31-12-2007, 03:14 AM | #1 | ||
not here much anymore
In an attempt to avoid the same threads coming up weekly, here's a few tips/answers/comments about the AU V8 range.
Q: How do I tell if my XR8 is a 200 or 220kw model? A: There is only one 100% foolproof way to do it, and that is to call ford with your vin and verify it. The number is 13FORD. The other ways are looking for the following features: * "220" Badge on rear bootlid * Tickford wings engraved into throttle body * Colour Coded Exterior Mirror Scalps As a general rule, 220kw motors were introduced into AU XR's from April 2001. This means late Series II models, and all Series III models got the 220kw donk. NOTE: This does NOT apply to XR8 Utes, where the maximum engine power available from factory was 200kw. No ute ever had the 220kw engine factory fitted. Again the April 2001 date is correct to identify your ute and determine whether it is a 185 or 200kw version, the 185kw utes also have a spacer between the throttlebody and the intake manifold. If your ute has the spacer there, it's a 185kW spec engine. If it doesnt, you've likely got a 200kw motor. Q: How much power does my XR8 have? Its a Series I. Power Outputs for the entire AU XR range were as follows: (from factory) AU Series I, Sedan and Ute: 185kw AU Series I, NON XR Sedan and Ute: 175kW AU Series II, Sedan: 200kw (late April onwards 220kw) AU Series II, Ute: 185kw (after introduction of Pursuit model, 200kw) AU Series II, NON XR Sedan and Ute: 175kW AU Series III, Sedan: 220kw AU Series III, Ute: 200kw AU Series III, NON XR Sedan and Ute: 175kW The exception to this is that the AUII onwards V8 LTD models did have 185kw, with the difference being made up primarily from a twin system exhaust fitted to that model. Q: What model got the 5.6L stroker engine? This engine went into Series III AU models known as T-Series. There were 4 models - TE50, TS50, TL50 and a ute model known as the Pursuit250 (although this was technically just an XR8 with a bigger engine). These models can be identified by their bodykits, bigger engines, 18" alloy wheels, brembo or tickford premium brakes (both were available), and in the case of the sedans, a build plate in the engine bay stating the model name and number (Utes did not get this). More info on the T-Series range can be found in the T-Series Room HERE Q: What's the difference between a "Pursuit" Ute, and the rest of the range? This is where it gets tricky. Ford released a model called the "Pursuit", which was an XR8 Ute (XR6 VCT utes were also available), with MOMO gear such as steering wheel and shifter, leather trim, Tickford Bodykit and Sports Bars on the back all included for an extra $1k. (The XR8 versions also had a 200kw motor as opposed to the 185kw regular offering, but after the introduction of Pursuit Utes the 200kw motor became the standard offering in all XR8 Utes). These were known and badged as Pursuit Utes, and are not to be confused with the Pursuit250 as described above. Q: I own a V8 AU but its not an XR. How much power does it make, and what is different on the engine compared to a XR model? For all non-XR V8 models the power remained at 175kw in all series except the AUII LTD as mentioned above. These engines have the same heads as the 200kw-spec motors (these heads are known as GT40Ps), same intake manifold (5.6L stroker has a specific manifold though, this is the only exception), but a smaller (65mm) throttle body and MAF sensor. Exhaust systems, particularly exhaust manifolds, also differed in design and were not as high-flowing as the XR types although the LTD models as mentioned got a twin exhaust system as standard. Q: My car has a Herrod/SVO badge on it. What does this mean? It means at some point the car has been worked on by an aftermarket company. Herrod and SVO are two of the biggest, and both did a lot of work on AU's. If you have the badges, best to call them and see what has been done. Q: Can the V8's in AU models be modified and if so what can I do to it? In a nutshell, yes they can be modified and you have a wealth of options seeing as the Windsor V8 has been in service for decades. Cylinder Heads, Cams, Manifolds and even Stroker Kits are all relatively easy modifications but they do require a bit of careful planning and a budget to work with. Exhaust systems and intakes are often the first mods that AU Windsor owners carry out and there's a wealth of info in these forums as well as the 'Workshop Builds' section. Also check out the Windsor V8 Forum HERE to see what other owners have done, and to get advice on what cam will be best for your car.
RAM 1500
31-12-2007, 08:12 AM | #2 | ||
Formerly known as TS 50
Non XR V8s had 175kw engines.
BLUEPRINT T3 TS50 #109, MANUAL WITH BREMBOS
31-12-2007, 09:41 AM | #3 | ||
Ya i remenber V8 was a 175kw. a good write now i just need to get a V8 to compared it lol...unless... i'll have to use my house mate V8 lol.
