Old 19-06-2018, 05:38 PM   #1
Harit6365
Default Laser won’t start
I have a 1994 Ford laser 1.6 manual the engine use to cut out then sometimes start up again by dropping down the gears other times had to wait for a while then it would start until now when it cut out and doesn’t want to turn over. The ignition lights come on and can hear fuel pump and turn the key and nothing is there anyone who has had this problem or someone who can help me with this problem?
Harit6365 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2018, 11:06 PM   #2
GTLEGEND
Default Re: Laser won’t start
Similar issue happened to my 93 KH Laser, no spark at lead ends, ended up being the distributor module.
So you best start by checking for spark. Pending on your results will determine next steps. No spark could be module or even coil or connections in the ignition system.
Let us know how you go and we can try and work through it. Is it a KH or KJ laser?
Old 20-06-2018, 09:14 AM   #3
falconhell74
falconhell74's Avatar
Yep as above
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2018, 02:41 PM   #4
11ford11
Check battery voltage.
Check battery cables.
Check starter for power at main cable and switch terminal . check earth cable.bridge power to small wire and see if it turns over. Is coolant level normal.
Old 20-06-2018, 03:28 PM   #5
Tassie f100
So does it turn over alright or is it like the battery is flat and the starter won,t work,or it it turning over alright but just won,t fire. If the former,check battery terminals and starter motor connections,if its the latter the problem is almost certainly the ign module on the distributor.
Tassie f100 is online now   Reply With Quote Multi-Quote with this Post
