Old 10-07-2014, 04:51 PM   #1
Stazza_Brendan
Stazza_Brendan's Avatar
Default Unable to access forums from home internet.
Having trouble getting the website to come up from my home internet but comes up fine on my phone using mobile data, but as soon as I turn wifi on it cannot find the site. My PC can't see the site at all on wifi, even trying different browsers and restarting computer. All other sites work fine.
Any tips to get it working? My ip blocked for some reason?
Seduce BFII XR6T Ute
ZF - Optioned interior - Hardlid - Rapidsystems V4.5 kit - GTX3576R - Crow Cams Valve springs - 1000cc KPM injectors - 20" MC Racing Wheels - DashDaq/Cobalt Gauges - 4in dump/3.5in exhaust system - Shockworks Coilovers - 30mm Swaybar - Shockworks 4pot 355mm front brakes - GT R-spec rear brakes
CPV Tuned to 340rwkw
Stazza_Brendan is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2014, 04:56 PM   #2
blackf6
R51 Pathy, 91 Jayco Swan
blackf6's Avatar
Default Re: Unable to access forums from home internet.
You have been banned for putting too much power through your poor old rear tires man.
I was having a drama with the website a few weeks ago, heaps of popups and not scrolling properly.
Turned out to be the wrong setting on my pc. Had to do a total reboot.
blackf6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2014, 06:13 PM   #3
Raysie
Raysie's Avatar
Open up your command prompt (http://windows.microsoft.com/en-au/w...-prompt-window) and type the following.... clicking enter afterwards:
ping www.fordforums.com.au
What happens after you click enter?
Tell me what shows up. If you get a message saying request timed out, try typing the following and tell me what appears:
ping 66.226.77.74
Raysie is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2014, 06:35 PM   #4
Stazza_Brendan
Trying to ping ford forums. I get "ping request could not find host www.fordforums.com.au. please check the name and try again.
Ping that ip and I get replies. To much to try type on phone.
Old 10-07-2014, 06:42 PM   #5
Raysie
Raysie's Avatar
That's good. What it tells us that it's a DNS issue. In other words your internet is having issues trying to understand where fordforums.com.au points to.
There's a couple of things that can be done, however both aren't considered super easy for a general user. Below are the best options:
1. Go into your network adapter settings on your PC and add the following as your static DNS:
Preferred: 8.8.8.8
Secondary: 8.8.4.4
This fix however is more a work-a-round and will only resolve issue for your PC, and not everything else on your network.
2. And this is your best option... is logging into your home router/modem and changing your DNS server settings to the same as what I placed above:
Primary: 8.8.8.8
Secondary: 8.8.4.4
This will tell your internet connection to use Google's servers for DNS, which will fix your current issue and any other website you haven't noticed isn't actually working for you.
If you have any issues, tell me your modem's model and I'll try my best to walk you through the change.
Old 10-07-2014, 07:20 PM   #6
Stazza_Brendan
I'll get onto that tonight. Weird that when I went away Monday arvo it was working and come home today to it not working.
Done the usual reset modem, computer.
Thanks for the help so far
Old 10-07-2014, 07:28 PM   #7
Raysie
Raysie's Avatar
No probs. Could've been anything really. It's more than anything just the crap ISP provided DNS servers having a hissy-fit.
Using Google's DNS servers are recommended as really... when has Google ever been down? lol
Old 10-07-2014, 07:57 PM   #8
Stazza_Brendan
That dns setting doesn't fix the problem.
I'm on internode nbn if that makes any difference
Old 10-07-2014, 08:06 PM   #9
Raysie
Raysie's Avatar
Which fix did you attempt mate?
If through the router, what DNS settings were there beforehand? If any?
Old 10-07-2014, 08:10 PM   #10
Stazza_Brendan
Changed dns for the router, setting on router was get automatically from isp.
Router is netgear dgnd3700
Old 10-07-2014, 08:14 PM   #11
Raysie
Raysie's Avatar
Thanks mate. Might be worth rebooting router for change to take effect. Might also be worth checking if your changes still show on the router side after the reboot.
Old 10-07-2014, 08:20 PM   #12
Stazza_Brendan
Done a reboot and didn't fix anything. Weird how every other website works but ford forums.
Old 10-07-2014, 08:26 PM   #13
Raysie
Raysie's Avatar
Bit odd that issue is still being experienced. It definitely sounds like a DNS issue from the router end, seeing as you mentioned that your phone when connected through WiFi has same issue.
Just for ***** and giggles... we know that you can ping 66.226.77.74, so how about I get you to open up your web browser and enter that IP address in the address bar field. The Ford Forums page SHOULD display.
