Old 15-05-2006, 03:31 PM   #1
Dano
Default help! gutless 2l pinto
Hey,
I have a 2door, 1980, 2litre, escort, manual
Basically it goes like crap, I have been in stock 1200 corolla that goes harder.
There are a few things going on:
1. It pings its head off at more than half throttle (I think I can fix this by adjusting the timing)
2. When I start it in the morning, even with a brand new battery it struggles to turn over, It sounds like it's half seized or something
3. It sounds like a tractor when its idling even after fitting a brand new muffler and an extra baffle.
Apart from fiddling with the timing (it is now set to specs from gregorys manual) What should I do?
Dano is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2006, 05:47 PM   #2
shepv8
V8's for ever
Check points dwell angle, cylinder compression , spark plugs and leads, and get the weber carb serviced by a decent tuning shop
shepv8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2006, 05:49 PM   #3
EA2BA
PM me if you want
EA2BA's Avatar
get a kit and service the carb yourself it is really not difficult at all.
Sounding like a tractor, 1. check your manifold exhaust manifold bolts are tight, 2. check the timing sounds lik,e it running very retarted timing or its way off.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2006, 05:50 PM   #4
shepv8
V8's for ever
oh , your starter motor could need a look at. Check the brushes etc.
if it sounds like a tractor check you dont have a leak at your exhaust manifold. If unsure put a new gasket in and torque up the exhaust bolts properly
Old 16-05-2006, 01:24 AM   #5
tufLTD
tufLTD
tufLTD's Avatar
Originally Posted by Dano
Hey,
Sounds like your timing is way advanced. This would cause the pinging & the sluggish starting. Try setting the timing to 10 deg BTDC at idle (with vacuum hoses disconnected). If it doesn't ping at 10 deg, try going up another 2 deg at a time until it pings, then pull the timing back a little.
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2006, 01:25 PM   #6
Dano
cheers dudes, im onto it. will let u know how i go
