   #1674
Stagg
Stagg's Avatar
Here is the number of times TVS has changed their business name
True Value Solar (VIC) Pty Ltd – (ABN 57135821626) – 31st of March 2009
True Value Solar (SA) Pty Ltd – (ABN 11143232482) – 20th of April 2010
National Solar Group – (ABN 31143993248) – 1st of June 2010
State Solar Services – (ABN 85563549240) – 1st July 2010
State Solar Services Pty Ltd – (ABN 57135821626) – 22nd of December 2010
Bear in mind every time they have changed their name, all of those previous customers now have voided warranties, let's hope they don't change their name again because you will be left without a warranty, hate to be the bearer of bad news...
Also, your system has been up less than a year, I would expect the panels to be yellowing by next summer..
DAS IT MANE
Old 19-02-2013, 10:07 AM   #1675
poppa smurf
well I would not be in too big a hurry to poo poo any solar system regardless of cost
the only thing that would concern me is cost versus time.......given the initial outlay of the system is less then payback time is less longevity of the system may come into play but the savings made in the meantime are not insignificant.... the bank account rises as a consequence
I have been involved in a few "cheap" installs where the company has installed and knicked off....the system is still producing as good as ever and in quite a few cases has paid itself off
in the meantime the owner has no, or little bills, and if the the system fails is now in a position to possibly consider larger
a lot of "reputable" solar sales outlets have gone under as well so the warranty of either system is questionable at best
we all have a bucket of money.....some buckets are bigger than others.....I hope the cheaper systems go on forever and produce copious amounts of power for the owners
Old 19-02-2013, 10:59 AM   #1676
davenl5l
davenl5l's Avatar
they should lift all panels and check because you still don't know if it's right
clevo mafia (sadly sold) 351c xe manual (now with short shifting 5sp goodness) xc gs coupe project...hmm more clevo for me new daily 2005 ba sr
davenl5l is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2013, 11:23 AM   #1677
devilcv8
Originally Posted by deesun View Post
I'm surprised you get any sunny days in Goulburn, lol. My bil +sil are building in Goulburn atm and have decided not to go the solar route. I think they will be sorry in the long run. Big house, 4 very young kids and its their family home probably forever. Whats the FIT in NSW nowadays?
We get sun, however we also get lots of wind, which has made erecting my Ranbuild shed lots of fun.
FIT in nsw is whatever you get from the retailer, upto 7 or 8c.
Goulburn also means you pay 31c/ kwh so your bil + sil will pay dearly for no solar.
devilcv8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2013, 11:30 AM   #1678
fnm17
fnm17's Avatar
Damm just watched that video, have to check what I have at home ... bugger being that guy in the video !!!!
fnm17 is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2013, 02:24 PM   #1679
deesun
deesun's Avatar
Yep, realised what I said after. FIT is ****** in NSW nowadays and would have had an adverse effect on installs. Even so I agree they will pay dearly.
igodabigblackshinycar and I relented and allowed a BMW into the garage.
deesun is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2013, 08:25 PM   #1680
Stagg
Stagg's Avatar
Have to remember though that 7-8c per kWh is the wholesale rate of power, and since FiT all over Oz were put in place, they were all going to disappear in a few years anyway, the whole industry knew of this and it sure isn't going to get better, nor will it really get worse. We do know however that electricity prices will continue to rise.
What I come across almost on an everyday basis, is that the customer says "There would be a lot more incentive to go for solar if there was still 66c FiT". Truth is of course there would be more incentive to do so, but regardless of 66c or 8c, you are still saving a huge amount of money over the life of a system, the total payback subjective to every households electricity habits may make a very small difference in payback period with todays tariffs compared to those tariffs of a few years ago. The fact that the market has gone completely quiet here in VIC just tells us that everyone believes that there is no payback for solar at all.
I mean, really, it still has a payback period. There are very few investments you can make for your home that have a payback, surely solar should still be seen as attractive because there is still so much benefit from going solar?
If people must know I was told a few new insights into the industry at the moment, that because Solar has become so affordable as of this year, the STC multiplier may be dropping earlier than June 30 (to a 1x multiplier), or potentially even lower. Which means if solar seems unattractive at the moment, it sure isn't going to be getting any better.
It really is an industry that due to huge incentives in the past, it is seen as no longer attractive with the current incentives in place. But it isn't going to get better. The earlier everyone decides to go solar, the better off they will be. Sure they won't have it as good as someone who bought a system two years ago, but you'll sure as anything be better off than someone who buys a system two years from now.
And yes because of how quiet is has become, we have been inundated with people whose jobs have been made redundant in the industry, and I potentially may no longer have a job by the end of the week :( I just wish that people really believed in solar like I do and see that it really is worthwhile
DAS IT MANE
