Old 05-01-2023, 03:44 PM   #1
asimplelife
mechanical novice hopeful
Default M93LE Auto Trans in I6 S3 Sedan will be same as I6 S3 wagon?
Everything I read says there is only 1 type of auto in all AU I6's.
My sedan auto was good but have just removed it for a manual conversion.
The wagon auto clunks hard when kicking back from 2nd to 1st and maybe 3rd to 2nd even after recent service.
Is also now leaking fluid both front and back.
Maybe cheaper and easier to swap the sedan auto into the wagon while resolving the leaks?
The sedan was an option 20 but that is still the same auto?
asimplelife is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2023, 06:55 PM   #2
arm79
arm79's Avatar
Default Re: M93LE Auto Trans in I6 S3 Sedan will be same as I6 S3 wagon?
The autos are the same, same, same then same again for all the AU I6's.
Harsh 1 - 2 and 2 - 1 is usually to do with a problematic S5 solenoid. I can't imagine you getting much change out of $300 to swap the S5 and then it doesn't guarantee a fix nor that there aren't other gremlins hiding in there.
So if the sedan box is good, its probably the simplest and most cost effective fix.
arm79 is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2023, 08:05 PM   #3
asimplelife
Thanks very much for confirming that.
In theory it seemed like the best thing to do.
But someone said to me the wagon auto could be different to the sedan...so off down the rabbit hole I went.
Old 05-01-2023, 08:26 PM   #4
arm79
arm79's Avatar
There might be a difference in the trans mount cross member that bolts under the mount, just keep an eye out and swap if necessary.
