11-01-2007, 11:42 PM | #1 | ||
Hi ppl,
I own a AUII XR8 220kw model. Just recently got a new exhaust system fitted (Metallic Cats, Pacemaker extractors, custom 2.5inch) I have also just replaced the spark-plugs. Everything runs well just lately she tends to be a little sluggish on idle (in Park) & today it was idling fine in park, but when i put it in drive she almost stalled!!! WTF!!! I havnt gottan a tune yet, could that be a problem or could it fix the problem??? AUII XR8 220Kw - K&N Filter, Metallic Cats, Pacemaker Extractors, Custom 2.5inch exhaust & Ultra-Low Kingsprings all round |
11-01-2007, 11:55 PM | #2 | |||
Walking with God
All the best with it. GK RESETTING AU ECU – BY LG WHY DO IT? Often, resetting the ECU can give the car a fresh start, improving performance, economy and smoothness. It is recommended that an ECU reset is done after any modification to allow the computer to relearn the car and the driver. PROCEDURE: Disconnect the battery (Take off the positive terminal lead) for approx 40minutes to 1 hour. Once reconnected do the following: AUTO Transmission: - Start car and idle in this sequence? - 2 minutes idling with the transmission in drive and A/C on. - 2 minutes idling with the transmission in drive and A/C off. - 2 minutes idling with the transmission in neutral and A/C on. - 2 minutes idling with the transmission in neutral and A/C off. - Drive the car on the road, for at least 5 minutes under variable throttle positions. MANUAL Transmission: - Same as above, except put the transmission in gear for (drive).
15-01-2007, 08:01 AM | #3 | ||
T3 TE50 Blueprint
After resetting the ECU, your idling problem may get abit worse 4 a couple of days before it gets better.
15-01-2007, 09:21 AM | #4 | ||
not here much anymore
Check you havent cracked a plug. #5 is a right bastard to get in on the right angle.
2024 F150 XLT
