26-10-2022, 03:39 PM | #1 | ||
I have an AU111 XR8 manual 220,000K's. When my car is turned off and key removed from ignition, a red hand flashes in the dashboard and the interior light stays on. That light does not "fade" off as per usual. In addition, the ignition key courtesy light remains on when the ignition key is removed.
Have disconnected the negative lead from the battery overnight however interior light condition remains the same but the ignition key courtesy light now "fades" off as it should. The car starts and drives ok - no problems and the flashing hand ceases to flash when accessories are engaged and the car is started. Have tried the second ignition key to no avail. Any ideas on what's going on? Cheers |
26-10-2022, 10:30 PM | #2 | |||
#neuteredlyfe
I'm gong to assume that you have the light turned off at the headlight switch. Sounds silly I know but... The flashing hand is the smartshield. Do all of the doors lock? Have you checked that they are all locked when you lock the car? |
28-10-2022, 09:58 AM | #3 | ||
Thanks PG2 for your note.
Understand your "you have the light turned off at the headlight switch". It's a bit like "is it turned on at the switch? Interior light turns off when ignition engaged and car started. Just jumped into the old girl (she's a bit of a garage queen at the moment) and now the interior light as well as the ignition courtesy light turn off. Thanks for the advise on the smartshield. I couldn't find any info on what it was in the Ford books or on the net. I thought it might have been but you've confirmed it - thanks. All doors lock when it's locked. You know what I think it might be is with the wet weather we've had and with the Canberra - Gosford return drive last week when it poured rain, I suspect some moisture has found its way into the electrics and caused these issues. At the moment I can't get the sunroof to close from position 1. It's just developed after the light issue went away however with the car in the garage that's not a real problem. I suspect it's a button press issue which should be resolved with a battery disconnect and reset. Thanks for getting back to me on this. As said, I suspect as things dry out all will come good. Cheers, Jim |
