Old 30-07-2014, 02:27 PM   #1
fordon
fordon's Avatar
Default towing
Towing with a falcon ba.
Your stock sedan,wagon,Ute,territory can tow brake 2300kg.
The xr range can only do 1600kg brake,why's this,because of sports suspension?
If you used rear air bag ,a xr8 should be fine to tow 2300kg but on paper legally it won't be?
fordon is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2014, 03:40 PM   #2
mik
mik's Avatar
Default Re: towing
That would be surprising if that was the case, tow bar, and transmission type , play a part in what you can and can't tow and load rating, i tow my au XR6 now and again, and I have to say it is the best tow vehicle I have ever had as far as a sedan goes.
Old 30-07-2014, 08:36 PM   #3
fordon
fordon's Avatar
Default Re: towing
True,I would think a ford BA GT be stronger all round than a stock sedan,but that can pull 700kg more legally than the big v8.
Old 30-07-2014, 09:04 PM   #4
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Re: towing
It's not about the model designation it's about the tow bar that's fitted. There's the 1600kg tow bar and then there's the factory option 2300kg unit. If an AU Forte wagon or sedan can pull 2300kg with the big tow bar then any other model can as well if it's fitted with the right tow bar. you can tell the heavy duty unit as it has the square sleeved Hayman Reece hitch.
MINE- AUII Forte
Old 30-07-2014, 09:16 PM   #5
fordon
fordon's Avatar
Default Re: towing
so fine to pull 2300kg with my BA GT with 2300kg tow bar ?
hand book says 1600kg limit.
Old 30-07-2014, 10:41 PM   #6
XR Martin
XR Martin's Avatar
Default Re: towing
Insurance will rape you if you have an accident, whether the tow bar is of rated capacity or not. If that particular model isnt rated to tow that weight, its illegal.
Tow capacity has also got to do with the load rating of the tyres and rims, not just the tow bar.
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 31-07-2014, 12:46 AM   #7
Bushbasher
Bushbasher's Avatar
Default Re: towing
Hmmm, ok, I'm happy to stand corrected then. Maybe it has to do with the drive train not being able to cope with that much load with the 290kW/520 Nm power and torque once you hitch up 2 tonnes behind it.
MINE- AUII Forte
Old 31-07-2014, 05:01 AM   #8
fordon
fordon's Avatar
Default Re: towing
Originally Posted by XR6 Martin View Post
Insurance will rape you if you have an accident, whQtherI rthe tow bar is of rated capacity or not. If that particular model isnt rated to tow that weight, its illegal.
That's what I don't get,what's makes them that weight.
Au xr range can do 2300,than b series can only do 1600kg.stock sedan 2300kg.
I read some say xr auto can do 2300 manual 1600.
Old 31-07-2014, 06:14 AM   #9
sico
sico's Avatar
Yeah, you'd probably have to fit 16 inch rear wheels like the 1tonne FG XR Utes.
Current Ride: 2009 Lightening Strike FG XR6 EGAS ute.
sico is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2014, 08:12 AM   #10
xisled
Default Re: towing
I towed a 1600kg caravan in my BA GT, it was basically sitting on the ground. I would not recommend towing anything larger.
The limit is there because of the height of the car. My GT is standard GT height, it was really bad towing the caravan.
xisled is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2014, 02:42 PM   #11
xtremerus
FG XR6T trayback
xtremerus's Avatar
Default Re: towing
Manual transmissions have the lower tow rate, even with a HD tow-bar
xtremerus is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2014, 02:56 PM   #12
Default Re: towing
Would that be because of the clutch?
Old 31-07-2014, 03:22 PM   #13
deesun
deesun's Avatar
Default Re: towing
This is correct, manual 1600, auto 2300. It has been discussed on AFF before.
igodabigblackshinycar and I relented and allowed a BMW into the garage.
deesun is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2014, 05:40 PM   #14
chrisandsharon
chrisandsharon's Avatar
Default Re: towing
Good point Martin. The F6 tyres for example have a load rating of 93 (650kg/tyre), I'm guessing the ball weight for the 1600kg is 160kg? Even towing a 1500kg van/trailer I'd be making sure that ball weight was in spec. No good towing 1500kg with 165kg on the ball........a claim would be rejected if anything happened.
chrisandsharon is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2014, 08:18 PM   #15
GASWAGON
Default Re: towing
So how do you work out the ball weight?
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2014, 08:46 PM   #16
XR Martin
XR Martin's Avatar
Default Re: towing
Jackstand under the hitch ontop of a couple of bathroom scales is one way. (making sure the hitch is at the same height as the towball on the car)
Old 31-07-2014, 10:33 PM   #17
fordon
fordon's Avatar
Default Re: towing
So this is true? So your saying by law you can do 2300kg with ba gt with right tow bar ect..
