02-07-2022, 04:28 PM | #1 | ||
Hi all, i have a 2008 LT focus hatch 2.0L manual. Ive had an issue for a while but seems to get worse with what the outside temp is doing/ how long the car has sat. I start her up in the AM (driven daily), let it warm up- drive around 3km up the road to the traffic lights, gear down to 2nd, clutch in roll to a stop. Although from clutch in, my REVS start bouncing.
The car will idel around 900RPM-1000RPM (normally) although shes bouncing between 400- 1000RPM for maybe two or 3 bounces then sorts itself out and idel's fine. The other morning the bouncing in REVS was pretty violent. Enough to make the battery light on the dash flicker. Never stalls though. When its mid day and warmer, same situation at any traffic lights i noticed it does it but more bounces between 800-1000RPM so don't notice it much. Anyone have any idea what could be causing this? Some one has told me a temp sensor but im not really sure about that, but if im wrong that fine, they mentioned something about a closed loop circuit. |
18-07-2022, 09:54 AM | #2 | ||
Hi
I had the same issue with my 2007 Ford Focus 2.0 manual. I took the throttle body off and cleaned that which has helped a lot. Just be really careful not to move the butterfly in the throttle body as they are a drive by wire unit and if the butterfly is moved it can break the teeth inside which means having to replace the whole unit which is expensive. My car is also having a intermittent egr code so I will be cleaning out the egr soon which can also cause similar issues. Hope this info helps |
18-07-2022, 06:03 PM | #3 | ||
Had bought throttle body cleaner last week to do it, so glad i was somewhat on the right track. Going to change spark plugs and ignition coils just for the sake of it. I wasnt aware of the drive by wire info so thankyou, probably just save me alot of $$$. Appreciated.
18-07-2022, 07:50 PM | #4 | ||
I looked at few YouTube videos of cleaning throttle bodies. One of them is the following link https://youtu.be/G6bCLTWfGGs. Hope this helps
