10-03-2008, 05:47 PM | #1 | ||
290
Hi,
I'm thinking of buying a dvd recorder, does anyone know if i can record straight of foxtel iq to the recorder? If not what about normal foxtel? Also can u transfer the recording show from the dvd recorder to the computer? Any help will be greatful Thanks |
10-03-2008, 05:54 PM | #2 | |||
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
As far as transferring the raw video file straight to your computer goes, that's unlikely, but things may have changed since i used to do it.
2024 Audi RS3 sedan - Mythos Black 2023 Skoda Superb Sportline sedan - Steel Grey |
10-03-2008, 06:08 PM | #3 | ||
Right out sideways
Aslong as it doesnt have copy protection, as crackersinc said, you can record Foxtel through one of the line inputs on the recorder.
there are very limited amount of recorders that have a connection to PC like USB, havent come across any as of yet on sale in aus yet though.
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
10-03-2008, 10:04 PM | #4 | ||
290
ok thanks was hopin u could just record from a dvd recorder on to a disc, then take out that disc and copy it to ya puter lol..... that would be to easy
11-03-2008, 09:57 AM | #5 | ||
Chairman & Administrator
I run the Foxtel HD input input into the Aux input on the Panasonic DVD recorder and use DVD RAM discs (which are multiply rewritable) to transfer files to the PC. Note that not all PC DVD drives will read DVD-RAM so you'll need to check that but otherwise it is a straight forward process.
The missing link at the moment is the capability to take the HD native stream as when the disc is burnt it drops back to DVD quality (576). I can use the TViX HD box to do it with the normal broadcast channels and as it is a network capable device I can transfer the captured stream to the PC but that process doesn't work for the Foxtel stream as it has no auxiliary inputs. It is possible to also transfer the file from the Panasonic unit to an SD memory card but again the transfer process reduces to DVD quality. Cheers Russ
Observatio Facta Rotae
11-03-2008, 10:14 AM | #6 | ||
It is probably also worth noting that we are about to see the first of the Blu Ray recorders from Hitachi, Sharp and Panasonic that have been available in Japan for some time now but had not been available in our market for a variety of reasons. I don't have detailed specs on the Hitachi but the Panasonic and Sharp seem likely to offer external input capability and although initial pricing will be high they should fall fairly quickly as other vendors join in.
With the format war effectively over (between HD-DVD and Blu-Ray) a lot of the uncertainty that had pervaded the market has now disappeared and we can look forward to seeing some of the newer product along with a significant increase in Blu Ray titles. I had always considered the Blu Ray format the technically superior format but just like the old VHS/Beta wars there was never any guarantee that the better format (which Betamax was) would win. In this case it did and the recent announcements from Toshiba (the main proponent of HD-DVD) and Warner (their main studio supporter) have put that battle to an end which can only be good for the consumer. Cheers Russ
