Old 19-09-2005, 10:40 AM   #1
Neeek
65 Galaxie Hardtop
Neeek's Avatar
Default Got NOS?
It may be a bit tragic, but there are so many good automotive puns you could make about this that it *has* to be shared. Idiots.
http://www.smh.com.au/news/national/...981967532.html
Red on red 65 Galaxie 390FE C6 9"
Neeek is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 10:48 AM   #2
RED_EL_XR8
RED_EL_XR8's Avatar
Something else to be legislated impossible to obtain to protect the brainless from themselves.
RED_EL_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 10:52 AM   #3
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Originally Posted by Article
A post mortem examination will be carried out on the dead man to determine cause of death.
Uh... yeah.
Carless
Old 19-09-2005, 11:10 AM   #4
seano14
dodgy nos installation gone bad or deliberately inhaled? seems pretty stupid.
seano14 is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 11:30 AM   #5
BlackLS
Well the article said that neighbours have seen the people all go sit in the car for extended amounts of time, then get out, so they were using the car as a sealed chamber. Deliberate i say
Old 19-09-2005, 11:42 AM   #6
Kryton
Kryton's Avatar
maybe they didnt know there was another use for NOS?
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 11:50 AM   #7
geckoGT
Ich bin ein auslander
geckoGT's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always level headed and i notice him being the voice of reason when a thread may be getting heated
They weren't bright enough to realise that a different mix is used in medicine, ours is 50% N20 and 50% O2. That whay it does not kill you through a lack of O2.
Hmmmm, wonder what would happen if you injected the medical stuff into your induction?
Growing old is compulsory, growing up is optional!
geckoGT is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 12:40 PM   #8
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
Uh... yeah.
Well, it'd hardly be a pre-mortem examination...
"The cause of death was extreme deadness"
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 12:44 PM   #9
Gammaboy
Gammaboy's Avatar
The RAF experimented with Liquid Oxygen injection during WW2... its a great power boost, but very dicey during fuelling.... they abandoned it to use Nitrous, just like the Germans were using...
But from the actual point of bolting up a medical grade bottle to a normal nos system, you'd need to fatten up the fuel side a *Long* way... unless you like picking bits of piston out of the sump... :P
Old 19-09-2005, 01:20 PM   #10
Gammaboy
Gammaboy's Avatar
I need two big bottles!
Old 19-09-2005, 01:27 PM   #11
merlin
merlin's Avatar
Yarr ye be crazy ye scurvy dog, ye shall blow the welds on yarr intake manifold
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop.
Still to go - Holley Sniper EFI with integrated fuel cell.
merlin is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 01:47 PM   #12
geckoGT
geckoGT's Avatar
Yeah, tipping a O2/N2O mix would melt a lot of stuff!
Old 19-09-2005, 02:08 PM   #13
Gammaboy
Gammaboy's Avatar
"So what do you like to do?"
"I like to melt stuff"
"what do you like?
"I like stuff that melts"
Old 19-09-2005, 02:19 PM   #14
Lukeyson
Right out sideways
Lukeyson's Avatar
I was wondering what the difference was between medical grade happy gas, and the stuff used in cars. :
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 02:29 PM   #15
BlackLS
: : : : : : : : :evil_laug
Old 19-09-2005, 02:52 PM   #16
geckoGT
geckoGT's Avatar
Cylinders will not fit as they are a different connection as well. Apart from that the medical grade stuff (called entonox) is accountable and movement of cylinders has to be registered.
Old 19-09-2005, 09:12 PM   #17
joshf2
striped
joshf2's Avatar
ahhahaha
someone else who remembered international talk like a pirate day!!
joshf2 is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 11:01 PM   #18
Bossxr8
Peter Car
Bossxr8's Avatar
Real smart people. Being in a closed environment probably depleted the oxygen enough to kill the one guy and seriously injure the other 3. Hook it up to your engine if you want some real laughs.
