11-01-2008, 12:29 PM | #1 | ||
is there any way for my pinto motor to be mounted to my engine stand without taking off the flywheel? i removed the bell housing from the spare gearbox and it looks like the arms cant get to all the bolt holes at once.
heres a pic of the engine stand |
11-01-2008, 12:46 PM | #2 | ||
I have that EXACT same stand with my 2L pinto on it. I found it was much easier to remove the flywheel and mount it to the hole that the bell housing bolts up to. If your planning on stripping down the entire motor, I suggest you take of the flywheel so you can access everything on your motor more easily. Mine is only attached to stand with three bolts anyway. If your dead set on leaving the flywheel on, im sure there is a way around it.
Just my opinion anyway : Hope it helps. James Last edited by mk2_1979_escort; 11-01-2008 at 12:51 PM. |
13-01-2008, 05:38 PM | #3 | ||
ill take the clutch off and see if there is room for that.
and this is a youngin question but does the flywheel need to be profesionally tightened? or can u just mark the position and take the bolts out i have a torque wrench. |
13-01-2008, 08:45 PM | #4 | ||
ok its not a pinto motor its me moular v8 for me 77 fairlane nut same situation
hope it helped
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
13-01-2008, 09:34 PM | #5 | ||
yeh i think i will do that unless the flywheel is to think, then i guess it will have to come off thanks!
13-01-2008, 09:55 PM | #6 | ||
Take clutch and flywheel off to get access to bolts. Easiest way to undo flywheel bolts is a rattle gun, try marking it for re-installation in same spot and torque up to specified specs.
For added safety get some ARP flywheel bolts, or use some loctite on your old ones.
Mk2 2dr 2lt Escort Mk2 2dr 1.6lt Escort - now a 2lt. |
13-01-2008, 10:20 PM | #7 | ||
ok ill look at it 2moro
