Old 27-04-2014, 05:12 PM   #2581
CJR09
RPO 77
CJR09's Avatar
Default Re: who amongst us have gone solar
you still need an inverter unless you move to specialist gear which will cost
unless you are building new thermal solar is still by far and away the most efficient form of energy conversion for domestic hot water
Q: If you have tried to sell it three times now and it is still not sold, do you think it might be over-priced?
A: It is over priced - just like all the other falcon coupes for sale!!
CJR09 is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2014, 09:03 PM   #2582
zilo
BANNED
zilo's Avatar
specialist gear????
inverter???
I was going to use 240 volts DC to drive the water element in a stock electric hot water storage unit.
How would it know it wasnt AC?
Seems so simple to me...can't see how it wouldn't be better than any convection unit to be honest??
zilo is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2014, 10:21 AM   #2583
poppa smurf
poppa smurf's Avatar
not sure if you could use DC to run your AC element, we couldn't here with a couple of different ones but that may vary with elements???
we have used these....... http://www.altestore.com/store/Charg...PT-Male/p2327/ found them to be okay.
depending on time of year your solar simply may not produce the amount needed for the element.
a better, but more costly way, is
solar - inverter/charger - batteries - water heater.
the batteries will "even out" the fluctuations in the solar generation as well as supply the needs of the unit.
instead of a 3 KW system i would recommend at least a 5KW to stand some chance in winter.
it is simple but it takes a lot of maths and a fair bit of knowledge to enact that simplicity.......
I have been involved in a fair few "stand alone" systems now and a few that are doing exactly what you want to do, with differing success rates.
but don't be put off, try it and let us know how you get on.
I've seen a lot of peculiar setups that work like a beaut.
G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II...
may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon!
poppa smurf is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2014, 03:55 PM   #2584
CJR09
RPO 77
CJR09's Avatar
you cant use your dc to run ac gear - hence there is still a req for an inverter unless you do as poppa eluded to (still need d/c-d/c inverter) which will be cost prohibitive - entirely possible but the cost benefit just isnt there unless you are going off grid?
cheapest way would be to run your hwc stand alone with inverter output dedicated to the hwc but you are only saving minimal coin (maybe $500-$750) - if you are going to do it may as well grid tie it for a bit extra and have the ability to take a credit for the excess generated that isnt used and you have the top up from grid on those crappy days
well designed solar thermal = 70-80% efficiency energy conversion/m2
solar pv restricted to MODULE efficiency x inverter efficiency = ave <15.5% efficiency energy conversion/m2
Old 29-04-2014, 12:15 AM   #2585
zilo
BANNED
zilo's Avatar
I know the difference between AC and DC.
But a water heater element doesn't care which you provide.
My reasoning is connecting photovoltaic directly means 100% goes into heating the water...why have battery stress and inverter losses to simply heat water???
Yes I will be off grid, the water heater will be a 4kw PV system for a 2400w heating element....oversized to always work.
So even at less than 50% sunshine it will still heat the water.
4Kw of panels for the same price as a convection water heater...it's a no brainer which to get...
But you are forgetting that when the water is hot I can dump the charge into batteries.....where do i dump the energy from a convection system when the water is up to temperature?....nowhere.
Roof space is prime real estate in this installation.
I was hoping that someone had tried it and had a few tips, but don't mind experimenting and posting back my findings poppa smurf.
Just can't believe noone has tried it...especially with the woeful grid feed in tarrifs these days.
Old 29-04-2014, 10:26 AM   #2586
poppa smurf
we have done it around here with varying success, what we found to be most successful was solar - inverter/charger - battery - water heater/household..... using the 240V direct from the inverter to power the element (and household), then the solar charges the batt's when drawdown is low and the batt's power the household at night.
direct solar to house is very tricky and full of problem's, I know because I've stumbled into most of them.
the 12V element has had limited success, longevity has been a big one as power fluctuations without the batteries flattening out the the power waves does the element no good, then there are the "evening" showers when, of course, the sun doesn't shine and the hot water is low.
much better to go 48V if at all possible if you still wish to go this route.
we do some "experimental" trials here, always glad to hear from another person trialling a system that we may not have heard or thought of.
I won't post "tip's" as Forum's can be a very argumentative place.
Old 29-04-2014, 10:34 AM   #2587
zilo
BANNED
zilo's Avatar
@poppasmurf-Picture this config...