If it does, I have a work-a-round fix which will at least get your PC showing the the forums here correctly. Only issue with this fix is if the public IP address here changes (Ie. If Ford Forums changes webhosts etc.) you once again will have issue viewing Ford Forums from your PC.
Old 10-07-2014, 08:39 PM   #14
Stazza_Brendan
Using that ip let's me onto the site. However after logging in, it forgets I'm logged in, no matter if the password is saved.
Might have to call the isp and see if they have an idea
Old 10-07-2014, 08:48 PM   #15
Cashie
Cashie's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Multiple helpful contributions throughout the tech area.
I'm having the same issue, also with Telstra..
Did the forum move servers at all?
Current Rides:
2017 Ford Mustang
2020 Ford Everest Sport
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2008 BF XR6 Turbo Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Cashie is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2014, 09:56 PM   #16
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Could be linked to what size screen is being displayed on?
Works fine on my mobile, doesn't work on my laptop, yet I'm hot spotting my laptop with my mobile data.
___________________________
Old 10-07-2014, 09:59 PM   #17
Uncle Tone
Ploppy pants
Uncle Tone's Avatar
I was having trouble today as well.
Fine on the phone, no good on the desktop, but other sites worked fine.
Don't wait to be told.....you need Palmolive Gold!!
Uncle Tone is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2014, 10:14 PM   #18
Cashie
Cashie's Avatar
Yeah, it's definitely a Telstra DNS issue..
Our Telstra ADSL can't find the forum but our business Telstra Fibre can.
It seemed to drop off around 2pm Perth time (4pm EST)
Current Rides:
2017 Ford Mustang
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Old 10-07-2014, 10:19 PM   #19
cs123
cs123's Avatar
the command nslookup will tell you if your DNS has an entry for fordforums.com.au
This command is testing my default DNS server which is my DSL router. The second is using one of Telstra's
Chriss-MacBook-Pro:~ cspierings$ nslookup fordforums.com.au
Server: 192.168.0.1
Address: 192.168.0.1#53
Non-authoritative answer:
Address: 66.226.77.74
Chriss-MacBook-Pro:~ cspierings$ nslookup fordforums.com.au 61.9.211.33
Server: 61.9.211.33
Address: 61.9.211.33#53
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 10-07-2014, 10:49 PM   #20
Stazza_Brendan
Spent ages on phone with internode trying different things. Could only come to conclusion the problems on the website side.
Old 11-07-2014, 03:24 AM   #21
russellw
russellw's Avatar
It won't be a website side issue as we have no control over DNS resolution and we certainly haven't made any changes to DNS in about the last 5 years.
Telstra and Optus (amongst others) do have intermittent issues with their DNS servers.
Russ
Old 11-07-2014, 08:15 AM   #22
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
I had an issue yesterday from home, roughly 4-9/10PM and I gave up. At work now so ill check again. Both PC and Mac not working...said the AFF server was down?
  • 2023 Mitsubishi Triton
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Polyal is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2014, 08:19 AM   #23
Stazza_Brendan
Working for me now.
Old 11-07-2014, 08:19 AM   #24
LTDHO
The one and only
LTDHO's Avatar
I am with internode also and couldn't access AFF from home.
I assumed the site was down after three tries and gave up.
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2014, 08:47 AM   #25
Raysie
Raysie's Avatar
Just doesn't make sense though. As if the issues was DNS using Internode/Telstra, the change in using Google's DNS should have resolved issue straight away.
Old 11-07-2014, 09:10 AM   #26
Yellow_Festiva
Where to next??
Working for me now.
Same here. Didn't play with any of my settings either.
Old 11-07-2014, 09:47 AM   #27
cs123
cs123's Avatar
No, not always. You need to verify which DNS server your machine is using. Sometimes they are configured in your TCP settings on your machine
Additionally there is a local cache on your machine which you may have to flush.
I showed you above how to validate which DNS server you are using as well as to test another DNS. Can you do that and post the results here so we can help you.
I love Holdens....
Old 11-07-2014, 01:21 PM   #28
Mr Brooksy
Youth worker
Mr Brooksy's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Numerous helpful how-to's and sound advice!
I had a similar issue yesterday. Except no devises worked and as you can see from my location it wasn't Telstra or Optus.
I'm glad it seems fine now today. As I can't use the work around here as Google is blocked.
2007 FPV F6 Typhoon BFII, Neo. Build Number 325
2011 SZ Territory
Old Futura thread:
Brooksy's Ex Build
Mr Brooksy is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2014, 01:45 PM   #29
Cashie
Cashie's Avatar
As others have said, the issue was obviously fixed over night.
Current Rides:
2017 Ford Mustang
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