Thinking get air bag support for back so keep her balance:-)
Old 01-08-2014, 04:59 PM   #18
xtremerus
FG XR6T trayback
xtremerus's Avatar
Default Re: towing
Can't exceed the weight on the placard, no matter what you do, - Legally.
Old 01-08-2014, 06:34 PM   #19
fordon
fordon's Avatar
Default Re: towing
Looks like I have to sell the gt :'(
290kw to 190kw falcon so I can be legal
Old 03-08-2014, 08:51 PM   #20
xtremerus
FG XR6T trayback
xtremerus's Avatar
Default Re: towing
And no-one drives a vehicle illegally??? Ha
Don't worry about it.
Old 03-08-2014, 10:43 PM   #21
2011G6E
2011G6E's Avatar
Default Re: towing
Good quote from a car dealer I spoke to once about a Land Rover Discovery which, at the time, had a towing "capacity" of 4000kg.
He said that yes, it can tow 4000kg...but that was the maximum capacity. He commented that "Just because your vehicle can tow a certain maximum weight claimed in the advertising...usually done on a billiard-table-flat piece of test track at a careful slow speed...doesn't mean you should do that every day, or sometimes even at all..."
I remember these words when I see those massive Yank trucks which claim ridiculous towing "capacities" of several times the mass of the vehicle...and also TV spots where they show a vehicle "towing" an airliner on a runway...
Old 04-08-2014, 01:44 AM   #22
mik
mik's Avatar
Default Re: towing
you would think a GT would be far better for towing than than the lower spec models,
the GT has.......
better brakes
firmer suspension
more mass,
more power
enhanced comfort for less fatigue
the only things i could see going by these posts is possibly suitable load rated tyres and rims for extra load and an appropriate tow bar,
and perhaps some heavier slightly taller springs on the back for sag, and a tranny cooler.
it might be worthwhile to have a chat with a knowledgeable dude at the rta and see what he says.
Old 04-08-2014, 08:58 PM   #23
GASWAGON
Default Re: towing
I dont get why a manual has much less rating than an auto?
Old 04-08-2014, 09:27 PM   #24
XR Martin
XR Martin's Avatar
Default Re: towing
I think you'll find Yank pickups will easily tow their rated figures day in and day out.
Old 05-08-2014, 02:03 PM   #25
fordon
fordon's Avatar
Default Re: towing
the GT has.......
better brakes
firmer suspension
more mass,
more power
That's my thoughts.
A ford mechanic told me it was due the power that the gt is already putting on the gear box diff.
It's the gear box and diff won't handle the power weight ratio going thru it.... ?
Nothing with suspension or wheels.
Old 05-08-2014, 06:48 PM   #26
a-total-tool
a-total-tool's Avatar
Default Re: towing
the GT has.......
better brakes
firmer suspension
more mass,
more power
It has different suspension. It may be firmer but it will also be lower. Load them up with the extra 150-200kg that such a trailer would put on the back of the car and there will be a difference.
As mentioned before, if towing something that heavy on a regular basis, I would suggest a more appropriate tow rig.
My Grandmother and her partner have a caravan that weighs 1.9t. He has a FG G6, with the 2300kg towbar and the weight distribution hitch. They say while the ford can tow it, they can really feel the caravan on the back of the car, expecially when the winds pick up. Her Hyundai Terracan has less power but feels a lot more sturdy with the massive weight on the back of it.
a-total-tool is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2014, 11:17 PM   #27
GREGL
Default Re: towing
Interesting read on ExploreOz forum on this . These are the places people need to visit when researching towing heavy loads . Like most forums it has its pros and cons as to what is fact , but in many cases the logical outcome can be reached .
It is truly scary what is happening in particular with the popular dual cabs rated at 3000 kg ex factory . People are buying them , loading up to factory specs and coming to grief when they use them for their ADVERTISED purpose .
Their is an AU wagon on a street on the way to work which the owner regularly has a car trailer attached . It doesn't matter much whether a car is on the trailer or not , the nose is always up in the air and the rear makes ssl springs look 4wd in comparison . Must be a handful when under way .
I'm old school , cannot get my head around pulling more than the vehicle weighs with a non commercial vehicle .
GREGL is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2014, 11:22 PM   #28
Crazy Dazz
Default Re: towing
I think it is the lower suspension.
Pursuit ute has lower capacity than standard because of lower suspension.
Time to Make the Hippies Cry Again
Old 09-08-2014, 11:59 PM   #29
nuthin' fancy
Lyminge, Shepway, Kent
nuthin' fancy's Avatar
Default Re: towing
I ask my wife.
Sorry
Mel Brooks sums it up best;
"Comedy is when you fall into an open sewer and die, tragedy is when I get a paper cut"
nuthin' fancy is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2014, 06:50 PM   #30
zilo
BANNED
zilo's Avatar
Default Re: towing
a multiple axle trailer fixes the tow ball weight limit issue.
zilo is offline   Reply With Quote Multi-Quote with this Post
