Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 30-05-2016, 10:25 AM   #1
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Twin piston 355mm brake kit
From $1500 PBR2P355kit front only kit. AU11 AU111 BA BF and FG
We have re introduced a brake kit we did some time ago using the PBR Performance twin piston caliper and the Brembo size 355mm x 32mm disc rotor. This kit has been fitted to numerous cars over the years and forum members.
The kit consists of a PBR Performance caliper in red with PBR performance brake pads along with braided lines , brackets and DBA T3 rotors for the price of $1500. We have options to change pads and rotors to make it a little cheaper or make it dearer if genuine rotors or 2 piece rotors are needed.This kit will need 18" wheels atleast but should fit behind most factory wheels (we just haven't tried everyone yet). We only have 5 front kits this time and we had the brackets water cut and are admittedly a little rough to how i would have liked them but the next batch will be back to being made cnc and a lot neater.
The rear 328mm PBR upgrade like the FPV or Terri's have is also available in various forms.
Pictures on our facebok page. Will upload here soon.
https://www.facebook.com/Race-Brakes...0218500996434/
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Phone 02 9609 1101
325mm x 32mm Twin piston front brake upgrade kits available. Limited stock $1495. Same as the BA GT kits in red.
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
FLOORED is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2016, 10:27 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Twin piston 355mm brake kit
The kit as mounted to a BA upright. The kit will fit AU11 AU111 BA BF and FG.
MATTHEW PEARCE
Phone 02 9609 1101
Old 31-05-2016, 04:15 PM   #3
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thumbs up Re: Twin piston 355mm brake kit
MATTHEW PEARCE
Phone 02 9609 1101
Old 04-06-2016, 04:42 PM   #4
JC
JC's Avatar
Could this be an option for those with 6/4 brembos to fit (say) an FG XR8 18" rim to the front, keeping the brembo 355mm discs and using these calipers? If so, how much just for the calipers, pads, brackets and braided lines to suit?
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60'
1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs)
Ford Performance Club ACT
Old 05-06-2016, 08:40 PM   #5
MattSAU2XR8
I think that's the general idea. Might not have the outright stopping power of Brembos but WOULD have the advantage of much improved fade resistance and less warping (as per Brembos) because it's a large and good quality disc. And the standard Flcon brakes aren't terrible to begin with for the first stop or two if you fit good pads, just go downhill once they get hot. Paired up with Territory rears (or even without) it sounds like a great deal - and every part other than the bracket is available off the shelf, eg. discs, pads, piston seals and so on. Once I've used up the brakes I have I will likely get a set of these :-)
MattSAU2XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2016, 10:13 AM   #6
FLOORED
Race Brakes Sydney
FLOORED's Avatar
This set up is for people who can't fit brembo's to there wheels or have the budget for Brembo's. This kit should fit behind the 18" FG XR8 rim but we haven't tried all of them as yet.
The kit is only available in kit form sorry i do not have enough brackets to sell separate. We may do another run down the track.
MATTHEW PEARCE
Phone 02 9609 1101
Old 19-09-2016, 10:48 AM   #7
geobar
Saw these on a FGX on car sales.
Looks like they clear the FGX 19's
George
geobar is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2016, 11:49 AM   #8
Professor Farnsworth
Fossil fuel consumer
Professor Farnsworth's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Many years of valuable contributions to the forum, including some superb build threads.
They look good don't they.
blue stang turbo green stang
Professor Farnsworth is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2016, 07:42 PM   #9
geobar
Yeah a good package Matt has done for guys not wanting to change wheels.
Old 10-10-2016, 10:02 PM   #10
theunfairadvant
For this mags can you fit a 6 pot brembos and 4 pot rears.
Sent from my Vowney using Tapatalk
theunfairadvant is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2016, 01:53 AM   #11
Mechan1k
Mechan1k's Avatar
Pretty sure I saw this setup behind a set of G6E 19"s ... so clears the back of the spokes on those from my understanding.
Old 11-10-2016, 11:14 AM   #12
FLOORED
Race Brakes Sydney
FLOORED's Avatar
On any front wheel you need atleast 90mm clearance between the outside rotor face and inside spoke face for Brembo's to fit. We also have a thread going in our section with over 130,000 views for wheels that clear brembo brakes if that helps.
http://www.fordforums.com.au/showthread.php?t=11310061
MATTHEW PEARCE
Phone 02 9609 1101
Old 14-02-2017, 12:50 PM   #13
FLOORED
Race Brakes Sydney
FLOORED's Avatar
I have 5 more twin piston 355mm kits available for sale and these may be the last kits we will do. The 328mm rear kits are also available.