I will be using 240V DC direct from a string of 10x 200 watt panels ..so high voltage DC not a low 12v system.
I can fully understand how a 12v element would be marginally successful as it would take enormous Amps to get 2000 watts of heating that way.
Old 29-04-2014, 10:38 AM   #2588
poppa smurf
Old 29-04-2014, 06:26 PM   #2589
CJR09
RPO 77
CJR09's Avatar
Originally Posted by zilo View Post
I was hoping that someone had tried it and had a few tips, but don't mind experimenting and posting back my findings.
there's more than one way to skin a cat so to speak
Plenty have tried it - good luck & all the best with it
Old 13-05-2014, 05:24 PM   #2590
Just received an email from the company I got my system through.
This is it:
"Title: Product Recall
Please check if you have one like the picture.
Regards"
12/05/2014
URGENT ATTENTION
***** PRODUCT RECALL*****
Today we were notified of a product recall of item AV/DC4P25A DC Isolator. We have been instructed to advise our Solar customers to shut down their systems. PLEASE FOLLOW SHUT DOWN PROCEDURE IN YOUR MANUAL.
This DC Isolator is located next to your inverter (Please turn off ) . This matter is in the control of the Distributor of the Product and the item will be recalled we will be supplied with a new DC Isolator and as soon as possible this will be changed.
Old 13-05-2014, 05:31 PM   #2591
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
hey WA guys
if a house has the 47cents contract in place and someone else buys the house is the solar contract transfered to the new owners of the house??
FG XR8 Ute 2010 Nitro,
Mods so far: Herrod CAI, headers, Ballistic cats, Cat back Manta dual 2.5" with X pipe and hotdog mid section, Mellings oil pump, Summit racing 60mm twin throttle body, and Yella Terra plenum
Powerbond 25% under drives, Sports bar,
now fitted with Koya Inox R1's, the rears are 20x10 with a 40mm offset and the fronts are 20x8.5 with a 35mm offset
total of 285.5 rwkw and 642nm
when Herrod cams in 290rwkw
GSXR 750K7 with goodies, dyno'd 136rwhp,
10.567sec for the strip
comagutsa is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2014, 05:44 PM   #2592
eaglem
eaglem's Avatar
Originally Posted by comagutsa View Post
hey WA guys
Not sure the contract can be transferred as the original contract was between the original owners and Western Power so the new owner would need to draw up a new contract and that would at today's unit rate.
eaglem is online now   Reply With Quote Multi-Quote with this Post
Old 13-05-2014, 05:46 PM   #2593
poppa smurf
hey WA guys
no, the tariff cannot be transferred, the new owner must renegotiate with their power suppliers.
Old 13-05-2014, 06:02 PM   #2594
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
so in other words they will get the usual WA 8cents
cheers
Old 13-05-2014, 06:05 PM   #2595
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
Same in QLD poppa. Initial FIT is not transferable to the new owner, and you cannot take your existing system from the roof and enjoy the original FIT on your new home. It's address and original owner specific.
Cheers!
Edit: comagusta, yep to your last post - way it is bro.
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2014, 07:19 PM   #2596
EgoFG
Same in NSW, but please understand that for me, the 66C Gross FIT was not viable due to inflated install costs, only when the Gross FIT was dropped and the 6c NET FIT was introduced did install prices drop sufficiently to get the payback period below 3 years
EgoFG is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2014, 08:04 PM   #2597
poppa smurf
unfortunately mate that's the way it is......new contract with the purchaser.
I smile when I see a house for sale that advertises solar that "guarantee's no power bill's e ver with a $0.52c FIT".
often wonder if the salesperson can be sued for false advertising when the new buyer doesn't receive said $0.52c FIT.
Old 14-05-2014, 07:34 AM   #2598
With the total lack of information from the solar people about my recall I started searching the web. It's strange how I haven't seen anything at all on the news about it.
http://www.dksh.com.au/htm/388/en_AU....htm?Id=553690
Old 14-05-2014, 09:21 AM   #2599
...and after contacting the suppliers and sending photos of my switches it appears that mine are heavier duty and not affected by the recall. Apparently the switches are mainly used on smaller installs.
Old 14-05-2014, 10:18 AM   #2600
AlanD
Hi Zilo,
Your 10 panels should (will) produce about 350 Volts DC. (Somewhere I have a spec sheet for the panels on our roof that, from memory, produce approximately 40 volts d.c. open circuit, this falls a bit when the load comes on.
