Old 10-04-2014, 12:26 AM   #1
bmac3
bmac3
bmac3's Avatar
Default BF ICC screen cuts out
I have a BF XR6 with a colour screen and the ASL DVD interface through the sat nav multipin plug in the ICC base .
Occasionally there is a clicking (relay )in the right kick panel and the ICC screen goes black (switches off) . Comes straight back on but sometimes clicks off and on a few times before setting down .
Also has factory Bluetooth interface for the phone .
After screen comes back on it behaves as if just powered up where the Bluetooth resets and the screen shows the "media" wording briefly .
I'm tipping a faulty earth but have you any idea where I should start looking . That is where is the earth point for the auxiliaries .
May not be connected but external mirror switch has the same effect on the ICC if you try to operate the mirror adjustment .
bmac3 is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2014, 08:39 AM   #2
FADI75
Sponsor
Default Re: BF ICC screen cuts out
hi
you most welcome to call us 0397991444 and ask to speak to one of the techs here at ASL
cheers
fadi75
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
Old 10-04-2014, 08:05 PM   #3
foxtrot3
foxtrot3's Avatar
Hi. Have a good look at the ignition switch and make sure the back of it is not loose, sounds more like the car is dropping the accessory power feed. Also make sure that the key springs back from the start position after starting the car. Cheers MD
HI
I'M MICHAEL
Old 10-04-2014, 11:42 PM   #4
bmac3
bmac3
bmac3's Avatar
Thanks Foxtrot & Fadi , I will have a look over the weekend and if still in doubt I will call you during next week Fadi .
Regards ,
Brad .
Old 25-02-2015, 11:31 PM   #5
Shankerleez
Hi
Just wondering how you went with this issue, I recently upgraded to premium icc, I have been running it on the am and menu button 5 mins of play, I got Ford to recode it yesterday now I'm getting this, the screen gets flickering lines and went on off a couple times
Ray-J
Shankerleez is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2015, 08:57 AM   #6
FADI75
Sponsor
Originally Posted by Shankerleez View Post
Hi
Ray-J
hi
you will need to book your car in with us ph 0397991444, sounds like the screen is at fault, sorry cant price it before testing icc
cheers
fadi75
