Old 23-01-2012, 02:04 AM   #31
BHDOGS
Default Re: Ticking noise from passenger inner guard
mine ticks constantly from starting car to turning it off and ive held it in my hand its touching nothing just ticking away to itself like im sending morse code as im driving.
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2012, 09:06 AM   #32
AU Mont
yeah even one in good condition ticks, thats what its supposed to do, however when its hidden away inside the guard it shouldnt be very noticable
AU Mont is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2012, 08:40 PM   #33
BHDOGS
Can't the one from a eb/Ed ef/el be put in instead they both have two wires just cut of the au one put the eseries one in its place plug in the pipes ticking stopped?
Old 03-02-2013, 03:56 PM   #34
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
Thanks for the link AU Mont, well I think I will go and get a new one aswell and if/when it starts making that noise again then perhaps covering it up.
Im interested in by passing it though, when is the RTA/Police etc ever going to check there?
  • 2023 Mitsubishi Triton
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Old 03-02-2013, 03:57 PM   #35
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
Originally Posted by SVT8 View Post
yeh its loud and embarrasing, sounds like theres something wrong with the engine. Got some insulating stuff from clark rubber that im going to try
How did this go?
I agree, its very embarrassing and the other half said straight up "great..new car and its already broken"...so yeah, I want it fixed.
Old 05-02-2013, 08:06 PM   #36
abzy
awsumness
i put a stereo in so i couldnt hear it haha and now i have a new ute
abzy is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2013, 10:05 PM   #37
rowan194
What rate does it tick at? Could it be mistaken for noisy lifters? I can hear ticking when I go past a kerb or a bush but with the bonnet open it's not obvious where it's coming from (seems more like the bottom of the engine), plus I don't hear any lifter noise at startup before the oil circulates. Could it be my purge cannister?
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2013, 11:47 PM   #38
BHDOGS
its located in the inner passenger guard behind the black wheel shroud pull that aside and stick your ear in you'll be able to hear it if it is
Old 07-02-2013, 09:47 AM   #39
AU Mont
first check that the problem isnt just the solenoid resting on the guard. If it is, then does suspending it away from the guard fix the noise when its all put back together?
If noise is still very noticable, then the solenoid is buggered and wrapping it up with wool from a golden sheep wont tame the sound. Get a new one.
I remember when i got the new one, i found it like to rest against the plastic guard which amplified the normal quiet tick they do, so i undid a couple screws at the bottom where the plastic guard meets the bar and jammed a sponge in between the solenoid and plastic guard
I did this because you cant really position the solenoid away from the guard as its all in a fixed position. Ford engineering at its best
Old 07-07-2013, 11:01 AM   #40
PROXT
434 Cube Dart
PROXT's Avatar
Extend te lines and run it right at the back under rear tyre
PROXT is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2013, 12:07 PM   #41
Blue Oval Mopar Man
Has Blue Blood
Blue Oval Mopar Man's Avatar
My AU1 5ltr fairmont wagon has this noise! sounds like a plug lead shorting out , but on investigation its the solenoid under the front passengers side gaurd .
Real cars dont wear bowties
I'm not arrogent , Just superior
Blue Oval Mopar Man is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2020, 11:29 AM   #42
Lkg1953
Default Re: Tapping noise from passenger inner guard
I removed inner guard and wiper cowling and drove with them off still noise. Suspension is perfect and I also checked behind the A pillar still no joy. Can anyone help
Lkg1953 is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2020, 11:53 AM   #43
Lkg1953
Old 10-12-2020, 02:40 PM   #44
lumen8
lumen8's Avatar
As mentioned in the thread its probably the purge solenoid making noise.
Only permanent fix I know of is what ive done, LS swap the car and run a Holden canister and factory LS purge solenoid on the engine. ... but that wont be of help to you.
lumen8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2020, 02:56 PM   #45
Cures:
Wrap the valve in foam. It that does not work likely the valve is faulty and a new one will often fix it regardless of if the foam works or not.
