Old 15-10-2009, 01:42 PM   #1
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Default Twin Turbo Anyone :)
This will get me more rwkw lol
Seen it on ebay as well.................
Originally Posted by Godzilla_STT
This is a complete Twin Turbo kit for sale, nothing extra needed to install. Mild modifications needed for the exhaust due to it came off a Fairlane.
History:
Many of you might know of this twin turbo setup that has been on my Fairlane for about 3 years, I have owned the complete setup for about 5 years. Original the kit was custom made by Tony Rigoli back in 2001 using T25 turbo's off a CA18 or SR20 S13 (not sure which one). I have made many upgrades since my purchase including the most recent being a turbo upgrade which was on the car for 6 months before I lost compression in number 3 piston. Before I pulled the car apart it was making 300rwhp on 9psi with full boost in 4th gear @ 2200rpm, possible a mid to high 12 second in a 1650kg car.
So I have decided to move on due to house/ business comments. The complete setup/kit in total owes me around 11K I am open to offers, but nothing stupid.
Item: Twin Turbo Setup/Kit.
Price: $5500.00ono
Turbo Setup:
Twin Garrett GT28 R33 N1 Nissan Skyline GTR Turbo's. (Around 310hp each turbo)
Oil & Water-cooled bearing
.42 A/R Front .64 Rear Housing (Same Turbo's as GT2860R-7 just plan bearing not ball bearing)
Standard Nissan GTR actuators 6.5psi x4
Oil feed lines
Twin tunned length custom made (Rigoli) manifolds 2 1/2" (8mm thick)
Twin 3" Dump pipes
Twin 3" Exhaust with Twin 3" punched out cats
Twin 2 1/2" Exhaust from the diff back
Oil Cooler with speedflow fittings
Adapter/ sandwich plate included
Custom made Sump
600x240x90 intercooler
Includes all pipework (goes around ABS unit)
Silver 50mm Snort Performance B.O.V
Head:
Complete Rebuilt EB head (Browns Engineering)
Crow Veiner cam gear
Crow 305pound double valve springs
Chamber work (JHH Engineering)
Removal of hot spots (JHH Engineering)
Seated Valves (JHH Engineering)
Fuel System:
Siemens 633cc injectors
Malpassi Fuel Regulator
Turbosmart NEW fuel regulator gauge
255 intank Genuine Walbro pump
ECU:
Microtech MT-8 ECU comes with manual - use as piggyback ECU
Wiring diagram to factory ECU EA-ED for easy install
Tunable via Laptop
Has current 300rwhp tune
Extras:
HPC Coated rocker cover
NEW Oil catch can
Twin 2 1/2" Dump pipes (rear flange suits S13, S14, S15 Nissan Silver turbo's different to Skyline GTR)
Boost Controller
Surge tank
Hoses and Clamps
Pics: There is no pictures of the B.O.V or Fuel Pump
Before install quick fit
Installed
Exhaust
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2009, 01:44 PM   #2
webby_191189
low wagooon
did you steal this from the AU forums lol
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2009, 03:57 PM   #3
FreddyDUZ747
FreddyDUZ747's Avatar
That is a damn good buy their.All seems to be done properly.
Did you know theirs an edit button frd096?
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2009, 04:06 PM   #4
frd906
i have posted this up mate in the au fourms
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2009, 04:09 PM   #5
frd906
http://www.fordforums.com.au/showthread.php?t=11276443
Old 15-10-2009, 04:16 PM   #6
bArNsY
bArNsY's Avatar
I am surprised there is no heat shielding whatsoever
The Old:
1993 ED Fairmont
1994 ED Futura Classic Manual,
2004 BA MkII XR6 Turbo
2009 G6E Turbo (277.2rwkw @ Tuned at Bullet Performance Racing)
2007 Audi S5 4.2L V8 manual (Supersprint exhaust, MMI 3G+ retrofit)
The New: 2015 SZ MkII Territory Titanium Petrol RWD (With Sync 3 Upgrade)
Other Road Toys
Silver Surfer
2014 S-Works Roubaix SL4 road bike with Roval Rapide CLX 40 wheelset
The Adventurer!
2023 TREK Domane SL 7 AXS Gen 4
bArNsY is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2009, 04:18 PM   #7
Sorted
Sorted's Avatar
Yeah i know but you dont have to click the linky to see the pics and there are more pics on this add
Plus I dont have an AU lol
Tuned by DYNOMOTIVE
Old 15-10-2009, 06:00 PM   #8
Falcon4L
'04 BA XT
Falcon4L's Avatar
Shouldnt there be a balance pipe between the two exhausts? Surely this would create uneven flow
1979 F350 Tow Truck
80 series Turbo Diesel Cruiser
Falcon4L is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2009, 10:23 AM   #9
hardlynormal
that setup is from a guy on boosted.
such a tough fairlane.
would sound pretty insane with that exhaust setup.
hardlynormal is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2009, 10:42 AM   #10
MAD
Petro-sexual
MAD's Avatar
The firing order of the I6 means that each exhaust pulse alternates down each pipe. It's like two separate 3 cyl engines.
- The Story
Old 16-10-2009, 05:43 PM   #11
Falcon4L
'04 BA XT
Falcon4L's Avatar
fair enough I guess that does make sense
1979 F350 Tow Truck
Old 17-10-2009, 09:17 PM   #12
MISSN2
MISSN2's Avatar
That was be way to loud wouldn't it
MISSN2 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2009, 07:24 AM   #13
banarcus
hmm eyebrows
banarcus's Avatar
I've been for a run in a EB TT. Very quick car.
1999 Range Rover 4.6 V8. Soon to have a new blue oval bent eight.
banarcus is offline   Reply With Quote Multi-Quote with this Post