MATTHEW PEARCE
Phone 02 9609 1101
Old 22-02-2017, 02:31 PM   #14
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Calipers are red on these just in case no one is aware of this. (I was asked)
MATTHEW PEARCE
Phone 02 9609 1101
Old 23-02-2017, 06:27 PM   #15
Tiger57
Are these a worthy upgrade over the 322 Turbo brakes and do they fit inside the FG 18's?
Tiger57 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2017, 06:44 PM   #16
Sox
RIP...
Sox's Avatar
Can you please quote the above whole kit using DBA T3 and Bendix HD pads?
Front and rear to suit an AU sedan with IRS rear.
Oval Everywhere...
Old 24-02-2017, 09:47 AM   #17
FLOORED
Race Brakes Sydney
FLOORED's Avatar
You will need a few mods done to the rear to make it fit but i believe the info is up on this forum. Total cost is $2500 for this kit complete with all brake components. Freight to you is extra.
MATTHEW PEARCE
Phone 02 9609 1101
Old 24-02-2017, 11:27 AM   #18
I'm assuming this kit fits behind fg2 19" luxury wheels? I've been debating Brembos for the turbo for years but don't want to ditch the wheels for one thing.
Old 24-02-2017, 12:34 PM   #19
FLOORED
Race Brakes Sydney
FLOORED's Avatar
It fits behind most wheels although one guy in QLD said it didn't fit one of his wheels once but we never found out what wheel it was as he offloaded it on his mates car.
We use the front 355mm rotor used on the Brembo kits so that sits about 15 to 20mm closer to the rim than the factory std discs if that helps.
MATTHEW PEARCE
Phone 02 9609 1101
Old 02-05-2017, 10:07 AM   #20
Neme
Needav8
Neme's Avatar
Any of these still available mate?
Back in the game with an '02 AUIII manual XR8
Neme is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2017, 12:17 PM   #21
FLOORED
Race Brakes Sydney
FLOORED's Avatar
I have 2 left thankyou
MATTHEW PEARCE
Phone 02 9609 1101
Old 08-12-2017, 06:16 PM   #22
FLOORED
Race Brakes Sydney
FLOORED's Avatar
OK we had sold out of these but just recently have another 1 or maybe 2 kits (if i get the last set of calipers) .These may well be the last as the calipers are no longer available.
MATTHEW PEARCE
Phone 02 9609 1101
Old 14-12-2017, 12:01 AM   #23
JCSags
Matt,
Interested in a kit. Car is Mk2 GS with 19 rims same as on BF GTs. Currently has 322mm front and solid 303mm rears.
Cheers, John.
JCSags is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2017, 10:08 AM   #24
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by JCSags View Post
Matt,
Cheers, John.
John those wheels shouldn't be a issue i have 1 front 355mm kit left at $1500.
We can also do a FPV rear 328mm rear upgrade to match for $1000. This would be a one of price for now as all our suppliers have put the prices up on the calipers and i believe the front calipers are now not available and i have the last batch. Freight or fitting would be extra
MATTHEW PEARCE
Phone 02 9609 1101
Old 17-04-2018, 02:24 PM   #25
Moo Man
Just organised a kit with Matt for the front of the AU
I've only ever seen good feedback on the forums for Matt and just wanted to add my 2 cents, his customer service was top notch and I would have no hesitation in recommending Race Brakes.
Cheers,
Moo Man.
Moo Man is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2018, 04:19 PM   #26
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thankyou and that was the last kit we had so all gone now. Let me know how it all goes thankyou.
MATTHEW PEARCE
Phone 02 9609 1101
Old 23-05-2020, 08:40 PM   #27
irvinnie
irvinnie's Avatar
Is this still an available option Matt??
Current rides
2010 GT (build # 152) Tuned by Spiro@Autotech 436rwkw.
2014 FGX G6E Turbo Tuned by spiro@Autotech 307rwkw
- 2012 XR6 turbo Ute 345rwkw
- 2007 Force 6 (build #91) 330 rwkw
- 2010 GTE (build #2) 425rwkw
- 2010 50th anniversary turbo ute 365 rwkw
irvinnie is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2020, 12:28 PM   #28
FLOORED
Race Brakes Sydney
FLOORED's Avatar
No 355mm twin piston kits sorry. Only have a 325mm twin piston kit thanks.
MATTHEW PEARCE
Phone 02 9609 1101
Thread Tools
Display Modes
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
