Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > FPV & XR Owners Club of Victoria > FPV & XR Club of Victoria Discussions
FPV & XR Club of Victoria Discussions FPV & XR Club of Victoria Discussions
Old 24-04-2009, 12:03 PM   #1
RCXR6UTE
Default BF1 XR6 Ute - Speedo Accuracy
Hi Guys,
Newbie. Recently bought BF1 XR6 ute. Got a camera fine this week. :
How accurate is the speedo? I think it might be very close to actual speed, rather than over reading.
What do you reckon?
RCXR6UTE is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2009, 02:23 PM   #2
Brute6
Lurvin' my Ute!!!
Brute6's Avatar
Typically Falcons speedo shows approx 4km/h faster than the actual figure.
ie. If speedo shows 100km/h, actual speed is approx 96km/h.
HIS: FG XR50 Turbo Ute, Sunburst, Sports Bar, Tuned by Herrods! )
HERS: SZ Territory TS, Havana
Proud Member "FPV & XR Owners Club of Vic"
Brute6 is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2009, 02:48 PM   #3
Go baby Go
Like no other..........
Go baby Go's Avatar
Location: Over here.... Mod:FPV & XR Owners Club of Victoria
G'Day,
Do you have std wheels and tyres on it? Don't forget that makes a difference......
The easiest way to tell what is accurate is to use a GPS that will show you what speed you are travelling. Whilst not absolutely guaranteed 100%, it's far closer than your speedo.
Cheers,
A recent study found the average Australian walks about 900 miles a year.
Another study found Australians drink, on average, 22 gallons of alcohol a year.
That means, on average, Australians get about 41 miles to the gallon.
Kind of makes you proud to be an aussie.
Go baby Go is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2009, 04:50 PM   #4
Ross-b
Ross-b's Avatar
can get a dyno run
theyll print you out road speed vs speedo speed
only problem is
if the speedo over reads and you know the value it over reads by then you may find it hard to drive at 60ks when you know ur only doing say 55. the temptation is there to estimate speed which can get you into trouble. but its better then not knowing that the speedo is under reading your speed
Old Car
Recent Car
Ross-b is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2009, 05:40 PM   #5
auMatt
ORSM Ford Cruisers
auMatt's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Matt's valued contributions in the technical area associated with AU/BA/BF & Terri instrument clusters & ICC's is considered the authoritative guide to work by members in this are of expertise. His contributions stand alone in the forum in this technical
If your in Melbourne I can check out if the speedo is out of wack in the cluster.
2004 Harvest Green XR6
Orsm Ford Cruisers
ORSM Ford Cruiser's Web Site
Contact me for all your Cluster Programming/Repairs & Window switch/ICC colour change for BA/BF/FG Falcons & Territory. Visit my SITE for info.
I Use and Recommend :
Ferntree Gully Auto Salvage
AutoWorks - Keilor
RIP Craig
RIP Samantha
auMatt is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2009, 01:30 PM   #6
RCXR6UTE
Thanks for your replies guys. What do you mean by the cluster? Are some out of wack?
I like the GPS idea too. I hear some warn of fixed speed and red light cameras. Any recommendations?
Old 05-05-2009, 05:18 PM   #7
auMatt
ORSM Ford Cruisers
auMatt's Avatar
I have played with alot of BA/BF clusters and 99% of them read high. But I have seen one that was reading a fraction lower than the indicated speed up to about 70kmh.
Orsm Ford Cruisers
AutoWorks - Keilor
RIP Craig
RIP Samantha
Old 05-05-2009, 08:24 PM   #8
RCXR6UTE
I looked at your website. Sorry, didn't see the link earlier. Have standard XR6 17" rims & tyres. Run at 35 PSI all round (unloaded).
Will try GPS first, as suspect speedo under reading. :
Old 05-05-2009, 10:24 PM   #9
Marduk
BFII XR6
Marduk's Avatar
Yeah try a GPS. My speedo reads generally 3-4km/h faster then what i'm actually doing.
2007 BF MKII XR6 'Vixen Red'
Marduk is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2009, 11:55 PM   #10
niggler
good to know, good to know...
niggler is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2009, 11:34 AM   #11
Teflon Turbo
i have heard people using some kind of police digital speedo that is 100% accurate.
But not sure if was standard in FPVs only?
Any info on this anywhere?
Teflon Turbo is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2009, 12:38 AM   #12
Go baby Go
Go baby Go's Avatar
Mate, not that i've heard of but I'm more often that not known to be wrong.......
Old 15-05-2009, 07:30 AM   #13
auMatt
ORSM Ford Cruisers
auMatt's Avatar
The Police Mode can be activated on any BA/BF/Territory Cluster, which sets the right hand side lcd to display a digital speedo. It shows the speed that is passed to the cluster by the PCM. So as longs as everything else is correct, tyre/wheel size and diff ratio the speed will be accurate.
But the catch is that it can only be turned on and off via a scan tool.
Matt
Orsm Ford Cruisers
AutoWorks - Keilor
RIP Craig
RIP Samantha
Old 15-05-2009, 02:02 PM   #14
RCXR6UTE
Matt
Sounds easier and quicker than trying to estimate speed on the needle.
Really can't understand why Ford don't make it a accessible feature. _ Is the scan tool available?
In the end, might still get a GPS anyway, that can also alert to approaching fixed speed cameras & red light cameras. :Up_to_som