The heater in your storage tank will have an insulation rating for 240 V a.c. which means it is able to withstand potentials of 340 volts or there-abouts. So they ought to be OK for the nominal 350 V d.c. (There is always some "safety" headroom in the design). But of more concern is that the (usual) heater element is designed for 240 volts and so will (try) to draw a larger current than its rating. This is likely to be inexcess of the panel's capability and there will be heating effects in the panel for which they are not designed. If you limit the panel string to 6 or 7 panels you should avoid this problem. This would provide 1500/1750 watts if you are using the more modern 250 watt panels.
Another problem will be with your thermostat contacts which are designed for a.c. and any arc that gets drawn when the contacts open is extinguished when the voltage waveform passes through zero volts. With d.c. this does not happen and thus any arc is maintained. This causes rapid erosion of the thermostat contacts and failure. One failure mode is that the contacts get welded closed and thus heating continues until some other fault appears. This might be, if the storage container is a pressure vessel, rupturing of the tank because the increasing water temperature causes expansion and thus increased pressure. Very hot water can also be a real hazard to people, especially if they are not expecting the very high temperatures. Particularly at risk are young children in baths who turn on a hot tap. d.c. thermostats are available, I believe, and I would counsel that you retro fit one of these if you proceed with your plan to directly feed the heater element from the panels.
Incidentally, this arcing business is the reason why you should always start the isolation procedure for a PV grid tied system by opening the a.c. switch or miniature circuit breaker on the output side of the inverter. This causes the input current to the inverter to drop to zero and thus no risk of arcing when the d.c. isolator(s) are opened.
AlanD
Our Drive: Mazda
CX5 KF AWD 2.5 Turbo
Soul Red
AlanD is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2014, 11:30 AM   #2601
Sam_Boss260
Have Boost, will use it..
Sam_Boss260's Avatar
I got an email from one of the solar companies that were quoting me, stating that the Govt will be dropping the $3,900 rebate so after July 1 the cost of a system will go up by the cost of rebate.
Is this true or s sales ploy to get me to sign now?
Sam_Boss260 is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2014, 11:35 AM   #2602
poppa smurf
all sorts of things in the pipeline regarding solar and renewable energy as a whole, some true, some not.........but the earlier you buy solar the better off you will be.
Old 14-05-2014, 01:56 PM   #2603
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
suck to be then buying a new house then
Old 15-05-2014, 06:43 PM   #2604
ute83
hey WA guys
Here in Victoria the feed in tariff stays with the residence, so yes.
ute83 is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2014, 08:59 AM   #2605
supershifty
Missing a sock...
QLD govco rolled the 8c FIT last night, think it ends in July. Those who signed up on the 44c FIT remain untouched - for now.
Wonder how long until this creeps over the border into the rest of the country?
http://www.heraldsun.com.au/news/nat...-1226925963793
Old 22-05-2014, 09:39 AM   #2606
EgoFG
Already in in NSW, and it makes the installer more competitive, driving prices down !
Old 22-05-2014, 10:11 AM   #2607
poppa smurf
this will be nation wide shortly, power industry is too strong now.
gas prices are set to skyrocket, petrol is shooting up at least 4c per litre and water is through the roof........not a good place to be anymore.
possibly the suppliers will come to the fore and up the FIT from their side, more competition on that side.......we can only hope.
Old 22-05-2014, 06:58 PM   #2608
buggerlugs
If it ain't broke........
http://www.couriermail.com.au/news/q...age%7Chomepage
Some very interesting comments at the bottom of the article............
Visitors welcome
Relatives by appointment only
buggerlugs is online now   Reply With Quote Multi-Quote with this Post
Old 23-05-2014, 10:06 AM   #2609
davenl5l
davenl5l's Avatar
at least the sun is shining !!!!!
clevo mafia (sadly sold) 351c xe manual (now with short shifting 5sp goodness) xc gs coupe project...hmm more clevo for me new daily 2005 ba sr
davenl5l is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2014, 10:22 AM   #2610
poppa smurf
yes but given the angle of the sun it is producing little,........I produced 6 KW's yesterday.
not enough to cover my usage, winter is coming and along with the increase in supply charge and a slightly higher tariff charge I think I will begin to chew into my credit for a while.
