Old 13-07-2007, 12:59 AM   #1
hrb93
Default AR Telstar Water troubles?
Hi,
I have an AR 84 Telstar, 2.0l Auto. I has done 53,000Kms and is in great condition apart from a few oil leaks due to the age of the car and not being driven much.
Anyway, yesterday i noticed the temp gauge go hot all of a sudden, i pulled over and it was bone dry, i poured some water in and it appers to be coming out of a hose/clamp under the manifold on the passanger side.
Any ideas what the hose/clamp could be?
Thanks.
PS: It blows black smoke (Fuel) and uses a heap of it, would FORD be able to give it a tune up?
Thanks again.
hrb93 is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2007, 07:53 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
that would be a pipe joiner into the inlet manifold to cool the carby
if the hose has a split or the clamp failed you are lucky
corrosion may be the problem
black smoke-- the carby is running rich probably a choke issue /sure tune it
To ford your money is as good as everyone elses
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
