14-08-2020, 08:43 PM | #1 | |||
The Terrain Tamer
Current Ride : A Ford owned D3... |
14-08-2020, 09:06 PM | #2 | ||
Critical Thinker
very true. After emptying it twice, I ended up using the great outdoors or CP toilets instead.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
14-08-2020, 09:46 PM | #3 | ||
Once you get the knack they are actually quite easy to empty and if you use the good chemicals in liberal quantities there is very little smell, probably no more than a caravan park toilet
14-08-2020, 09:59 PM | #4 | ||
Critical Thinker
maybe thats where I came unstuck. I was using 2 tablets and a scoop of nappysan and I still could smell it.
14-08-2020, 10:29 PM | #5 | ||
No buy a bottle of the proper stuff and put maybe a quarter of a cup into the holding tank and another eighth of a cup into the flush tank,very little smell and it breaks the solids up a bit so it pours out the spout a bit easier,doesn’t make it look any better though lol
15-08-2020, 08:52 AM | #6 | |||
Cabover nut
Done quite a lot of research on this due to building cabins and motorhomes. Currently, I like to use Zeolite in the motorhome cassette dunny. Absorbs the liquid which is mainly what produces the smell when mixed with the solid. Sold for the horse stables market. Quite a lot of country CP's, showgrounds and NP camping area's don't want chemicals down in their septic systems or long drops. Being offgrid at home, I just installed whats called a 9020 Separatte dry toilet, (a flash composting dunny) just ordered another baby one which will go into the MH later. They work by separating the dry from liquid waste. In a caravan, boat etc the liquid is captured in a different holding tank while the solids are 12v fan dried to a powder in the chamber. In a RV....The ammonia pee smell isn't as bad when emptied at a dump point and the broken down solids are approved for garden compost material (still wouldn't put it around the veges though) In a home install.... the pee is diverted off with grey sink water to a approval reed bed or absorption field. Mobile wise the biggest problem with this system is cost a pee tank, 12v fan install and the need to be installed under an already busy chassis. To me its worth it as it doesn't stink and cuts out the cost of chemical toilet additives. There are a few great RV type composting toilets available now, some are completely self contained Sunmar and Airhead comes to mind.