Many Thanks 2001 AUII Factory LPG Manual XL Styleside Box High series bonnet Clear Side Indicator K&N Air Filter BAXR6T Snorkle Low Fronts, Super Low Leafs Last edited by LPGUTE; 31-12-2007 at 09:42 AM. Reason: grammar |
31-12-2007, 11:25 AM | #4 | |||
RAM 1500
31-12-2007, 01:13 PM | #5 | ||
Club Moderator
With the 200kw motor, the Left cylinder head will have '200' stamped on it.
As Austin has said, the easiest way to check is to call Ford. The t/b and badges can be put onto any car. Also the 220kw motor got an engine oil cooler and runs the smaller oil filter, as where the 200kw motor doesnt have the cooler and runs the standard Ford oil filter.
2001 T2 TS50 2002 T3 TS50 2006 FPV GT Racecar 2010 FPV F6 Ute 2016 FGX XR6 Sprint 2020 PX3 Ranger Wildtrak |
31-12-2007, 01:18 PM | #6 | |||
all other non XR models were 175kw. http://www.drive.com.au/buy/market_v...&body=4D+SEDAN |
31-12-2007, 02:24 PM | #7 | ||
Miami Pilot
While we're picking, the XR8 utes on 200kw guise would have had the EGR spacer as well - all 200kw motors did. The 220 is the only one with a single solid TB/EGR setup.
Austin - as a moderator, can't you go back and edit your original post? I think it's worth doing because anyone that reads it will go, "Oh, OK, so that's the story", only to read further down and find all the corrections, which then makes people question the correctness of any info posted in a "one stop Q & A" type thread. I'd correct it with the right info, delete the below corrections, then close it so it's a one post thread (oh, and sticky it)!
31-12-2007, 02:28 PM | #8 | |||
31-12-2007, 02:37 PM | #9 | |||
AULTD
31-12-2007, 02:48 PM | #10 | |||
We'll get the right info going, then I'll re-write the lot and get rid of this thread, and sticky one up. After that I'll have a go at doing the 6 cyl models.
RAM 1500
31-12-2007, 02:50 PM | #11 | |||
Miami Pilot
31-12-2007, 02:54 PM | #12 | |||
31-12-2007, 03:56 PM | #13 | |||
Barra Turbo > V8
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels |
31-12-2007, 10:26 PM | #14 | ||
Are you sure about that?
Another way to tell if it is a 220kw is the 220s have an engine oil cooler mounted behind the grill.
When I grow up, I want to be half as good as you THINK you are. |
02-01-2008, 12:23 AM | #15 | |||
Back on the road
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
27-12-2008, 08:25 PM | #16 | ||
My utes a series 2 Au xr8. Hand built 200kw, not 185 ;)
27-12-2008, 08:55 PM | #17 | ||
Afterburner + skids =
This thread should be a sticky.
27-12-2008, 09:56 PM | #18 | ||
I've stuck this one and made a few edits but any more info that we can come up with will be added provided it's correct.
RAM 1500
28-12-2008, 01:27 PM | #19 | ||
formerly "3x-puursui7"
i dunno if u wanna add this, but i had the issue with the wrong filter first time i went to service my 220. I did have the other brand part numbers but cant find them atm.
the K&N part# HP-2004 also this is the dimensions and stuff straight from their website. Height: 4.1 in (104 mm) Outside Diameter: 3.66 in (93 mm) Thread Inside Diameter: 0.75 Thread Number: 16 UNF-2B PSI Relief Valve: 8-11 Anti Drain Back Valve: Yes
all hail the mighty V8's http://www.aufalcon.com.au/3x-puursui7 |
28-12-2008, 04:31 PM | #20 | ||
200 spec V8's take a Ryco Z9/Valvoline V01
220 spec take a Ryco Z89
RAM 1500
28-12-2008, 09:04 PM | #21 | ||
So the 220 au2 xr8 sedans didnt necessarily have the 220 insignia on the engine cover....?
28-12-2008, 09:37 PM | #22 | ||||
AU DIE HARD
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... .................................................. Quote:
28-12-2008, 09:48 PM | #23 | ||
It's really strange, because mine has all the indictations of a 220 (incl. build date), bar the different engine cover.
28-12-2008, 10:14 PM | #24 | ||
Engine covers are easy to change so I wouldnt be relying on it to determine whether it's a 200 or 220 spec engine.
RAM 1500
28-12-2008, 10:15 PM | #25 | ||
there was no 5.6litre TL50's produced i believe.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
28-12-2008, 10:15 PM | #26 | ||
As b2tf said, engine covers tend to rub and get trashed easily, so it wouldn't be out of the question for it to have been replaced at some stage.
28-12-2008, 10:17 PM | #27 | |||
28-12-2008, 10:23 PM | #28 | |||
RAM 1500
28-12-2008, 10:36 PM | #29 | ||
Is the 347 the biggest stroker kit you can get for the 5ltr windsor
28-12-2008, 10:40 PM | #30 | |||
RAM 1500
