26-01-2010, 08:40 PM | #1 | ||
Last night my engine light came on and i had two codes teh one i cant figure out what it is is U2514... can anyone please tell me what this porblem code is referring to...
27-01-2010, 05:40 PM | #2 | ||
TBA Customs
Might be best to contact one of the tuners bud, they would no doubt have an answer for you.
18-03-2010, 01:19 AM | #3 | ||
Anyone know the answer to this? I have it as well
I cant find it in the manual |
18-03-2010, 01:40 AM | #4 | ||
VFII SS UTE
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
18-03-2010, 03:16 AM | #5 | ||
VIC The Place to Boost
Just go to clear DTC and it should clear it mate...
F6 310 - Blue Power Racing Developments |
18-03-2010, 10:30 AM | #6 | ||
DTC: U2514
Description: Message for VSS missing Electrical: Damaged wiring or connections between the VSS and PCM. Other: Error on the SCP system between the VSS, PCM, IC and DLC Incorrect VID programmed in to PCM. PCM, IC, ABS not running current software and calibrations. I don't know why people don't use the resources we provide here where you can look then up. Cheers Russ
18-03-2010, 01:49 PM | #7 | ||
It just may be that some people are not aware of what is available and need guidance don't you think?? It always pays to at least ask.
Cheers GT 450 |
18-03-2010, 10:29 PM | #8 | ||
I did find your link eventually Russ thanks
But when I typed in U2514 in search all I got was this thread so I started here Code was cleared and hasn't come back |
19-03-2010, 12:50 AM | #9 | ||
guys i have another code that come up its p1000 whats this mean...
19-03-2010, 01:42 AM | #10 | ||
DTC # P1000
Description: Monitor Testing Not Complete Mechanical: The on board diagnostic II (OBD II) monitors are performed during the OBD II Drive Cycle. The DTC will be stored in continuous memory if any of the OBD II monitors do not complete. Sensor: *Vehicle is new from the factory *Battery or PCM had recently been disconnected *An OBD II monitor failure had occurred before completion of an OBD II drive cycle *PCM DTCs have recently been cleared with a scan tool *PTO circuit is shorted to VPWR or B+ or PTO is on during testing Electrical: The DTC does not need to be cleared from the PCM except to pass an inspection/maintenance test. Go to our DTC Reference Search and select a model and enter a code. If you don't find it under the model use the REF model option as it uses the OBD Reference table as a secondary look up. Cheers Russ
22-03-2010, 12:14 AM | #11 | ||
thanks russel you have been a great help
27-10-2014, 04:55 PM | #12 | ||
Ford territory 2005 is giving error code u2514. Can someone tell me how to resolve
Regards Sunail 0477896997 |
