Old 10-05-2012, 02:56 PM   #1
FPV_Steve
Livin Life in the F6 Lane
FPV_Steve's Avatar
Default BFII F6 brake enquiry
Hey Matt,
I am considering upgrading my brake set up on my BFII F6 Typhoon.
I currently have the brembo 4/1 set up on my car.
Can you give me a quote on the cost of a brembo 6/4 set up, just for the calipers themselves.
I am also assuming that the 19" standard FPV wheels I have will be able to fit the 6/4 set up?
Also, if I was to purchase the 6/4 caliper set up, do I have to get new brake discs & pads or can I use my current ones until they need to be replaced?
Lastly, do the braided brake lines improve braking performance and are they worth buying?
Cheers,
Stephen
FPV_Steve is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2012, 06:52 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: BFII F6 brake enquiry
Originally Posted by FPV_Steve
Hey Matt,
Cheers,
Stephen
Stephen we can do the full 6/4 kit with rotors and braided lines from $4500
The front rotors on your kit could be used but the rear can't as they are different but my suggestion is buy the 6/4 kit complete so you can resell your 4/1 kit complete.
Braided lines are inluded in the kit price and will give you a firmer pedal.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 10-05-2012, 07:02 PM   #3
FPV_Steve
FPV_Steve's Avatar
Thanks for that.
Can I just also find out what the front 6 piston and rear 4 pistons cost separately as well.
And what I'm looking at for a new set of rear rotors for the 4 piston calipers?
Cheers,
Stephen
Old 11-05-2012, 02:57 PM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thanks for that.
Cheers,
Stephen
We have a basic 6 piston kit from $2099 and a rear 4 piston kit from $2000 but this all changes when different rotors and braided lines and pad material is added.For example the 6/4 kit i quoted from $4500 has certain products in it that don't come wih the cheaper options but we can mix and match to a point depending on what you want.
Rear DBA T3 330mm slotted rotors to suit the brembo's are $235 each
MATTHEW PEARCE
Phone 02 9609 1101
Old 09-07-2012, 09:43 PM   #5
FPV_Steve
FPV_Steve's Avatar
Hi Matt,
Got another question for what you have said above. Can you give me a break down for what is provided as part of the $4,500 6/4 kit you provide.
I was aiming on getting the 6/4 caliper set up, dba 5000 front rotors, dba 4000 rear rotors, braided brake lines, good quality brake fluid and the pads I'm not too sure, but I am currently running Bendix SRT pads on the front and happy with them.
Cheers,
Stephen
Old 10-07-2012, 10:27 AM   #6
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Hi Matt,
Cheers,
Stephen
The kit is a bolt on kit so all parts are supplied to bolt it on and for Forum members we supply the DBA T3 (4000's) slotted discs front and back in the $4500 kit with factory brake pads and braided lines included.
We can do a kit for you with the 5000 fronts and SRT pads all round if thats what you want but it will be around the $5400 mark.
MATTHEW PEARCE
Phone 02 9609 1101
