07-08-2020, 01:26 AM | #1 | ||
Recommendation for a good and super reliable shed alarm please. I have tried several versions of this generic sort of thing https://www.ebay.com.au/itm/wireless...wAAOSwVRpfDV1X over the last few months and something keeps triggering these alarms even if I am only using the magnet door switch and no motion sensors. It triggers randomly but usually within 20 minutes of arming (sometimes with 5 minutes). You would think that being in a colourbond shed and surrounded by metal on all sides would stop most external signals interfering with it. There is also nothing inside the shed that I suspect could be triggering it; nothing is powered on at the various mains power outlets. I have cameras that monitor the shed and a good padlock but there have been several attempts to break into it over the last year since the block behind me is being redeveloped and is essentially now a vacant block. Video footage is never sufficient to identify the hoody wearing scum attempting to break in. Fortunately, I am a very light sleeper and so far have disturbed the felons before they got past the padlock. This luck can’t last and it is also turning me into an insomniac laying half-awake listening for trespassers. Altronics, and Jaycar have surprisingly nothing suitable. I would prefer something that is mains powered with a battery backup that sets off an alarm when the sliding door is opened. I am not keen on motion sensors as there are too many critters such as geckos, skinks, juvenile dugites and likely mice (although I’ve seen none or any droppings) that move around and would set of the alarm. Is it worth spending $700 on one of these Yale systems from Bunnings: https://www.bunnings.com.au/yale-eas...m-kit_p0079199 or will I have the same issues? I would also be interested in any ideas on what might be triggering the alarms systems I have tried. All my vehicles have good and multiple security systems; this is more about securing my tools etc.
regards Blue |
07-08-2020, 06:33 AM | #2 | ||
Hi,
To scare someone off before they break in, try this dual beam IR sensor at the back of your block, (installed above where cats would walk). You could wire this up via a relay to anything that makes noise, a car horn, a bell, lights, etc, https://www.ebay.com.au/sch/i.html?_...rimeter+sensor If you want the alarm inside the shed to work, which means you get a broken door before the alarm goes off, then I think PIR detectors of a good brand could be what you need. They should be pet safe, so something small shouldn't set them off. One alternative if you already have a house alarm is to get one with individual zones, and extend a zone to the shed, and have that zone turned on when you are not there, even if you are home in the rest of the house. A good quality separate alarm for the shed, such as a Bosch solution 3000 sell for under $400 on ebay, and it isn't rocket science to install. (possibly plus the communication IP module and a roll of cable ) Alternatively, many of the new CCTV camera systems can set alarm outputs when there is motion detection in front of the cameras. I think you would have a few false alarms with that. Disclaimer: I'm not security specialist in any way, so I'm sure someone here does this for a living and can give further advice. Cheers, |
07-08-2020, 10:03 AM | #3 | ||
20,000 volts
COVID 19 tests being undertaken inside.
07-08-2020, 10:21 AM | #4 | ||
I have duel Rottweilers and CCTV
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
07-08-2020, 10:59 AM | #5 | ||
I'm not exaggerating when I say that the best thing you could dois to make your property snake-proof, and get a dog.
If you want to go cheap, you could just put a switch on the door, wired to any screamer. I'm sure there are plenty of cheap alarm units that would do that job, or even simpler just the door-switch and put the power-switch inside your house (and bury the cable.) But as Happy said, that means they will have broken your lock before the alarm goes off. I would also consider the idea of your basic security lights. There are very good commercial IR detectors that you can use to secure your yard. They are reliable and they work, but they are presumably a bit more expensive.
