TL40 Wagon?
I have been running the wagon a bit now and know the limitations of the weight and power I have but i am finding its off the line performance its worst feature.
How do i imporve it? I am tempted to go for the Jim Mock histall as i run theri cam successfully but how streetable will it be for me a wagon dad if i am honest who is still playing at drag racing. My best three times so far in 28 degrees with all the mods in the sig. Name60'330'660'MPH1000'ETMPHjonbays2.34406.570010.009071.450012.963015.464090.2400jonbays2.33406.56809.990072.160012.961015.474091.8400jonbays2.37806.657010.110070.970013.058015.549090.5000 |
TL40 Wagon?
that didnt work hows this
60' 330' 660' MPH 1000' ET MPH 2.3440 6.5700 10.0090 71.4500 12.9630 15.4640 90.2400 2.3340 6.5680 9.9900 72.1600 12.9610 15.4740 91.8400 2.3780 6.6570 10.1100 70.9700 13.0580 15.5490 90.5000 |
trying to get a leg over
![]() Join Date: Dec 2004
A Hi stall converter is your friend, even a 3500 or there abouts are still streetable.
Just make sure you install a trans cooler if you put a Hi stall in as they tend to heat up the fluid in stop start traffic......oh and forget about towing anything too !!!
Cameron ------------------------------------------------------ |
RIP Craig - 13/11/08
![]() Join Date: Feb 2005
What Cam said. The I6 really need a nice stall convertor. You seem to have all the other mods youre just missing out on a real important piece of the puzzle.
Cheers CC |
#5 | |||
Back in the Game!
As far as streetability goes jonbays, I guarantee anyone not totally familiar with the car would not even know it was in there if they drove it. But you will......! :dr_Evil:
2016 Focus RS MK3 XHII XR8 Falcon Ute S/C 5.0 Manual '66 Mustang coupe 289 Auto 70 Mustang Mach1 351 4V/Shaker Auto Previous forum rides: XH Falcon Ute 4.0 Auto BF XR8 5.4 Manual '88 60 Series Landcruiser Turbo Diesel. Komatsu 830E Haul Pac- 2500hp, 165tonnes. AUIII XR6 HP: Prepared by Aussie Car Enhancements & Custom Tuned by Blue Power to a record setting 14.22@96mph. BA Fairmont Ghia 5.4 3V :Unfinished business. |
TL40 Wagon?
OK you're convincing me. my car stalls now at 1800-2000 odd and at 1800 takes off sharply but at 2000 sort of limps off a bit worse. so from 0-45kmh its slow then at 2500rpm it sort of almost switches on and goes well.
So for a stally do i want to go for a 2500rpm 3500rpm stall or what? Jim Mock do them and I can get one of their easy as but what other choices are there? And yes i will put a trans cooler on for sure if i do the hi stall |
Weezland
Yep, stall is the way to go,the only other easy thing is to get as much weight out of it as you reasonably can,the more weight you can get out of it the better it will 60.
#8 | |||
TL40 Wagon?
what about turboing the beast, i might do mine down the track , my brother has donated 2 turbos off supras he`s wrecked 2x3 litre , they are also cheap too buy i think,...... that would get the wagon boogeying
#10 | |||
TL40 Wagon?
I might as well sell it and buy an XR6T it would be cheaper and easier. You can make a high 16 car into a low 15 but what I want here is the red light 0-60 performance increase not to pull 100MPH plus throught the quarter. |
yep point taken.
#12 | ||
what about diff change?
#13 | |||
TL40 Wagon?
Could go lower but the wagon tailshaft is long and the speed limiter becomes stupidly low like 140k if you go too far. It's easy to fix the limiter but not the carnage if it lets go! Also the trans fluid gets foamed up by spinning the ts too fast. I considered 3.73 but kept it at lowest stock ratio as I don't want to put a two piece tailshaft in that would be too much trouble. |
#14 | |||
Weezland
#15 | ||
ahaaa just had a brain wave prolly cost prohibitive, but have you seen the gear vendors site, bolt on overdrives basicly another tranny on the end of a tranny, worth a read anyway, i just mentioned this on another thread, gives a split gear between gears and taller overdrive ....who needs a zf.....http://www.gearvendors.com/hrford4s.html
#16 | ||
owning V8=having no $$$
I also have no stall in my car and found that my 60' time was slightly better when I just stood on the go pedal rather than stall it up then flatten it...I cant explain it, maybe the converter streches a little more by say 100-200 rpm by just standing on it....anyway, thought id share my experience
Weekends - 1965 XP 302 sedan... ![]() Weekdays - 1980 323 Mazdabator complete with cheese cutters & FF sticker :dr_Evil: The Reality: 13.1 @ 106mph.... The Goal: somehow get into the 12s!!! :sm_headba www.qldsuperkart.org |
#17 | |||
TL40 Wagon?
Its not all about launch technique though as i have done this so many times now and even by accident you would think i would have fluked a better technique by now. No its about modding the drivetrain engine ecu or wahtever to improve the 0-40KMh or 60' time not just for a once off PB but for daily driving traffic light launch stuff not really drag strip launches as such. |
#18 | ||
EcoBoostin
yeh same problem with the pannie.
