22-02-2020, 11:52 AM | #1 | ||
1000+ passes
Just a quick question I’ve been searching and still not sure about the engine number location on a Kent 1600 in a 1972 XL Capri, I was about to do an engine swap cause I thought my Engine didn’t have a number so it wouldn’t matter since it was a non matching car, But now I have located the matching number on the front of the block just under the head, is this normal I was under the impression it should be on the side above oil sensor. Thanks in advance Bruce
XY ute 1600+ kgs, normally aspirated pump gas 351 std stroke, cast iron 2V heads, toploader, drag radials, 11.524 - 119.48mph https://www.facebook.com/DragRacingT...2067110055900/ http://www.cacklingpipes.com/100825_...250810_025.JPG XA coupe naturally, aspirated Cleveland, full exhaust, 98 oct pump gas, drag radials, Manual trans, 10.664 132 mph The faster youve gone the worse your attitude |
23-02-2020, 12:19 PM | #2 | ||
RS The Faster Fords
Try here, theres a lot of Capri guru's/ anoraks that'd be able to help
https://www.classic-ford.org/cfp/
Escort RS2000 Restored factory a/c and alloys. TD Cortina Unrestored 35 000km 6cyl manual. Mk1 GT Cortina Project. FG XR50 Daily. |
24-02-2020, 11:58 PM | #3 | |||
formerly ford3000gt
Current ride: '83 Mk.3 Capri, 2.8i, 5-spd |
26-02-2020, 02:50 PM | #4 | |||
1000+ passes
04-11-2020, 09:39 AM | #5 | ||
Hi All,
I am looking for my engine number. I have a 67 Cortina 440 that is running a 1600 Kent X flow 711 engine. Earlier engines had the number near the dizzy, badly stamped into the cast block very hard to read. I see that the later 711 engines have engine number in diff location.. Any chance someone could post a pic of the EXACT place to look for my engine number please? TIA |
04-11-2020, 11:05 AM | #6 | ||
Hopefully this picture attaches properly. This is the location for all 1600 Kent Ford engines pretty much. Unfortunately, if the mating surface ever gets skimmed for a rebuild the numbers can be skimmed off as well.
04-11-2020, 11:11 AM | #7 | ||
Thanks mate. I had my suspicions it was supposed to be there.
My engine was recently rebuilt and obviously skimmed. Thanks again
Seeya ! Wouldn't wanna be ya ! |