Time to Make the Hippies Cry Again |
07-08-2020, 11:57 AM | #8 | |||
regards Blue |
07-08-2020, 12:01 PM | #9 | |||
regards Blue |
07-08-2020, 12:12 PM | #10 | ||
I do have 3 IR cameras that cover all of the back yard and shed and they can trigger an external alarm siren (the system does still turn flood lights on) but there are too many cats that walk through the yard each and every night so I have to leave the alarm off. The shire is talking about tightening up on cats so they will not be allowed out of their owners yard so thing might improve; but I doubt it as I can't see the people that allow their cats to wander freely at night changing their ways.
regards Blue |
07-08-2020, 12:17 PM | #11 | |||
regards Blue |
07-08-2020, 12:27 PM | #12 | |||
regards Blue |
07-08-2020, 12:45 PM | #13 | |||
GT-P With An Ego
the proper solution is a wired option. wireless is great in principle, but always heavily compromised for a large number of reasons.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, Ford Performance Club of ACT |
07-08-2020, 02:08 PM | #14 | |||
regards Blue Last edited by aussiblue; 07-08-2020 at 02:15 PM. |
07-08-2020, 03:38 PM | #15 | ||
I could lend you my guard dog for a week or so. He's a sneaky bugger
07-08-2020, 03:50 PM | #16 | ||
I'd recommend something from the Smith and Wesson product range...
After I read your post again Aussiblue I realised it was for keeping your tools and things safe. I thought for additional vehicle protection you could instal some of the lockable bollards that go into the concrete. But not really going to help you here |
07-08-2020, 04:00 PM | #17 | ||
What about a couple of motion activated sprinklers or get some led lights and have them on all night .
07-08-2020, 05:55 PM | #18 | ||
Well I have found what is causing the false triggering.
Rather than build an RF sniffer i decided that I would walk around in my shed with my handheld radio scanner testing at the frequencies commonly used for wireless alarm systems (bonus discovery so my radio scanner still has a use after all). Tuned to 315 Mhz it quickly found this: https://www.repco.com.au/en/product-...tarter-2400amp , my Repco 2400 Jump Starter, emitting a strong signal from 310Mhz to 315Mhz and slightly beyond. Even at 5Mhz their RFI albeit not as strong. This is with it NOT plugged in and being charged just "passively" (or not so much it seems) sitting there. It is a bit too heavy and bulky to relocate into the house and too expensive and useful to scrap or sell. Nothing in its handbook about meeting any radio frequency emissions either. Does anyone else have one and if so can they confirm there's is doing the same in terms of RF emissions? So in the absence of any of you having a better solution, I am going to see if I can find my old tin of Electrodag to paint the inside of it's plastic case of this jump starter. This is a conductive grey coating paint I used to use to coat the inside of the plastic cases on Microbee computers to similarly stop RFI when I was playing around with them in the 1980's. I can't help thinking the "dag" part in the name came from it sheep dag like consistency. I was hoping Altronics, Jaycar RS Components etc would now have any similar stuff in a spray can at a reasonable price. In any event, after 30 years on I expect my can of Electrodag may have gone from daggy to chunky. It's now a Henkel Loctite product and very expensive per: https://www.laddresearch.com/chemica...graphite-paint There is this on ebay https://www.ebay.com.au/itm/Conducti...AAAOSw5ohep~iF and this https://www.altronics.com.au/p/t3133...aint-jar-50ml/ Not cheap and not in a spray can. I gather musos use similar stuff to paint the inside of their electric guitars e.g. https://www.ebay.com.au/itm/Professi...cAAOSwNSxU9fyM so perhaps if any of you are electric guitar musos, you might also be able to suggest a source.
regards Blue Last edited by aussiblue; 07-08-2020 at 06:07 PM. |
07-08-2020, 06:23 PM | #19 | ||
I wonder if there is some cheap self adhesive foil metal foil I could use to shield the inside of the case at less cost. I have contacted Repco and asked if this is normal and if there is a simple solution.
regards Blue |
07-08-2020, 06:23 PM | #20 | |||
Frankenford pilot
She heard a noise the other night and yelled out “is that you in the shed” I was watching the telly it was enough to scare them off before getting to much, only lost one option 52 rim and tyre. The missus got a good talking to and the dogs are no longer inside after dark My house backs onto parkland and by the time I wandered out there and found the door open they were long gone. The way the small storage sheds are set up I’ve got a couple of battery operated sensor lights pointing at each other and there’s only one way in to the doors. As much as I would like to hard wire the sheds to “lighten” up their day, I love my dogs to much
Cheers Bretto 73 XB GT Last of the Big Ports |
3 users like this post: |
07-08-2020, 06:56 PM | #21 | ||
I never had any problems with wired IR movement, located indoors, sensors generating false alarms. (Yes, cats will definitely set off IR movement detectors located outdoors.) Perhaps an option is to wire up the shed with magnetic switches and have a loud alarm inside the shed and a repeater alarm outside the shed. I do think that thieves do notice security cameras. One can get better images at night by using IR flood lights.
Straight out of the T4 book, the big thing is "defence in depth" and not relying on one thing. The principle is; deter, detect, delay. For example; sensor lights, visible security cameras, and a visible alarm light helps deter (as well as detect). A clear field of view to the shed helps. A decent lock will delay (but if the alarm is screaming, the intruder will be under serious time pressure). There are a number of web sites (including government ones) that provide some good ideas on security (and not all of them require lots of cash to implement). |
07-08-2020, 07:14 PM | #22 | ||
07-08-2020, 07:55 PM | #23 | |||
In all the one's I've had, there was a hard on/off dial/switch, that physically disconnected the battery. In that mode they were just batteries. I can only assume that in yours something is permanently live. At a guess, maybe this : "The low voltage warning system activates automatically" Assuming yours has a master on/off, you might want to rewire it. Or try storing it inside a steel cabinet.
07-08-2020, 08:27 PM | #24 | |||
regards Blue |
07-08-2020, 09:05 PM | #25 | ||
Hmmm says he cant have guard dogs as he has a snake problem
for the life of me cant fathom why not incorporate the snake problem in to being the security system can even see a movie ---- snakes in a shed "the last secure stand !" , recon i could cast samuel l. jackson
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
07-08-2020, 09:13 PM | #26 | |||
regards Blue Last edited by aussiblue; 07-08-2020 at 09:21 PM. |
07-08-2020, 09:21 PM | #27 | ||
Regular...with metamusal
07-08-2020, 09:25 PM | #28 | ||
I have cameras too but as I said they don't seem to deter the scum and ID a person wearing a hoodie seem too difficult for the constabulary (probably there's also not a lot of interest as I have stopped any actual theft so far by disturbing and scaring the offenders off so it's just a trespassing issue no actual breaking and entering has occurred so far).
regards Blue |
07-08-2020, 09:35 PM | #29 | ||
Is there anything you can do to make the exterior or interior more secure, such as a metal cage storage cabinet for your tools? Or make it harder for them to get into, or out of, your yard?
2022 ZH Escape ST-Line AWD 2.0L Ecoboost |
07-08-2020, 10:15 PM | #30 | ||
I must say that your shed seems like a popular place to be.
I would consider relocating the tools into a large floor mounted safe and/or anchor anything that can possibly move on its own, they do this to prevent theft in the UK with very large expensive chains and anchor points for motorbikes. Its the only thing that will work, an un-cuttable chain and a huge $200 anchor point. Oxford makes a good affordable anchor. You get them on eBay and need a large industrial hammer drill to drill the holes required. https://www.ebay.com.au/itm/Oxford-S...e/333225017260 The chains are more expensive. They are worth every penny, a theif easily has access to bolt cutters, make it so that he needs the good quality bolt cutters by getting an expensive chain and he will snap his teeth on your chain trying to break it. I would also consider raising your fence or beefing up your fence so that they cannot easily get onto your property in the first place. The best offence is a good fence in my book. I would also electrify it but thats me. Give them a tingle with a current limited device along the fenceline with a ground stake. If you're serious a couple of microwave transformers will show them the error of their ways. Might want to leave the last option for post-apocalyptic society. Last edited by gooseneck; 07-08-2020 at 10:27 PM. |
